It's not Arduino compatible but Bill Henning's Morpheus accepts plug-in expansion cards in the same way Arduino accepts shields, and it's a two-prop design.
There are currently three boards that stack on top of Morpheus:
Mem+ ...... adds 2MB of RAM, 16 bits parallel I/O, an RS232 programming/serial port, and an SD socket.
Propteus .... can be used as an add-on I/O processor with large prototyping area, servo headers and more (it can also work as a stand-alone development board) (Has access to Morpheus's EXP1, EXP2 and MORPHBUS (parallel bus with 24 bit addressing, 8 data bits))
Proteus .... a nice prototyping board for adding "stuff" to a Morpheus system (Has access to Morpheus's EXP1, EXP2 and MORPHBUS (parallel bus with 24 bit addressing, 8 data bits))
There will be more products coming for Morpheus before Xmas [noparse]:)[/noparse]
..... and even more next year.
See links in my .sig for more information, the downloads page has manuals on it.
James Michael Huselton said...
Localroger, thanks for the direction.
Please use mikronauts _at_ gmail _dot_ com to contact me off-forum, my PM is almost totally full Morpheus & Mem+dual Prop SBC w/ 512KB kit $119.95, 2MB memory IO board kit $89.95, both kits $189.95 www.mikronauts.com - my site 6.250MHz custom Crystals for running Propellers at 100MHz Las - Large model assembler for the Propeller Largos - a feature full nano operating system for the Propeller
One of the annoying things about the Arduino is the non-standard spacing of the headers- otherwise, you could whip up something that would take Arduino shields on top of the Protoboard. [noparse]:)[/noparse]
Since there doesn't appear to be such a beast yet, these may make great places to prototype one:
JMH
--Steve
Propeller Tools
Something like that?
I've put one prop in an altoids tin, good luck with 8.
@Ariba-lol
Not the fish.
sites.google.com/site/bitwinproject/
JMH
Hi James,
Perhaps you can do it using this method?
(8 props using a single eeprom and crystal)
http://forums.parallax.com/showthread.php?p=835128
They cost me US$20 each ($12.99+freight)
· Home of the MultiBladeProps: TriBladeProp, RamBlade, TwinBlade,·SixBlade, website
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80) , MoCog (6809)
Post Edited (Cluso99) : 8/31/2009 6:39:11 AM GMT
DIY Arduino Shield Kit
Arduino ProtoShield
or... stack a few Propellurinos, along with some sort of dummy board to provide power at the bottom! [noparse]:)[/noparse]
To get something with an identical board size and more than one Prop you'd be doing the kind of SMT work that a lot of hobbyists shy away from...
It was the 32K ram and vid that dragged me away, at least I might have become more "C" ish had I stayed.
Style and grace : Nil point
