Defective Stamp I/O?,...I need help please — Parallax Forums
GIJOEGIJOE Posts: 1
edited 2009-09-08 16:52 in General Discussion
I am working with an SX Stamp and do not understand what is happening.
I was getting false readings and started to "unplug" the IOs to the stamp.
When all is said and done, completely unplugged, ·P5 has a resistive value of 16M between P4 and P6 while as every other pin's resistance is open.
Could I have received a defective chip?
This pin was plugged to the output of another basic stamp in my project.
I am stuck,...under a deadline and did not know where to turn.
Anyone's input would be greatly appreciated.
    edited 2009-09-08 15:12
    I'd start by calling Parallax tech support.
    And deleting your other post using the red X in the upper right corner.
    - Stephen
    edited 2009-09-08 15:14
    Your question raises more questions ...
    How are you measuring the resistance? What do you have connected to the SX chip?
    16M is a very high resistance. It may be completely normal depending on how you're measuring it and what else is connected to the SX.
    Just on general principles, you probably have a program error. Generally when an I/O pin fails, it becomes shorted to Vdd or Vss or completely open.
    Your duplicate post has been removed. Please post questions on a subject only once and in the appropriate forum. Take care.
    Parallax Engineering
