WiFly 802.11b or other wireless solutions for the Propeller?
Oldbitcollector (Jeff)
Has anyone worked with the WiFly stuff with the Propeller yet,
or other Wireless solutions for the Propeller?
OBC
New to the Propeller?
OBC
Purchasing a Lantronix Matchport this afternoon, guess I'll be the one to report. [noparse]:)[/noparse]
OBC
Beside this I have used Lantronix products. From the early feelings I see in Tibbo one gear more. They are not just usual serial over tcp but you can program them (basic) and preprocess data or manage ftp file transfers/ web server/ e-mail. Regarding the reliability I can not say nothing because I am not using it enough long. With Lantronix (XPort/XportAR)·I never had problems.
· Propeller Object Exchange (last Publications / Updates)
--Steve
Propeller Tools
Thanks, I knew it came up before, but I thought I'd see if there was any more current
input from the crowd on this one. [noparse]:)[/noparse]
OBC
I think I'm only one of many who use XBee with the prop. Or are you looking for 802.11b specific solutions?
Peter
I've been waiting for updates for a very long time from some forum members wifi results.
--Steve
Propeller Tools
$75 in small quantities. If you need higher security an AES version is available for a couple dollars more.
Russ
I HAVE ONE (2 actually) i have been waiting to post until i have had something remarkable. I love the device though. Extremely easy to use!! i love this device. I am using it to make my project communicate with a webserver out there, some where. Did i mention, easy to use? I have used the Digi ME WI and the lantronix. This only draws 160 mah when transmitting and when it isnt, it can sleep for a very long time on very little current. Chip antenna is great or you can use an external antenna, just specify in the command area. I have been working on a "driver" object for all the commands. Makes it really easy. It does WPA WEP, and others. (dont have the spec sheet in front of me) Also run it in adhoc and have wirless control of your project.
It's Only A Stupid Question If You Have Not Googled It First!!
On the other hand, it looks like the Matchport could connect to a "real" WiFi network, so you'd only need 1 of them to connect to your computer...
My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
OBC
Those SFE modules are quite easy to use - just an SPI interface. I've used them with PICs.
Leon
I have a WiFly module but hospital stays keep getting in the way.
Mike Green or OBC, I would like to send you one if you reciprocate with results.
JMH
BTW- Hospital stays are when i get to prop the most.· 14 hours a week in a hospital bed = my time [noparse]:)[/noparse]
