Barcode Scanner - anyone know of an engine I can purchase — Parallax Forums
neotericneoteric Posts: 144
edited 2009-09-01 16:53 in Propeller 1
I intend to add a barcode scanner to a project I am working on. It needs to be laser. I searched Digikey and Mouser, and could not find a single component. I just spent a lot of time on google. I also searched the stamp forums here, but it looks like no-one has done this with a stamp?
I did find one from Honeywell, but it contains the scanner and the decoder board for $89. My hope was to find just the scanner part, and do my own decoder with the propeller, of course.
My hope is that someone else on this board knows of a small laser barcode scanner physical engine I could use in my project. Thanks in advance for the help.
    edited 2009-09-01 16:32
    It's not a laser scanner, but the Cue-Cat barcode scanner will work with a slight modification to the keyboard object on the Propeller (I have one and tested this).
    For a time, Radio shack was giving away The Cue-Cats with every purchase. It looks like the original company is no more, but you can still find a few readers on E-bay here and there.
    Reference:
    http://en.wikipedia.org/wiki/CueCat
    Beau Schwabe
    IC Layout Engineer
  • Agent420Agent420 Posts: 439
    I'm not sure you'll find just the laser module, and given the commodity nature of bc scanners these days I almost think an assembled unit will be near as cheap as the components.· But really they are just vibrating mirrors or line scanners with a photodiode to capture the reflection.
    You might consider eBay for a used one.· If you get a PS2 interface it will plug right in.
    I've got my share of CueCats too ;-)
    Post Edited (Agent420) : 9/1/2009 4:41:15 PM GMT
    I have 2 Symbol LS-1220 Serial Laser Scan Engines and they work quite nicely. I have a project in the backseat that will utilize them. Check eBay for "LS-1220", they are inexpensive, small, and very durable. Power is supplied on two unused pins on the DB-9 on the back. I can dig up the datasheets if you have trouble finding them.
    This guy has a few of them for $20
    cgi.ebay.com/Symbol-LS-1220-1200A-Miniscan-Barcode-Scanner_W0QQitemZ140274286346QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item20a8ffbf0a&_trksid=p3286.c0.m14
    Andrew Williams
    WBA Consulting
