16x2 Parallel LCD, Displays incorrect chars.
I just recieved my 16x2 LCD Parallel, and got the demo to show up correctly, but I am trying to display charecters I store in an array and they show asian charecters or something like that.
' File...... Parallel_LCD_2X16.bs2
' Purpose... Parallel LCD Display Demo
' Author.... Parallax, Inc.
' E-mail.... [url=mailto:support@parallax.com]support@parallax.com[/url]
' {$STAMP BS2}
' {$PBASIC 2.5}
' -----[noparse][[/noparse] Program Description ]---------------------------------------------
' This program demonstrates using a Hitachi-compatible Parallel LCD Display
' This code works with the BS2, BS2e and BS2sx
' -----[noparse][[/noparse] I/O Definitions ]-------------------------------------------------
E PIN 0 ' Enable Pin For LCD
RW PIN 2 ' R/W Pin For LCD
RS PIN 3 ' LCD Register Select
' 0 = Instruction, 1 = Text
' -----[noparse][[/noparse] Variables ]-------------------------------------------------------
char VAR Word ' Character To Send To LCD
time VAR Byte(5)
inst VAR char ' Induction To Send To LCD
index VAR Word ' Character Pointer
temp VAR Byte ' Temp Variable
gpstime VAR Word
' -----[noparse][[/noparse] EEPROM Data ]-----------------------------------------------------
'DO
SERIN 15,16572,[noparse][[/noparse]WAIT("RMC,"),DEC gpstime]
gpstime = gpstime
FOR temp = 0 TO 4
time(temp)= gpstime DIG temp
NEXT
'GOSUB Main
'GOSUB Initialize
'LOOP
'DATA "Goodbye, this is the LCD demo." ' Message To Send To LCD
' -----[noparse][[/noparse] Initialization ]--------------------------------------------------
Initialize:
LOW RW ' Set LCD To Write Mode
OUTS = %0000000000000000 ' Set All Output Low
DIRS = %0000000011111111 ' Set I/O Direction
GOSUB Init_Lcd ' Initialize The LCD Display
' -----[noparse][[/noparse] Program Code ]----------------------------------------------------
Main:
FOR temp = 0 TO 4 ' 28 Characters
char= time(temp)
DEBUG DEC time(temp) ' Read Next Character From EEPROM
GOSUB Send_Text ' Send Character To LCD Display
NEXT
RETURN
END
' -----[noparse][[/noparse] Subroutines ]-----------------------------------------------------
Init_Lcd:
OUTS = %00110000 ' Reset The LCD
PULSOUT E,1 ' Send Command Three Times
PAUSE 10
PULSOUT E,1
PAUSE 10
PULSOUT E,1
PAUSE 10
OUTS = %00100000 ' Set To 4-bit Operation
PULSOUT E,1
Inst = %00101000 ' Function Set (2-Line Mode)
GOSUB Send_Inst
Inst = %00001110 ' Turn On Cursor
GOSUB Send_Inst
Inst = %00000110 ' Set Auto-Increment
GOSUB Send_Inst
Inst = %00000001 ' Clears LCD
GOSUB Send_Inst
Inst = 14 ' Set Cursor To Underline
GOSUB Send_Inst
RETURN
Send_Inst:
LOW RS ' Set Instruction Mode
OUTB = Inst.HIGHNIB ' Send High Nibble
PULSOUT E,1
OUTB = Inst.LOWNIB ' Send Low Nibble
PULSOUT E,1
HIGH RS ' Set LCD Back To Text Mode
RETURN
Send_Text:
OUTB = Char.HIGHNIB ' Send High Nibble
PULSOUT E,1
OUTB = char.LOWNIB ' Send Low Nibble
PULSOUT E,1
RETURN
Next_Line:
Inst = 128+64 ' Move Cursor To Line 2
GOSUB Send_Inst
RETURN
What type of custom character are you trying to make?
Quit buying all those fixed voltage regulators, and·get an Adjustable Power Supply·for your projects!· Includes an LED testing terminal!
*-NEW-* SD Card Adapter·Now available!· Add extra memory to your next Propeller project with ease!
So when you have it display the data on the debug terminal, there isn't a problem?
Then, I define char from the demo code to be time(counter) where counter is a for-next from 0 to 4.
The result is pure Kingons.
DEBUG is your friend.
DEBUG gpstime···· ' ???
gpstime = gpstime ' ??
FOR temp = 0 TO 4
time(temp)= gpstime DIG temp '??
debug time(temp)
debug temp
NEXT
Or better yet lookup/·use ·STR qualifier to do the conversion bypassing the gpstime for loop
which is the problem.
SERIN 15,16572,[noparse]/noparse]WAIT("RMC,"),STR time\5[color=white]·[/color
Keep in mind that the time array still needs to be defined as (concecutive ) array.
Post Edited (vaclav_sal) : 8/30/2009 5:01:19 AM GMT
