GearMotor, Electromechanical Clutches — Parallax Forums
NoNo Posts: 26
edited 2009-09-06 20:52 in Robotics
sup guys, i need some help. Im on the verge of getting a Banebot geared motor from robotshop.com for a two wheel project that im working on.·http://http://www.robotshop.ca/rbban31-banebots-spur-gearmotor.html
My question is : is anyone familiar with this geared motor? can it spin freely by hand if theres no voltage applied to it?
I know with the gearbox/motor arrangements·that i work with its almost impossible to turn a gearbox by hand.
Any good· sources out there for small (12vdc) electromechanical clutches?
What·i want to be able to do is mobilize this bot·with two dc motors at the·wheel with the option to override the motor and push it by hand w/o damaging parts.
worse case id have to design a way to engage and disengage the motor with some mechanical arrangement
feedback greatly appreciated.
Thank you in advance
Post Edited (No) : 9/6/2009 8:56:41 PM GMT
  • GWJaxGWJax Posts: 267
    edited 2009-09-04 01:44
    You can find the electrical clutches in small desk top laser based copiers "dry toner process" the larger copiers uses 24vdc for this purpose. We tend to toss out a lot of them when they start to slip and miss that uSec timing that is needed to keep the paper inline at all times. These clutches can be cleaned and work like brand new but we don't skimp out on our clients to save us a few dollars. So if you know or see a small laser printer or copier on the side of the road then bingo you have what you need and best of all it's FREE..Plus you'll start a great wealth of electronic sensors, parts, gears, chips, bases to cut out for your new creation and the list goes on..
    Jax
    If a robot has a screw then it must be romoved and hacked into..
    edited 2009-09-04 15:29
    You should edit your message using the pencil icon to the top right of the message and add a subject line so others will know what your message is about.
    Parallax Engineering
  • NoNo Posts: 26
    Thanx for the idea GW
    Thanks Chris, lol im just noticing i didnt put a subject on there
