Re-using main ram space
Off the wall thought from an offshoot trying to figure out the vga code pasm...
If I understand correctly, during boot up your entire code is transferred from eeprom to main ram.· Then if you launch some cogs containing pasm, the 512 long cog ram is transferred from main ram to the cog.·
At this point, with the cog running, could you potentially use the main ram space that held it's loading image as user ram for things like buffers or such?
Thanks.
James
