Re-using main ram space — Parallax Forums
Agent420Agent420 Posts: 439
edited 2009-09-01 16:10 in Propeller 1
Off the wall thought from an offshoot trying to figure out the vga code pasm...
If I understand correctly, during boot up your entire code is transferred from eeprom to main ram.· Then if you launch some cogs containing pasm, the 512 long cog ram is transferred from main ram to the cog.·
At this point, with the cog running, could you potentially use the main ram space that held it's loading image as user ram for things like buffers or such?
    edited 2009-09-01 15:56
    Yes you could.
  • Agent420Agent420 Posts: 439
    edited 2009-09-01 16:01
    Free ram ;-)
    Thanks.
  • JavalinJavalin Posts: 892
    in-fact the vga code does exactly that - it specifies a physical address for the buffer area's.
    James
    Javalin said...
    James
    I must be blind... where do you see that?
