16x2 Parallel LCD, Displays incorrect chars.
I just recieved my 16x2 LCD Parallel, and got the demo to show up correctly, but I am trying to display charecters I store in an array and they show asian charecters or something like that.
' ========================================================================= ' File...... Parallel_LCD_2X16.bs2 ' Purpose... Parallel LCD Display Demo ' Author.... Parallax, Inc. ' E-mail.... [url=mailto:support@parallax.com]support@parallax.com[/url] ' {$STAMP BS2} ' {$PBASIC 2.5} ' -----[noparse][[/noparse] Program Description ]--------------------------------------------- ' This program demonstrates using a Hitachi-compatible Parallel LCD Display ' This code works with the BS2, BS2e and BS2sx ' -----[noparse][[/noparse] I/O Definitions ]------------------------------------------------- E PIN 0 ' Enable Pin For LCD RW PIN 2 ' R/W Pin For LCD RS PIN 3 ' LCD Register Select ' 0 = Instruction, 1 = Text ' -----[noparse][[/noparse] Variables ]------------------------------------------------------- char VAR Word ' Character To Send To LCD time VAR Byte(5) inst VAR char ' Induction To Send To LCD index VAR Word ' Character Pointer temp VAR Byte ' Temp Variable gpstime VAR Word ' -----[noparse][[/noparse] EEPROM Data ]----------------------------------------------------- 'DO SERIN 15,16572,[noparse][[/noparse]WAIT("RMC,"),DEC gpstime] gpstime = gpstime FOR temp = 0 TO 4 time(temp)= gpstime DIG temp NEXT 'GOSUB Main 'GOSUB Initialize 'LOOP 'DATA "Goodbye, this is the LCD demo." ' Message To Send To LCD ' -----[noparse][[/noparse] Initialization ]-------------------------------------------------- Initialize: LOW RW ' Set LCD To Write Mode OUTS = %0000000000000000 ' Set All Output Low DIRS = %0000000011111111 ' Set I/O Direction GOSUB Init_Lcd ' Initialize The LCD Display ' -----[noparse][[/noparse] Program Code ]---------------------------------------------------- Main: FOR temp = 0 TO 4 ' 28 Characters char= time(temp) DEBUG DEC time(temp) ' Read Next Character From EEPROM GOSUB Send_Text ' Send Character To LCD Display NEXT RETURN END ' -----[noparse][[/noparse] Subroutines ]----------------------------------------------------- Init_Lcd: OUTS = %00110000 ' Reset The LCD PULSOUT E,1 ' Send Command Three Times PAUSE 10 PULSOUT E,1 PAUSE 10 PULSOUT E,1 PAUSE 10 OUTS = %00100000 ' Set To 4-bit Operation PULSOUT E,1 Inst = %00101000 ' Function Set (2-Line Mode) GOSUB Send_Inst Inst = %00001110 ' Turn On Cursor GOSUB Send_Inst Inst = %00000110 ' Set Auto-Increment GOSUB Send_Inst Inst = %00000001 ' Clears LCD GOSUB Send_Inst Inst = 14 ' Set Cursor To Underline GOSUB Send_Inst RETURN Send_Inst: LOW RS ' Set Instruction Mode OUTB = Inst.HIGHNIB ' Send High Nibble PULSOUT E,1 OUTB = Inst.LOWNIB ' Send Low Nibble PULSOUT E,1 HIGH RS ' Set LCD Back To Text Mode RETURN Send_Text: OUTB = Char.HIGHNIB ' Send High Nibble PULSOUT E,1 OUTB = char.LOWNIB ' Send Low Nibble PULSOUT E,1 RETURN Next_Line: Inst = 128+64 ' Move Cursor To Line 2 GOSUB Send_Inst RETURN
What type of custom character are you trying to make?
Quit buying all those fixed voltage regulators, and·get an Adjustable Power Supply·for your projects!· Includes an LED testing terminal!
*-NEW-* SD Card Adapter·Now available!· Add extra memory to your next Propeller project with ease!
So when you have it display the data on the debug terminal, there isn't a problem?
Then, I define char from the demo code to be time(counter) where counter is a for-next from 0 to 4.
The result is pure Kingons.
DEBUG is your friend.
DEBUG gpstime···· ' ???
gpstime = gpstime ' ??
FOR temp = 0 TO 4
time(temp)= gpstime DIG temp '??
debug time(temp)
debug temp
NEXT
Or better yet lookup/·use ·STR qualifier to do the conversion bypassing the gpstime for loop
which is the problem.
SERIN 15,16572,[noparse]/noparse]WAIT("RMC,"),STR time\5[color=white]·[/color
Keep in mind that the time array still needs to be defined as (concecutive ) array.
Post Edited (vaclav_sal) : 8/30/2009 5:01:19 AM GMT
