AD5666 16-bit dac - did anyone use it? — Parallax Forums
dossicdossic Posts: 38
edited 2009-09-20 18:34 in Propeller 1
Hi!
I am starting a project on chemical instrumentation using a Ad5666 DAc from Analog Device.
I'm wondering if anybody in this forum had already use this chip, just to have some tips how to set input and ADC registers.
Thanks so much from Italy
Carlo
  • LeonLeon Posts: 7,620
    edited 2009-09-09 18:56
    I think that the biggest problem will be getting the PCB layout right so that you can use all 16 bits.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
  • dossicdossic Posts: 38
    edited 2009-09-09 21:26
    Thanks!
    Fortunately, PCB layout is already OK.
    My problem is the following, I do not have any experience on interfacing this chip, I was just looking for some sample code to speed up firmware development. y experience on DAC is mainly on 12-bit DAC from Microchip.
    Carlo
    edited 2009-09-09 21:36
    You won't find out if the layout is OK until you actually use it!
    Leon
  • AleAle Posts: 2,363
    edited 2009-09-10 10:00
    It has a 4 wire SPI interface. It shouldn't be a problem (software-wise) to interface, just be sure to have the data line stable when the clock transitions from high to load because the data is latched at that moment. No, I haven't used it.
    There is an evaluation board available with pictures of the top/bottom layers here: [noparse][[/noparse]url|http://www.analog.com/static/imported-files/eval_boards/502607298AD5666EB_0.pdf. But I assme you already had a lokk at it :-D
    Visit some of my articles at Propeller Wiki:
    MATH on the propeller propeller.wikispaces.com/MATH
    pPropQL: propeller.wikispaces.com/pPropQL
    pPropQL020: propeller.wikispaces.com/pPropQL020
    OMU for the pPropQL/020 propeller.wikispaces.com/OMU
    edited 2009-09-10 18:48
    Thanks for the advise of data latching, it shouldn't be a problem with SPI_ASM object.
    My problem is to figure out the correct settings of registers, the data sheet isn't so rich in information! I know that an evaluation board is available, I'll think about.
    Yours carlo
    Thanks to everybody!
    the SPI_ASM object seems now to work fine.
    Carlo
