WiFly 802.11b or other wireless solutions for the Propeller? — Parallax Forums
edited 2009-08-28 00:58 in Propeller 1
Has anyone worked with the WiFly stuff with the Propeller yet,
or other Wireless solutions for the Propeller?
OBC
New to the Propeller?
    edited 2009-08-27 14:57
    Hmm.. Mostly uncharted territory.. (23 views, no comment)
    Purchasing a Lantronix Matchport this afternoon, guess I'll be the one to report. [noparse]:)[/noparse]
    OBC
  • dMajodMajo Posts: 862
    edited 2009-08-27 14:58
    Have a look at Tibbo programable modules. I have a EM1000 and I am reserching its potentials. Both the EM1000 and the new EM1206 have also a WiFi plug-on board. You can have wired and wireless connection at the same time. The WiFi module communicate with Tibbo platform over a spi interface. They states the WiFi is working only on Tibbo platform but I believe you can use it alone if you know the spi command protocol.
    Beside this I have used Lantronix products. From the early feelings I see in Tibbo one gear more. They are not just usual serial over tcp but you can program them (basic) and preprocess data or manage ftp file transfers/ web server/ e-mail. Regarding the reliability I can not say nothing because I am not using it enough long. With Lantronix (XPort/XportAR)·I never had problems.
    · Propeller Object Exchange (last Publications / Updates)
    edited 2009-08-27 15:01
    Oldbitcollector said...
    Take time, have a rest. The fury kills (specially the electricians) smilewinkgrin.gif
  • jazzedjazzed Posts: 11,803
    edited 2009-08-27 15:29
    Search for "wifi" ...
    --Steve
    Propeller Tools
    717 x 290 - 14K
    edited 2009-08-27 16:51
    People here still use that worthless forum search tool??? [noparse]:)[/noparse]
    Thanks, I knew it came up before, but I thought I'd see if there was any more current
    input from the crowd on this one. [noparse]:)[/noparse]
    OBC
  • pgbpsupgbpsu Posts: 460
    edited 2009-08-27 16:59
    OBC-
    I think I'm only one of many who use XBee with the prop. Or are you looking for 802.11b specific solutions?
    Peter
    edited 2009-08-27 17:02
    It's just as useful for me most of the time as google (which is just as much of a PITA when it returns 39000 hits).
    I've been waiting for updates for a very long time from some forum members wifi results.
    --Steve
    Propeller Tools
  • BigFootBigFoot Posts: 259
    edited 2009-08-27 17:24
    We are using the Lantronix Match Port, it does Ethernet / WiFly and will also bridge between the two. The modules are around
    $75 in small quantities. If you need higher security an AES version is available for a couple dollars more.
    Russ
  • Brian CarpenterBrian Carpenter Posts: 728
    edited 2009-08-27 17:43
    OBC,
    I HAVE ONE (2 actually) i have been waiting to post until i have had something remarkable. I love the device though. Extremely easy to use!! i love this device. I am using it to make my project communicate with a webserver out there, some where. Did i mention, easy to use? I have used the Digi ME WI and the lantronix. This only draws 160 mah when transmitting and when it isnt, it can sleep for a very long time on very little current. Chip antenna is great or you can use an external antenna, just specify in the command area. I have been working on a "driver" object for all the commands. Makes it really easy. It does WPA WEP, and others. (dont have the spec sheet in front of me) Also run it in adhoc and have wirless control of your project.
    It's Only A Stupid Question If You Have Not Googled It First!!
  • RaymanRayman Posts: 16,460
    edited 2009-08-27 18:04
    Those do look nice. But, the XBee looks a lot cheaper! If I'm reading it right you can do serial comms with 2 of either, but the Matchport is ~$80 and the XBee is ~$20. Factoring in that I'd want 2 of them, I think I'd go XBee...
    On the other hand, it looks like the Matchport could connect to a "real" WiFi network, so you'd only need 1 of them to connect to your computer...
  • LeonLeon Posts: 7,620
    edited 2009-08-27 18:06
    For low cost and short range wireless the Nordic RF nRF24L01+ or TI CC2500 chips are ideal.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
    edited 2009-08-27 18:40
    Brian Carpenter said...
    OBC,
    I HAVE ONE ...
    One of what?
    edited 2009-08-27 18:51
    Leon: The Nordic things at Sparkfun.com do look very easy to use... There's one with a chip antenna for just $19... Also comes in FOB and RFL controller packages..
    edited 2009-08-27 18:52
    It's 802.11 I'm after... Still working on my complete laptopless/wireless Propeller development setup.
    OBC
    edited 2009-08-27 19:05
    Rayman said...
    Those SFE modules are quite easy to use - just an SPI interface. I've used them with PICs.
    Leon
    edited 2009-08-27 21:50
    @DMajo i have the WiFly 802.11b/g
  • Mike HuseltonMike Huselton Posts: 746
    edited 2009-08-27 22:22
    I have been in the hospital for the past week.
    I have a WiFly module but hospital stays keep getting in the way.
    Mike Green or OBC, I would like to send you one if you reciprocate with results.
    JMH
    edited 2009-08-27 23:05
    @James- What results are you looking for? I can give you lots of info. What do you need?
    BTW- Hospital stays are when i get to prop the most.· 14 hours a week in a hospital bed = my time [noparse]:)[/noparse]
    James: Hope you're doing OK! I was in the hospital recently too, so I know it's no fun!
