GearMotor, Electromechanical Clutches
sup guys, i need some help. Im on the verge of getting a Banebot geared motor from robotshop.com for a two wheel project that im working on.·http://http://www.robotshop.ca/rbban31-banebots-spur-gearmotor.html
My question is : is anyone familiar with this geared motor? can it spin freely by hand if theres no voltage applied to it?
I know with the gearbox/motor arrangements·that i work with its almost impossible to turn a gearbox by hand.
Any good· sources out there for small (12vdc) electromechanical clutches?
What·i want to be able to do is mobilize this bot·with two dc motors at the·wheel with the option to override the motor and push it by hand w/o damaging parts.
worse case id have to design a way to engage and disengage the motor with some mechanical arrangement
feedback greatly appreciated.
Thank you in advance
Post Edited (No) : 9/6/2009 8:56:41 PM GMT
Jax
If a robot has a screw then it must be romoved and hacked into..
Chris Savage
Parallax Engineering
50 72 6F 6A 65 63 74 20 53 69 74 65
Thanks Chris, lol im just noticing i didnt put a subject on there
