Issue with SHT Humidity/Temperature sensor
I've got a problem with my SHT Humidity/Temp sensor, I accidentally left the board on for at least a day. I had to change out the battery·for a new one, and now when I'm recording values in Excel using PLX DAQ the temperature readings are reading very high. Example is over 100* Fahrenheit in a 70* (at most) room. The strange thing is, the values are slowly dropping over time, to the point where it's changing - 10 * every couple of hours. Do I have to leave it on and running so it slowly (very very slowly??) acclimates to the room temperature? I changed the sensor out with another one, and it's reading the same problem. Humidity measurements seem to be accurate, good response with contact against the palm of the hand and breath.
Seems to be a board problem? Anyone have any ideas? For now, I'm just going to leave it running and see if it stabilizes..
- Stephen
- Stephen
Try verifying your setup and other components.
Try running the sample code to see if you get the same readings in the debug window.
Verify your power to the SHT is within specs, 2.4-5.5v
Try reloading your code. I have never heard of EEProms getting corrupted due to brown out but you never know.....
Andrew Williams
WBA Consulting
Thanks for the help guys.
