Using a 3.5mm 4-pole connector for audio and composite video on prop pcbs
Cluso99
The 3.5mm socket takes less space on the pcb and can provide stereo out (or in) plus video (TV) out on the one connector. A cable is required to convert to RCA connectors.
Unfortunately there is a number of incompatible standards. Attached is the diagram of some different connections.
http://www.anythingbutipod.com/archives/2006/04/zen-vision-m-video-cable-other-4pole-35mm-pinouts.php
I am not sure of whether to use the iPod or Nokia/iBook version. The video and ground are swapped which makes them totally incompatible. I looked on eBay·and they can be bought for from about·$5+ including shipping. It is also possible that some people already have one of these versions.
Below are some eBay links... (I have not tried any of these)
http://cgi.ebay.com.au/1AV-To-3RCA-Audio-Video-TV-cable-for-iPod-Touch-Nano_W0QQitemZ260467735952QQcmdZViewItemQQptZAU_Computers_Apple_Parts_Accessories?hash=item3ca5163d90&_trksid=p3286.c0.m14
http://cgi.ebay.com.au/AV-Audio-Video-RCA-Cable-for-Apple-iPod-iPhone-3G_W0QQitemZ170375792287QQcmdZViewItemQQptZAU_Computers_Apple_Parts_Accessories?hash=item27ab30469f&_trksid=p3286.c0.m14
http://cgi.ebay.com.au/AUDIO-VIDEO-TV-OUT-AV-CABLE-FOR-NOKIA-5800-XPRESS-MUSIC_W0QQitemZ300344101776QQcmdZViewItemQQptZAU_MobilePhoneAccessories?hash=item45ede74b90&_trksid=p3286.c0.m14
http://cgi.ebay.com.au/1-2-Meter-TV-Out-Audio-Video-AV-Cable-for-Nokia-N95_W0QQitemZ300344767060QQcmdZViewItemQQptZAU_MobilePhoneAccessories?hash=item45edf17254&_trksid=p3286.c0.m14
Digikey part numbers for the 4-pole 3.5mm sockets...
CP-43514-ND (t/hole), CP-43514SJCT-ND (smt but should be able to be hand soldered)
Do you think this style of connector is a good idea?
If so, what standard do you think we should use (or provide links to swap video and ground)?
· Home of the MultiBladeProps: TriBlade,·RamBlade, RetroBlade,·TwinBlade,·SixBlade, website
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80) , MoCog (6809)
Post Edited (Cluso99) : 9/4/2009 3:49:10 PM GMT
I haven't had time to see if I can make the pcb take either connector by overlaying both the RCA and 3.5mm socket.
I have managed to overlay the USB-A, PS2 connector and 4-pin header. Just have to use a couple of jumpers to get to the right pinouts.
Composite NTSC sprite driver: Forum
NTSC & PAL driver templates: ObEx Forum
OnePinTVText driver: ObEx Forum
My feeling is to have links on the pcb to swap the 2 end "rings" so that the ground can be swapped. Of course, this means we use 2 standards, but then anyone with a cable is fine. I have a pair of Nokia's (they come with the N85 & N95) and I am sure I have at least 1 Camcorder cable somewhere. And these cables are available fairly cheap on eBay and more expensively in the shops (camera, phone and iPod) if you are desperate.
There is even an eBay version with RCA sockets, but I don't know which pinout.
For me, this is a space saving exercise, as fitting into a box means only 1 or 2 ends of connectors.
USB-A -v- PS2:
Recently, Peter said he uses USB connectors instead of PS2 for keyboard and mouse connections. He still uses the clock/data PS2 protocol, but can use newer keyboard and mouse with the USB connectors (not all keyboard and mouse support the older protocol). They take less space and he can buy 2 stacked USB-A connectors in the space of 1 PS2 connector. With a little juggling I have found I can overlay the footprints to get 1 or 2(stacked) USB-A or 1 PS2 connector in a comon set of holes. Even 0.1" pin headers fit into these. FYI the Digikey parts are: 609-1045-ND, 609-1040-ND, CP-2460-ND, CP-2260-ND, CP-4060-ND.
Power connector:
Digikey CP102A-ND, CP-202-A-ND (-A versions are 2.1mm center pin, -B are 2.5mm)
RCA connector (yellow):
Digikey CP-1403-ND, (there is a narrower version but I cannot find the p/n at the moment)
VGA connector:
Digikey 609-2802-ND, 151-1117-ND (shallower footprint)
microSD:
Digikey HR1941CT-ND (smt but can be hand soldered - exposed pins)
mini USB-B:
Digikey WM17115-ND
