Defective Stamp I/O?,...I need help please
I am working with an SX Stamp and do not understand what is happening.
I was getting false readings and started to "unplug" the IOs to the stamp.
When all is said and done, completely unplugged, ·P5 has a resistive value of 16M between P4 and P6 while as every other pin's resistance is open.
Could I have received a defective chip?
This pin was plugged to the output of another basic stamp in my project.
I am stuck,...under a deadline and did not know where to turn.
Anyone's input would be greatly appreciated.
And deleting your other post using the red X in the upper right corner.
- Stephen
How are you measuring the resistance? What do you have connected to the SX chip?
16M is a very high resistance. It may be completely normal depending on how you're measuring it and what else is connected to the SX.
Just on general principles, you probably have a program error. Generally when an I/O pin fails, it becomes shorted to Vdd or Vss or completely open.
Chris Savage
Parallax Engineering
50 72 6F 6A 65 63 74 20 53 69 74 65
