AD5666 16-bit dac - did anyone use it?
Hi!
I am starting a project on chemical instrumentation using a Ad5666 DAc from Analog Device.
I'm wondering if anybody in this forum had already use this chip, just to have some tips how to set input and ADC registers.
Thanks so much from Italy
Carlo
Carlo
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Fortunately, PCB layout is already OK.
My problem is the following, I do not have any experience on interfacing this chip, I was just looking for some sample code to speed up firmware development. y experience on DAC is mainly on 12-bit DAC from Microchip.
Carlo
Leon
There is an evaluation board available with pictures of the top/bottom layers here: [noparse][[/noparse]url|http://www.analog.com/static/imported-files/eval_boards/502607298AD5666EB_0.pdf. But I assme you already had a lokk at it :-D
Visit some of my articles at Propeller Wiki:
MATH on the propeller propeller.wikispaces.com/MATH
pPropQL: propeller.wikispaces.com/pPropQL
pPropQL020: propeller.wikispaces.com/pPropQL020
OMU for the pPropQL/020 propeller.wikispaces.com/OMU
My problem is to figure out the correct settings of registers, the data sheet isn't so rich in information! I know that an evaluation board is available, I'll think about.
Yours carlo
the SPI_ASM object seems now to work fine.
Carlo
