Powering Stamp through power pins
Can 5 volts of power be supplied to the stamp on the board of educations through the servo power dock? Are there diodes or anything blocking it? I ask because my speed controller sends me 5 volts through and then i send a control signal down the signal wire.
Just be careful that the 5 volt is 'clean', because you won't be going through a regulator anymore...
http://www.parallax.com/Portals/0/Downloads/docs/prod/boards/BOE_USB_D_Schematic.pdf
---EDIT----
I think I am wrong.· It looks like the VDD pin is not used from the stamp, other then for a filter cap.· It looks like you will need to power the board with 6.5 volt and above.· Hopefully someone that has a board will be able to chime in and let you know forsure...
Post Edited (Joms) : 8/19/2009 9:50:20 PM GMT
No you would not. You can power the unit from the Vdd on pin 21 of the BASIC Stamp or Vin (pin 24) to power the BASIC Stamp 2; however the servo headers and the X3 header are powered by the voltage regulator at the top of the board.
I hope this helps
Respectfully,
Joshua Donelson
www.parallax.com
