Say It Module GUI/Comm - not connecting.
xanatos
The GUI cannot see the Board of Education with the Say It module in it.· The response on connection attempts is:
"Could not detect device connected to "COM5".
The operation completed successfully"
If I start up the Stamp Editor V2.4.2 and Run > Identify on COM5 it sees the stamp just fine, and I can load code to it.· I quit the editor and retry the Say It GUI and get the same error message again.
I am running Windows XP SP3 on a Sony Vaio.· I have verified that no terminal windows or other serial-port hogging programs are running.· I have verified voltage and available current at the supply, and measured voltage actually at the Vss/Vdd pins; I have verified that the proper pin insertion exists on the BoE board's X1 header (looks exactly like the photo in the SI Module's PDF manual).· I have nothing else connected to the stamp (and remember that the Stamp Editor DOES see the stamp on COM5).· I have tried selecting the other listed COM ports (4 and 3) and get the same results.· I have cycled power to the board and quit/restarted the GUI.
I have exhausted all options I am aware of at the moment.· Has anyone on here successfully connected from a WinXP machine?
Lastly - if the USB to Serial converter I am using for the stamp editor works just fine there, is there any chance that it would not work on the Say It GUI for some reason?· Is there some difference in the communication protocol?
Thanks for any info - anxious to get the Say It module listening soon!
Dave
Dave
- Stephen
Thanks for any ideas.
Dave
Luckily you are only out of luck until Parallax is open on Monday - I know Tech Support can give you a hand.
You are probably right about most folks not having any experience with this - unless maybe Mike Green, PhiPi or Beau have played with it.
Whit+
Dave
I am experiencing the same connection issues (and error message) on a Windows Vista PC and Windows 7 PC.
I am also unable to make the Basic Stamp code work. It is as if the Stamp and/or PC is completely unaware of the Say It Module.
The red LED never comes on.
Has anyone been able to troubleshoot or workaround the issue?
Thanks.
BT
Post Edited (btshil2000) : 9/12/2009 2:58:58 AM GMT
Can you confirm which BASIC Stamp 2 you are using with the GUI?
Respectfully,
Joshua Donelson
www.parallax.com
Still travelling so I don't have my full compliment of hardware resources - but I do have the development environment with me! It's like American Express - I never leave home w/o it!
I have tried with both a regular BS2 and a BS2SX (and the demo code worked on both when loaded in with the stamp editor - and with the stamp-appropriate mods to the code) but the GUI works with neither. I also loaded the GUI on a second computer and obtained identical results.
I won't be able to do a lot of testing until I return from my travels, but I can do some simple stuff if you need, as I do have my USB2Ser cable, the dev board and power supply, and of course, my laptop.
Dave
Mike2545
This message sent to you on 100% recycled electrons.
Nothing yet.· I heard from a tech on this a few times, but I was travelling all over teh place and hadn't the real time or proper stuff to test any of the things he asked me to.· Basically the only thing I've heard from anyone is one guy who dug up some ancient old tower he had with a serial port card in it, and that worked.· Other than that, I know of at least three other folks who have been unable to get the programming GUI to work.· The unit DOES run the demo program which loads just fine with the Basic Stamp editor, but the GUI seems DOA from everything I've observed so far.· I'm really VERY surprised that this is happening - Parallax has always had some outstanding products that have worked (for me, anyway) FLAWLESSLY every time.· Let me know if you find anything.
Dave
' {$STAMP BS2} ' {$PBASIC 2.5} ' COM Parameters COM_RX PIN 0 ' rx pin COM_TX PIN 2 ' tx pin COM_SPEED CON 84 ' baud 9600 ' Protocol Command CMD_BREAK CON "b" ' abort recog or ping CMD_SLEEP CON "s" ' go to power down CMD_KNOB CON "k" ' set si knob <1> CMD_LEVEL CON "v" ' set sd level <1> CMD_LANGUAGE CON "l" ' set si language <1> CMD_TIMEOUT CON "o" ' set timeout <1> CMD_RECOG_SI CON "i" ' do si recog from ws <1> CMD_RECOG_SD CON "d" ' do sd recog at group <1> (0 = trigger mixed si/sd) ' Protocol Status STS_AWAKEN CON "w" ' back from power down mode STS_ERROR CON "e" ' signal error code <1-2> STS_INVALID CON "v" ' invalid command or argument STS_TIMEOUT CON "t" ' timeout expired STS_INTERR CON "i" ' back from aborted recognition (see 'break') STS_SUCCESS CON "o" ' no errors status STS_RESULT CON "r" ' recognised sd command <1> - training similar to sd <1> STS_SIMILAR CON "s" ' recognised si <1> (in mixed si/sd) - training similar to si <1> ' Protocol arguments are in the range 0x40 (-1) TO 0x60 (+31) inclusive ARG_MIN CON 64 ' 0x40 ARG_MAX CON 96 ' 0x60 ARG_ZERO CON 65 ' 0x41 ARG_ACK CON 32 ' 0x20 'TO READ more status arguments 'Groups and Commands '§G > '§G + GROUP_%2!-2d! CON %2!d! '(Command count: %3!d!) '§C > '§C + G%2!d!_%4!-32s! CON %5!d! '§C ^ %0 '§G ^ RES_ERROR CON 255 RES_TIMEOUT CON 254 RES_COMMFAIL CON 253 RES_BUILTIN CON 32 'Robot Constant VRLED PIN 4 'Global Variable VRA VAR Byte VRA1 VAR Byte VRGROUP VAR Byte VRCOMMAND VAR Byte ' Main Start Restart: LOW VRLED VRGROUP = 0 DEBUG CR, "Setting up VRbot... " 'Wake up or stop recognition GOSUB VR_Wakeup DEBUG "awake... " 'Set SI Language '§L : VRA1 = %1!d! GOSUB VR_SetLanguage DEBUG "language ", DEC VRA1, "... " 'Set 5 seconds timeout VRA1 = 5 GOSUB VR_SetTimeout DEBUG "timeout ", DEC VRA1, "... " DEBUG CR, "VRbot ready!" VR_Loop: DEBUG CR, "VRbot in group ", DEC VRGROUP, " waiting for command... " LOW VRLED PAUSE 150 IF VRGROUP > 0 THEN HIGH VRLED VRA1 = VRGROUP GOSUB VR_RecognizeSD '-- handle errors or timeout IF VRA1 = RES_ERROR THEN DEBUG "error" 'try again in the same group GOTO VR_Loop ENDIF IF VRA1 = RES_TIMEOUT THEN DEBUG "timed out" VRGROUP = 0 ' back to trigger GOTO VR_Loop ENDIF IF VRA1 = RES_COMMFAIL THEN DEBUG "comm failed" 'resync and try again GOSUB VR_Wakeup GOTO VR_Loop ENDIF '-- got a command VRCOMMAND = VRA1 IF VRCOMMAND <= RES_BUILTIN THEN GOSUB VR_Action GOTO VR_Loop VR_Action: DEBUG "got ", DEC VRCOMMAND '§G > SELECT VRGROUP '§G : '§G + CASE GROUP_%2!d! '§C > SELECT VRCOMMAND '§C + CASE G%2!d!_%4!s! '§C : PAUSE 0 '-- write your code here '§C ^ %0 '§G ^ ENDSELECT '§G > ENDSELECT RETURN '=== VR Routines === ' Wake up: VR_Wakeup: TOGGLE VRLED VRA = CMD_BREAK SEROUT COM_TX, COM_SPEED, [noparse][[/noparse]VRA] SERIN COM_RX, COM_SPEED, 1000, VR_Wakeup, [noparse][[/noparse]VRA] IF (VRA <> STS_SUCCESS) THEN GOTO VR_Wakeup LOW VRLED RETURN ' Inputs: ' VRA1 = language index (0 = english, ...) VR_SetLanguage: VRA = CMD_LANGUAGE SEROUT COM_TX, COM_SPEED, [noparse][[/noparse]VRA] VRA1 = VRA1 + ARG_ZERO SEROUT COM_TX, COM_SPEED, [noparse][[/noparse]VRA1] SERIN COM_RX, COM_SPEED, 200, VR_CommFailed, [noparse][[/noparse]VRA] VRA1 = VRA1 - ARG_ZERO 'IF (VRA <> STS_SUCCESS) THEN GOTO VR_Wakeup RETURN ' Inputs: ' VRA1 = timeout (in ms, 0=forever, 255=default) VR_SetTimeout: VRA = CMD_TIMEOUT SEROUT COM_TX, COM_SPEED, [noparse][[/noparse]VRA] VRA1 = VRA1 + ARG_ZERO SEROUT COM_TX, COM_SPEED, [noparse][[/noparse]VRA1] SERIN COM_RX, COM_SPEED, 200, VR_CommFailed, [noparse][[/noparse]VRA] VRA1 = VRA1 - ARG_ZERO 'IF (VRA <> STS_SUCCESS) THEN GOTO VR_Wakeup RETURN ' Inputs: ' VRA1 = SI knob (0=loosest, 2=normal, 4=tightest) VR_SetKnob: VRA = CMD_KNOB SEROUT COM_TX, COM_SPEED, [noparse][[/noparse]VRA] VRA1 = VRA1 + ARG_ZERO SEROUT COM_TX, COM_SPEED, [noparse][[/noparse]VRA1] SERIN COM_RX, COM_SPEED, 200, VR_CommFailed, [noparse][[/noparse]VRA] VRA1 = VRA1 - ARG_ZERO 'IF (VRA <> STS_SUCCESS) THEN GOTO VR_Wakeup RETURN ' Inputs: ' VRA1 = SD level (1=easy, 2=default, 5=hard) VR_SetLevel: VRA = CMD_LEVEL SEROUT COM_TX, COM_SPEED, [noparse][[/noparse]VRA] VRA1 = VRA1 + ARG_ZERO SEROUT COM_TX, COM_SPEED, [noparse][[/noparse]VRA1] SERIN COM_RX, COM_SPEED, 200, VR_CommFailed, [noparse][[/noparse]VRA] VRA1 = VRA1 - ARG_ZERO 'IF (VRA <> STS_SUCCESS) THEN GOTO VR_Wakeup RETURN ' Inputs: ' VRA1 = wordset (0=trigger) ' Ouputs: ' VRA1 = result (0-31=word, 32..=builtin, 253=comm err, 254=timeout, 255=error) VR_RecognizeSI: VRA = CMD_RECOG_SI GOTO VR_Recognize0 VR_RecognizeSD: VRA = CMD_RECOG_SD VR_Recognize0: SEROUT COM_TX, COM_SPEED, [noparse][[/noparse]VRA] ' send Group/WS VRA1 = VRA1 + ARG_ZERO SEROUT COM_TX, COM_SPEED, [noparse][[/noparse]VRA1] ' wait for answer SERIN COM_RX, COM_SPEED, 6000, VR_CommFailed, [noparse][[/noparse]VRA] IF VRA = STS_RESULT THEN ' send ack VRA = ARG_ACK SEROUT COM_TX, COM_SPEED, [noparse][[/noparse]VRA] ' wait for recognised command code SERIN COM_RX, COM_SPEED, 200, VR_CommFailed, [noparse][[/noparse]VRA1] VRA1 = VRA1 - ARG_ZERO ELSEIF VRA = STS_SIMILAR THEN ' send ack VRA = ARG_ACK SEROUT COM_TX, COM_SPEED, [noparse][[/noparse]VRA] ' wait for recognised command code SERIN COM_RX, COM_SPEED, 200, VR_CommFailed, [noparse][[/noparse]VRA1] VRA1 = VRA1 - ARG_ZERO + RES_BUILTIN ELSEIF VRA = STS_TIMEOUT THEN VRA1 = RES_TIMEOUT ELSE VRA1 = RES_ERROR ENDIF RETURN VR_CommFailed: VRA1 = RES_COMMFAIL RETURNIt gets to DEBUG CR, "Setting up VRbot... "
and flashes the LED on the Sat it module...any ideas??
Mike2545
Mike2545
Mike2545
Dave
I'm using the say it module and I had the same problem "could not enter control mode"...
I got a similar problem with the ultrasonic sensor because the debug terminal did not recogniced it.
Even I used other two laptops and the problem was the same.
I only changed the pin I was using and my ultrasonic sensor worked normally. So just by changing the pins I was using my say it module worked normally.
So I was wondering why these pins get "crazy" sometimes.
Note. I'm using the board of education and the BS2.
Angel Calder
