Say It Module GUI/Comm - not connecting.
The GUI cannot see the Board of Education with the Say It module in it.· The response on connection attempts is:
"Could not detect device connected to "COM5".
The operation completed successfully"
If I start up the Stamp Editor V2.4.2 and Run > Identify on COM5 it sees the stamp just fine, and I can load code to it.· I quit the editor and retry the Say It GUI and get the same error message again.
I am running Windows XP SP3 on a Sony Vaio.· I have verified that no terminal windows or other serial-port hogging programs are running.· I have verified voltage and available current at the supply, and measured voltage actually at the Vss/Vdd pins; I have verified that the proper pin insertion exists on the BoE board's X1 header (looks exactly like the photo in the SI Module's PDF manual).· I have nothing else connected to the stamp (and remember that the Stamp Editor DOES see the stamp on COM5).· I have tried selecting the other listed COM ports (4 and 3) and get the same results.· I have cycled power to the board and quit/restarted the GUI.
I have exhausted all options I am aware of at the moment.· Has anyone on here successfully connected from a WinXP machine?
Lastly - if the USB to Serial converter I am using for the stamp editor works just fine there, is there any chance that it would not work on the Say It GUI for some reason?· Is there some difference in the communication protocol?
Thanks for any info - anxious to get the Say It module listening soon!
Dave
Dave
- Stephen
Thanks for any ideas.
Dave
Luckily you are only out of luck until Parallax is open on Monday - I know Tech Support can give you a hand.
You are probably right about most folks not having any experience with this - unless maybe Mike Green, PhiPi or Beau have played with it.
Whit+
Dave
I am experiencing the same connection issues (and error message) on a Windows Vista PC and Windows 7 PC.
I am also unable to make the Basic Stamp code work. It is as if the Stamp and/or PC is completely unaware of the Say It Module.
The red LED never comes on.
Has anyone been able to troubleshoot or workaround the issue?
Thanks.
BT
Post Edited (btshil2000) : 9/12/2009 2:58:58 AM GMT
Can you confirm which BASIC Stamp 2 you are using with the GUI?
Respectfully,
Joshua Donelson
www.parallax.com
Still travelling so I don't have my full compliment of hardware resources - but I do have the development environment with me! It's like American Express - I never leave home w/o it!
I have tried with both a regular BS2 and a BS2SX (and the demo code worked on both when loaded in with the stamp editor - and with the stamp-appropriate mods to the code) but the GUI works with neither. I also loaded the GUI on a second computer and obtained identical results.
I won't be able to do a lot of testing until I return from my travels, but I can do some simple stuff if you need, as I do have my USB2Ser cable, the dev board and power supply, and of course, my laptop.
Dave
Mike2545
This message sent to you on 100% recycled electrons.
Nothing yet.· I heard from a tech on this a few times, but I was travelling all over teh place and hadn't the real time or proper stuff to test any of the things he asked me to.· Basically the only thing I've heard from anyone is one guy who dug up some ancient old tower he had with a serial port card in it, and that worked.· Other than that, I know of at least three other folks who have been unable to get the programming GUI to work.· The unit DOES run the demo program which loads just fine with the Basic Stamp editor, but the GUI seems DOA from everything I've observed so far.· I'm really VERY surprised that this is happening - Parallax has always had some outstanding products that have worked (for me, anyway) FLAWLESSLY every time.· Let me know if you find anything.
Dave
It gets to DEBUG CR, "Setting up VRbot... "
and flashes the LED on the Sat it module...any ideas??
Mike2545
Mike2545
Mike2545
Dave
I'm using the say it module and I had the same problem "could not enter control mode"...
I got a similar problem with the ultrasonic sensor because the debug terminal did not recogniced it.
Even I used other two laptops and the problem was the same.
I only changed the pin I was using and my ultrasonic sensor worked normally. So just by changing the pins I was using my say it module worked normally.
So I was wondering why these pins get "crazy" sometimes.
Note. I'm using the board of education and the BS2.
Angel Calder
