Freebies Table(UPENE)
Some people got some LED display's that were not like the HC4LED but bigger. They say Spectradyne Inc. Display Board.
I hooked one up the same way the HC4LED is hooked up and it worked. Try it and have fun. Use Thomas Whatson's Driver.
The LED display boards on the freebie table were on there because they didn't have a datasheet, but what Bean didn't realize when he put the "firestarters" on there was that the displays where socketed! I realized this at the expo and grabbed about 5 on the way out. I just salvaged them here at home and have got the pinouts for them. The socketed ones are the ones with the big chip (DIP) out to the right of the display.
Computers are microcontrolled.
Robots are microcontrolled.
I am microcontrolled.
But you·can·call me micro.
If it's not Parallax then don't even bother.
I have changed my avatar so that I will no longer be confused with others who use generic avatars (and I'm more of a Prop head then a BS2 nut, anyway)
Bean.
Does that byte of memory hold "A", 65, $41 or %01000001 ?
Yes it does...
OBC
New to the Propeller?
Andrew Williams
WBA Consulting
Good Idea! When buying electronics lots I usually have a bunch of junk that I would love to give away!
P.S. Bean, do you still have some of those Palm Pilot keypads?
I don't know but it will be funny to see if it shows up again next year....
Then we could keep it more focused on stuff we use.
The post office is able to ship a box at a fixed rate.
All we would need to do is start a list of names/addresses and someone start a box along the list.
OBC
I propose, that we initiate a trend... whomever ends up with the grab bag at the Freebies table is free to use whatever is inside (of course), but is required to add something to the bag and make it available at the next Expo. Perhaps keep a list of what was added/used and include that list within the bag. The main rule is, ... you can't look inside the bag, unless you are the one that claims it for that Expo.
... could be fun!
Beau Schwabe
IC Layout Engineer
What electronics need - MORE POWER!!!!!!!
OBC
I asked what it did and he changed the subject, but then again maybe I am talking about a different board......
