Neat Instructable - Cheap DIY SD Card Breadboard Socket
Hey Everyone,
Check out this neat little Instructable project - http://www.instructables.com/id/Cheap-DIY-SD-card-breadboard-socket/
Whit+
Whit+
cool. thanks!
- Howard
Whit+
I have to admit that the easiest solution in my lab has been soldering the sockets directly
to the perf after a little pre-tinning. I keep five or six on hand now for the whatever
Propboard I build next.
OBC
New to the Propeller?
I use these $7 SD/MMC mini-boards from Futurelec, pretty nice for cheap.
One of those that seems so obvious and simple...after someone else has thought of it.
I will try that 2day 4sure
- Some mornings I wake up cranky.....but usually I just let him sleep in -
Chris Savage
Parallax Engineering
PG
http://mikronauts.com/2006/12/28/cheap-sd-socket/
Please use mikronauts _at_ gmail _dot_ com to contact me off-forum, my PM is almost totally full
Morpheus & Mem+dual Prop SBC w/ 512KB kit $119.95, 2MB memory IO board kit $89.95, both kits $189.95
www.mikronauts.com - my site 6.250MHz custom Crystals for running Propellers at 100MHz
Las - Large model assembler for the Propeller Largos - a feature full nano operating system for the Propeller
I don't think they actually soldered anything to the card. It appears that they used the headers in such a way that bent pins made a fairly reliable contact with the pads.
PG
The picture says it all (but the article backs it up too). There is no solder between the pins and the card pads. It doesn't matter if it's a microSD or full size SD card.
@Chris,
It is true it is not a socket - I just used the Instructable title.
By the way - I did not write the Instructable - I just thought some folks here might like to use this...
Whit+
Whit - I am going to use it --- tomorrow [noparse]:)[/noparse])
This is a GoODIE. Rather than pay $10USD shipping for a $3 part, my Propeller can now have an SDcard.
If you think about it, the same thing can be done with a USBmemory stick, but it is a tigher fit. At least I can buy USB sockets locally.
Ain't gadetry a wonderful thing?
aka G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
Now wouldn't that be nice...
Chris Savage
