This speeds up the compilation process. Edit the spin in the Prop tool or notepad. Save the file. Run z.bat. Double click on the 'load eeprom'
Shut down the prop tool. Run the terminal program.
2) One nifty thing about the zicog is debugging. I have DRIVE__I.DSK added to the list
#else
FindDriveBase(0, string("DRIVE__A.DSK")) 'set the SD card drive base(s) CPM2.2
FindDriveBase(1, string("DRIVE__B.DSK")) 'set the SD card drive base(s)
FindDriveBase(2, string("DRIVE__C.DSK")) 'set the SD card drive base(s)
FindDriveBase(3, string("DRIVE__D.DSK")) 'set the SD card drive base(s)
FindDriveBase(4, string("DRIVE__E.DSK")) 'set the SD card drive base(s)
FindDriveBase(5, string("DRIVE__F.DSK")) 'set the SD card drive base(s)
FindDriveBase(6, string("DRVCPM_2.DSK")) 'set the SD card drive base(s) CPM2.2
FindDriveBase(7, string("DRVCPM_3.DSK")) 'set the SD card drive base(s) CPM3
FindDriveBase(8, string("DRIVE__I.DSK")) 'set the SD card drive base(s) 8MB #endif
Then add some debugging capture to the ports that don't exist yet (two new lines near the bottom to print the port and the byte)
'Handle Z80 IO port readscase io_port
srport: 'Altair front panel switches register
in_srport
simhport: 'SIMH control port
in_simhport
constat: 'Console status port.
in_constat
condata: 'Console data port
in_condata
statin: 'Altair disk status port
in_statin
secpos: 'Altair disk sector position port
in_secpos
dskread: 'Altair disk read port
in_dskread
n8vem_uart_test: ' test port $6D
in_test_n8vem ' is a byte ready returns 0 for no byte, 1 for a byte
n8vem_uart_in: ' ask for input from port $68
in_uart_n8vem ' get the byte#ifdef hdskenable
hdskport:
in_hdskport 'SIMH style hard disk port#endifother:
UART.transmitCharacters(string("Read from unimplemented I/O Port &H"))
printhex(io_port)
UART.transmitCharacters(string(" with byte &H"))
printhex(io_data)
UART.transmitCharacters(string(13,10))
io_data := 0
io_command := 0
and
PRIon_output'Handle Z80 IO port writescase io_port
ledport: 'An 8 bit parallel output with LEDs attached
out_ledport
out_simhport
out_condata
out_constat
punstat:
out_punstat 'Punch control port
selout: 'Altair disk controller select port
out_selout
dskcon: 'Altair disk function port
out_dskcon
dskwrit: 'Altair disk write port
out_dskwrit
n8vem_uart_out: ' &H68
out_n8vem_byte
#ifdef hdskenable
hdskport:
out_hdskport 'SIMH style hard disk port#endifother:
UART.transmitCharacters(string("Write to unimplemented I/O Port &H"))
printhex(io_port) ' print the port number for debugging
printhex(io_data)
io_command := 0'Set flag ready for next io
And now try to get into drive I. It prints out the following:
Write to unimplemented I/O Port &HFD with byte &H02
Write to unimplemented I/O Port &HFD with byte &H00
Write to unimplemented I/O Port &HFD with byte &H06
Write to unimplemented I/O Port &HFD with byte &H39
Write to unimplemented I/O Port &HFD with byte &HF7
Read from unimplemented I/O Port &HFD with byte &HF7
Write to unimplemented I/O Port &HFD with byte &H01
etc
Then tried uncommenting this line
#define hdskenable 'Uncomment for hard disk support
and added this line
PRI in_hdskport_read | r
'Handle read from hdskport during a disk read command'This read triggers the actual disk sector transfere'and must return an error code.'N.B. sectors are mapped to blocks 1 to 1
UART.transmitCharacters(string("hdisk read "))
and it then gets to hdisk read.
But further down
PRIin_hdskport_write'Handle read from hdskport during a disk write command'This read triggers the actual disk sector transfere'and must return an error code.'N.B. sectors are mapped to blocks 1 to 1if hdsk_check_dts 'Check drive, track and sector are sane
io_data := $FF'Return error if notreturn#ifdef TriBladeProp'???#else
Not sure what the '??? means, at this point I'm stuck. Any help would be most appreciated.
Sorry James... this is over to heater as I didn't know what to do.
But, do we really require hard disks (hence code complexity) if we can up the floppies size to 8MB (or indeed 32MB if we up the sectorsize to 512B)??? There is really no difference between floppies and hard drives as they are all being emulated on the one SD card anyway. That was one objective in choosing the fixed size of 32MB. So 8x32MB=256MB which should be fine for CPM, and remember, we can always add a routine to remount (remap) a floppy to a different file anyway.
Next thing James is to get the bst compiler running - no code changes required. It has the editor and downloader inbuilt plus a teminal program to boot! However, I cannot get bst to recognise my USB port under Vista. It will archive everything too. If you have an issue with the font, download and install the latest PropTool 1.2.6 which fixes it.
I have been looking at the SD drivers this afternoon.
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ Links to other interesting threads:
Ah, so floppies can go to 8mb? How do you do that? I'm getting only 984k (see at the bottom) - is that right?
A>dirx
Name Ext Bytes Name Ext Bytes Name Ext Bytes Name Ext Bytes
ASM COM 8K ! EXZ80ALLCOM 12K ! SBASIC COM 26K ! UNERA COM 2K
BASICLIBREL42K ! EXZ80DOCCOM 12K ! SHOWSEC COM 4K ! UNLOAD COM 2K
BOOT COM 2K ! FORMAT COM 2K ! SID COM 8K ! USERLIB REL 2K
BOOTGEN COM 2K ! HALT COM 2K ! SPEED COM 2K ! USQ COM 2K
CCPZ TXT 40K ! HDIR COM 2K ! STAT COM 6K ! W COM 4K
CONIN ASM 2K ! L80 COM 12K ! SUBMIT COM 2K ! WS COM 8K
COPY COM 2K ! LOAD COM 2K ! SUPERSUBCOM 4K ! WS OVR 52K
CPU COM 2K ! M80 COM 20K ! SURVEY COM 2K ! WSMSGS OVR 14K
DD TXT 2K ! MBASIC COM 24K ! SYSCOPY COM 2K ! XFORMAT COM 4K
DDT COM 6K ! NEW BAS 2K ! SYSCPM2 SUB 2K ! XMODEMP COM 4K
DDTZ COM 10K ! NEW COM 4K ! SYSCPM2ZSUB 2K ! XMODEMQ COM 4K
DIR TXT 2K ! OVERLAYBCOM 8K ! TEST BAK 2K ! XSUB COM 2K
DIRX COM 4K ! PACMAN95COM 18K ! TEST TXT 2K ! ZASM SUB 2K
DUMP COM 2K ! PIP COM 8K ! TIMER COM 2K ! ZSID COM 10K
ED COM 8K ! R COM 4K ! TS SUB 2K ! ZTRAN4 COM 4K
EX8080 COM 12K ! RSETSIMHCOM 2K ! UNCR COM 8K
63 File(s), occupying 472K of 984K total capacity
182 directory entries and 512K bytes remain on A:
A>
Dr_A: Your hard disk investigations look good so far. I will try very hard to have a few hours free to help with this this evening (7 hours away here)
I have to remind myself how it was all supposed to work!
Cluso: I think we should stick to the idea of having the 8 SIMH compatible floppy disks and up to 4 SIMH compatible hard disks. Because then:
1) We don't need to create and maintain a customized BIOS to create new sizes of floppy disks
2) All disks can be compatible with SIMH, just drop them into ZiCog and they work.
3) The SIMH hard drives use DMA rather than fetching individual bytes. Should be faster. Floppies do not unless we change the BIOS (See 1)
4) The SIMH style hard drives can be customised (size, geometry) on the fly in Spin with no CP/M BIOS hacking. Just change the disk parameter table.
5) RAM disk should be hard drives and use the disk parameter table for definition.
6) All the code is in place already and most of it has been shown to work already.
Think that's about it[noparse]:)[/noparse]
Dr_A: Making the floppies bigger requires changes to the CBIOSX.
I'd rather not get into that. I'd like to be able to run all the SIMH CP/M with no or as few changes as possible.
James: I think that size comes from the floppy size on the SIMH disk. You could try a format of one of the blank drives an see what that gives (I have done this before).
Heater: OK sounds great. We should therefore set the sector size to 512Bytes. Does 4x32MB drives sound good or do you want them bigger ??
Yes, for hard disks sector size should match the SD block size to make best use of the SD card and the virtual DMA for speed.
If I remember correctly 32M is the limit for CP/M 2 but we can go much bigger for CP/M 3.
What I have been fishing for is a CP/M guru is knows how to tweak the disk parameter tables to do this.
Not to mention suitable params for a RAM disk.
If we can't find a guru it's back to studying the CP/M customization manuals....
I tried creating a blank 32mb file (=8mb drive) which makes DRIVE__Z.CPM in the vb6 program and then renamed it DRIVE__B.DSK
but it still comes up as less than a mb.
Attached is the little DIRX program as this gives the space used and the space left and the directory. Sort of a combination of stat and dir
Then I read heaters comment. Does that mean drives A-H are 1mb and I, J, K L are 8mb each?
I see a parameter in the spin code that limits the number of drives to 8 - is that relevant?
'The following taken from SIMH Altair simulator CBIOSX.MAC
ndisks = 8 ' total number of Altair disks
The N8VEM parameter blocks seem different - not sure if this will be relevant or not but these are the parameter blocks for the 448k ram disk
1mb rom disk, 8mb hard disk and a 1mb hard disk. But perhaps stick with the simh ones
DPBLK0: ; DISK PARAMETER BLOCK (ROMDISK 32KB WITH162K TRACKS, 22K usable)
SPT_0: .DW 16 ; 16 SECTORS OF128 BYTES PER 2K TRACK
BSH_0: .DB 3 ; BLOCK SHIFT FACTOR (SIZE OF ALLOCATION BLOCK)
BLM_0: .DB 7 ; PART OF THE ALLOCATION BLOCK SIZE MATH
EXM_0: .DB 0 ; DEFINES SIZE OF EXTENT (DIRECTORY INFO)
DSM_0: .DW 31 ; BLOCKSIZE [noparse][[/noparse]1024] * NUMBER OF BLOCKS + 1 = DRIVE SIZE
DRM_0: .DW 31 ; NUMBER OF DIRECTORY ENTRIES
AL0_0: .DB 10000000 ; BIT MAP OF SPACE ALLOCATED TO DIRECTORY
AL1_0: .DB 00000000 ; DIRECTORY CAN HAVE UP TO16 BLOCKS ALLOCATED
CKS_0: .DW 0 ; SIZE OF DIRECTORY CHECK [noparse][[/noparse]0IF NON REMOVEABLE]
OFF_0: .DW 5 ; FIRST 5 TRACKS TRACKS RESERVED (10K FOR SYSTEM)
; SYSTEM IS ROM LOADER, CCP, BDOS, CBIOS, AND MONITOR
; IMPORTANT NOTE: TRACKS $00 - $04OF2K BYTES
; EACH ARE MARKED WITH THE OFF_0 SETTO5AS
; SYSTEM TRACKS. USABLE ROM DRIVE SPACE
; STARTING AFTER THE FIFTH TRACK (IE, TRACK $05)
; MOST LIKELY FIX TO THIS IS PLACING A DUMMY
; FIRST 10K ROM CONTAINS THE ROM LOADER, MONITOR,
; CCP, BDOS, BIOS, ETC (5 TRACKS * 2K EACH)
DPBLK1: ; DISK PARAMETER BLOCK (RAMDISK 512K, 448K usable)
SPT_1: .DW 256 ; 256 SECTORS OF128 BYTES PER 32K TRACK
BSH_1: .DB 4 ; BLOCK SHIFT FACTOR (SIZE OF ALLOCATION BLOCK)
BLM_1: .DB 15 ; PART OF THE ALLOCATION BLOCK SIZE MATH
EXM_1: .DB 1 ; DEFINES SIZE OF EXTENT (DIRECTORY INFO)
DSM_1: .DW 225 ; BLOCKSIZE [noparse][[/noparse]2048] * NUMBER OF BLOCKS + 1 = DRIVE SIZE
DRM_1: .DW 255 ; NUMBER OF DIRECTORY ENTRIES
AL0_1: .DB 11110000 ; BIT MAP OF SPACE ALLOCATED TO DIRECTORY
AL1_1: .DB 00000000 ; DIRECTORY CAN HAVE UP TO16 BLOCKS ALLOCATED
CKS_1: .DW 0 ; SIZE OF DIRECTORY CHECK [noparse][[/noparse]0IF NON REMOVEABLE]
OFF_1: .DW 1 ; 1 TRACK RESERVED [noparse][[/noparse]FIRST 32K OF RAM]
DPBLK2: ; DISK PARAMETER BLOCK (IDE HARD DISK 8MB)
SPT_2: .DW 256 ; 256 SECTORS OF128 BYTES PER 32K TRACK
BSH_2: .DB 5 ; BLOCK SHIFT FACTOR (SIZE OF ALLOCATION BLOCK)
BLM_2: .DB 31 ; PART OF THE ALLOCATION BLOCK SIZE MATH
EXM_2: .DB 1 ; DEFINES SIZE OF EXTENT (DIRECTORY INFO)
DSM_2: .DW 2017 ; BLOCKSIZE [noparse][[/noparse]4096] * NUMBER OF BLOCKS + 1 = DRIVE SIZE
; HD PARTITION 2IS16128 SECTORS LONG
; AT 512 BYTES EACH WHICH IS
; 2016 BLOCKS AT 4096 BYTES A PIECE.
DRM_2: .DW 511 ; NUMBER OF DIRECTORY ENTRIES
AL0_2: .DB 11110000 ; BIT MAP OF SPACE ALLOCATED TO DIRECTORY
AL1_2: .DB 00000000 ; DIRECTORY CAN HAVE UP TO16 BLOCKS ALLOCATED
CKS_2: .DW 0 ; SIZE OF DIRECTORY CHECK [noparse][[/noparse]0IF NON REMOVEABLE]
OFF_2: .DW 1 ; 1 TRACK (32K) RESERVED FOR SYSTEM
DPBLK3: ; DISK PARAMETER BLOCK (IDE HARD DISK 8MB)
SPT_3: .DW 256 ; 256 SECTORS OF128 BYTES PER 32K TRACK
BSH_3: .DB 5 ; BLOCK SHIFT FACTOR (SIZE OF ALLOCATION BLOCK)
BLM_3: .DB 31 ; PART OF THE ALLOCATION BLOCK SIZE MATH
EXM_3: .DB 1 ; DEFINES SIZE OF EXTENT (DIRECTORY INFO)
DSM_3: .DW 2017 ; BLOCKSIZE [noparse][[/noparse]4096] * NUMBER OF BLOCKS + 1 = DRIVE SIZE
; HD PARTITION 3IS16128 SECTORS LONG
DRM_3: .DW 511 ; NUMBER OF DIRECTORY ENTRIES
AL0_3: .DB 11110000 ; BIT MAP OF SPACE ALLOCATED TO DIRECTORY
AL1_3: .DB 00000000 ; DIRECTORY CAN HAVE UP TO16 BLOCKS ALLOCATED
CKS_3: .DW 0 ; SIZE OF DIRECTORY CHECK [noparse][[/noparse]0IF NON REMOVEABLE]
OFF_3: .DW 1 ; 1 TRACK (32K) RESERVED FOR SYSTEM
DPBLK4: ; DISK PARAMETER BLOCK (IDE HARD DISK 1024K)
SPT_4: .DW 256 ; 256 SECTORS OF128 BYTES PER 32K TRACK
BSH_4: .DB 4 ; BLOCK SHIFT FACTOR (SIZE OF ALLOCATION BLOCK)
BLM_4: .DB 15 ; PART OF THE ALLOCATION BLOCK SIZE MATH
EXM_4: .DB 0 ; DEFINES SIZE OF EXTENT (DIRECTORY INFO)
DSM_4: .DW 497 ; BLOCKSIZE [noparse][[/noparse]2048] * NUMBER OF BLOCKS + 1 = DRIVE SIZE
; HD PARTITION 4IS4032 SECTORS LONG
; 1008 BLOCKS AT 2048 BYTES A PIECE.
; NOTUSING ALL OF THE AVAILABLE SECTORS SINCE THIS
; DRIVE IS INTENDED TO EMULATE A ROM DRIVE AND COPIED
; INTO A ROM IN THE FUTURE.
DRM_4: .DW 255 ; NUMBER OF DIRECTORY ENTRIES
AL0_4: .DB 11110000 ; BIT MAP OF SPACE ALLOCATED TO DIRECTORY
AL1_4: .DB 00000000 ; DIRECTORY CAN HAVE UP TO16 BLOCKS ALLOCATED
CKS_4: .DW 0 ; SIZE OF DIRECTORY CHECK [noparse][[/noparse]0IF NON REMOVEABLE]
OFF_4: .DW 1 ; 1 TRACK RESERVED [noparse][[/noparse]FIRST 32K OF PARTITION]
This is my altair simh 'super cp/m computer' that I use for testing. Seems the same one as for the zicog. Drive I is correctly reporting 8mb with dirx. Just need to find the block parameters and port that over to the zicog??
d tracks[noparse][[/noparse]0-7] 254attach dsk cpm2.dsk
attach dsk1 basic.dsk
attach dsk2 games.dsk
attach dsk3 sbasic.dsk
attach dsk4 supercalc.dsk
attach dsk5 tools.dsk
attach dsk6 wordstar.dsk
attach hdsk i.dsk
set cpu 64k
set cpu noitrap
set cpu z80set cpu altairrom
set cpu nonbanked
reset cpu
set sio ansi
set sio nosleep
boot dsk
bye
and a printout of it running:
C:\N8VEM\AltairSIMH>altairz80allAltair8800 (Z80) simulator V3.7-3 build 1016 (scp created Apr 202008 at 13:01:
09 with gcc 4.2.3)
64K CP/M Version 2.2 (SIMH ALTAIR 8800, BIOS V1.25, 2 HD, 15-Jan-07)
A>dirx
ASM COM 8K ! EXZ80DOCCOM 12K ! SID COM 8K ! UNLOAD COM 2K
BOOT COM 2K ! FORMAT COM 2K ! SPEED COM 2K ! USQ COM 2K
BOOTGEN COM 2K ! HALT COM 2K ! STAT COM 6K ! W COM 4K
CCPZ TXT 40K ! HDIR COM 2K ! SUBMIT COM 2K ! WS COM 8K
COPY COM 2K ! L80 COM 12K ! SUPERSUBCOM 4K ! WS OVR 52K
CPU COM 2K ! LOAD COM 2K ! SURVEY COM 2K ! WSMSGS OVR 14K
DDT COM 6K ! M80 COM 20K ! SYSCOPY COM 2K ! XFORMAT COM 4K
DDTZ COM 10K ! MBASIC COM 24K ! SYSCPM2 SUB 2K ! XSUB COM 2K
DIRX COM 4K ! PACMAN95COM 18K ! SYSCPM2ZSUB 2K ! ZASM SUB 2K
EXZ80ALLCOM12K ! SHOWSEC COM 4K ! UNERA COM 2K
50 File(s), occupying 370K of 984K total capacity
198 directory entries and 614K bytes remain on A:
A>i:
I>dirx
CP409DOCARK68K ! K1KERM11LBR 16K ! ZORK1 COM 12K ! ZORK2 DAT 92K
CP411HEXARK156K ! LU COM 20K ! ZORK1 DAT 84K ! ZORK3 COM 12K
CP411SRCARK436K ! UNARC COM 8K ! ZORK2 COM 12K ! ZORK3 DAT 92K
12 File(s), occupying 1008K of 8136K total capacity
987 directory entries and 7128K bytes remain on I:
I>
I think 32Mb hard drives will be fine at least for now, perhaps forever,
we don't have to hack any CP/M driver parameters to do that.
We already discussed the "Virtual DMA" for hard drives, as usual I will have to try to remind my self of what we concluded[noparse]:)[/noparse]
Thing is for floppy drives each byte in/out goes through a Z80 IN/OUT opcode emulation and hence through all the
Spin code that traps and performs that so even when the the complete sector buffer is sitting in HUB (which it is anyway) that is a lot of overhead.
I would think that there must be away to blit the entire sector buffer from HUB to CP/M space in external RAM in one hit whilst the actual Z80 emulation is
stopped waiting for completion. In fact I though you had already attempted to do that. I will have to look again.
Dr_A:
We can't just make the floppies bigger with bigger image files. The floppy geometry is fixed in the CBIOS.
The SIMHH BIOS can be built with a configurable number of floppies, can save CP/M memory by using fewer. Max is 8 so that is what is in the Spin emulation.
For drive I and up SIMH has totally different driver code in the BIOS. For floppies it is Altair floppy compatible. For hard drives it has variable size/geometry disks
where the geometry descriptor blocks are fetched by the CBIOS from the hd emulator at run time. So to change hd disk size/geometry it is a Spin cnage
When you say "Drive I is correctly reporting 8mb with dirx. Just need to find the block parameters and port that over to the zicog?? "
That is correct and it is ALREADY in the ZiCog spin code.
Don't forget I have been aiming for SIMH compatibility all along.
I try and have more time for this later today.
James: Here is v094. Could you please check it before I post at the top of this thread.(it is untested)
You will need to uncomment the·#define CPU_Z80 line in ZiCog009_rr090 (bst would not otherwise zip the project).
I have added· #define·addLF which outputs a LF following CR in·the FDX object (new mode).
If all is ok, please uncomment the 4·lines from ZiCog009_demo_rr094 before the #endif as shown (careful of indents)
PRIWriteSRAMblock | i, r, mask, in
r := tbp2.start
check_error(r)
#ifdef diskboot'clears ram $0000-$EFFF, loads $FF00-$FFFF, loads sram disk above'remember we are reading 8KB blocks, so clear the seven blocks and 8KB-128B of eighth blockif blockno < 8'TV.dec(blockno)if blockno == 7repeat i from0to count-1 -(256) 'clear below $FF00
buff[noparse][[/noparse]i] := 0'clear the bufferelserepeat i from0to count-1
buff[noparse][[/noparse]i] := 0'clear the bufferif blockno == 0
buff[noparse][[/noparse]0] := $C3'force jmp to $FF00 (faster)
buff[noparse][[/noparse]1] := $00
buff[noparse][[/noparse]2] := $FF#endif
This should improve the boot speed - causes a direct jump to the disk boot code $FF00
More experiments, random key presses eventually brings up the A> prompt but none of the characters are echoed.
More more experiments, going back to the serial object v002, that gets to the A prompt but the characters on the keyboard are coming back as different characters eg i came back as a u.
James: Should just have been a tidyup. Have you #define hdskenable uncommented? Hard disk is not working on the TriBlade yet - this could be getting into an incorrectly handled error.·Did you have Drive I enabled?
There are a few extra lines·you put in for debugging.
Do you have WinDiff ?
Ah, not quite cluso. The whole reseaon I used 256 byte buffers is to exploit the fact that a while using a byte head and tail pointer they have automatic wrap arround.
return ((inputHead - inputTail) & $FF)
Is actually the simpliest way to calculate amount of stuff in the FIFO buffer. Great ain't it? It's also more usefull than just know if there is stuff or isn't stuff because it allows you to know the amount in the buffer.
Well, unless anyone has any results on my driver working now or not I'll be moving on to other things.
Cluso99 said...
James: It was a 5 second mod to add the call names like Kye's. You are reading way too much complexity into all this
Granted that Kye's code let you look for the actual problem.
Kye: Thanks for your code - it helped solve the real bug of dropping characters.
I think there is a bug in the·rxavail call.
PUB rxavail '' 3 Stack Longs
'' │ Returns the number of characters in the receiver buffer. │
·Should be...
PUB rxavail '' 3??? Stack Longs
if inputHead >= inputTail
else
return ((inputHead + $FF - inputTail)) & $FF)
Is it necessary to know the number of received characters in the buffer? If not, then this may be simpler..
PUBrxavail : truefalse'' Check if byte(s) available'' returns true (-1) if bytes available
truefalse := rx_tail <> rx_head
BTW can you use a constant to define the length of the buffers like I did with the recent posting of the modified FDX for James·(also pasm needs to use the constant also)
CONbufsiz = 256 '16 'buffer size (16, 32, 64, 128, 256, 512) must be factor of 2, max is 512bufmsk = bufsiz - 1 'buffer mask used for wrap-around ($00F, $01F, $03F, $07F, $0FF, $1FF)
VARbyte rx_buffer[noparse][[/noparse]bufsiz] 'transmit and receive buffersbyte tx_buffer[noparse][[/noparse]bufsiz]
rx_tail := (rx_tail + 1) & bufmsk 'example of use
Kye, we should probably continue this under your SerialEngine post as there may be input from others. I also have some other ideas for you.
Kye: I am quite familiar with the wrap-around technique. I suggested using a constant so that the buffer size can be changed easily, instead of looking for all the hard-coded literals.
Now, won't ((inputHead - inputTail) & $FF) give an incorrect result when the inputHead is near the beginning of the buffer and inputTail is near the end of the buffer? That is, the inputHead has just wrapped around to the beginning. In this instance you will get a negative answer and you cannot just·& of the upper bits?? That is why I checked for this condition and added the buffer length to it to get the correct length - Ah, but I should have added $100 (bufsiz), not $FF (bufmsk) !!
Just thinking about it, you should call it rxcount or rxnumber (like you did before)·as rxavail tends to imply a true/false answer.
Heater & Dr_Acula: For testing the hard disk, if we change the hard disk parameters to be the same as a floppy we can substitute a floppy file for initial testing. Once running we can adjust the size.
@Kye: My apologies - there is no bug in your ReceiveNumber code (called rxnum below).
Currently lacking hardware at the moment, I was not able to see my flaw. Since I had to go through examples to prove it,·I thought I would post what I did for others to see... The cyclic buffer method is used in other·code such as FullDuplexSerial.
Here is an example. Lets say for simplicity, the buffer is 256 bytes in length and begins at hub $1000.
Head points to the relative position in the buffer where the next byte will be stored. Tail points to the relative position in the buffer where the last character was obtained from. When head == tail there is no data available in the buffer. Head increments each time a byte is placed into the buffer and Tail increments when a byte is taken from the buffer. Both wrap-around at the end of the buffer to the beginning of the buffer by ANDING the result with the buffer length - 1. A 256 byte buffer is ANDED with $FF. If more bytes than the buffer length are added into the buffer before they are taken, then depending on the code, either a block of bytes are lost (equal to the buffer size and the oldest) or the new bytes are lost until space is available.
When empty the head and tail point to 0 (which is $1000 + 0). Fine.
When 10 bytes have been input, the header = 10 and tail = 0. rxnum = (head - tail) & $FF·= (10 - 0) & $FF·= 10. So correct.
When 257 bytes have been input and 254 bytes taken, header = (0 + 257) & $FF = 01, tail = (0 + 254) & $FF = 254
So rxnum = head - tail = (1 - 254)· & $FF = -253 & $FF = $FFFF_FF03 & $FF = 3. So you are correct and my apologies.
Note: 10 = $0A, 254 = $FE, 257 = $101.
@OBC: You are welcome to add·this to your Tips and Traps :-)
Good and bad news.
Ok, good news is that the past post by Cluso works and I think we are now getting back to a common file between us!
Even better news, the bst compiler doesn't give any warnings. (suggestion, maybe include bst.bat and bstc.exe in the package - only adds a tiny bit to the storage on the forum)
The bad news is that the carriage return/line feed is still a muddle. It went from overprinting with no line feeds to now putting in two line feeds!
I found the reason - not in the main program but in the fullduplexserial object.
I think I can see the reason you have put it there, because CP/M outputs CRLF after each line and I think the terminal program you are using treats CR as if it is CRLF. Or something like that - I'm not sure why you are not getting double spacing either.
Anyway, I'm preferring to stay with standard terminal programs like Hyperterm and Teraterm and remote Telnet and also down the track, the PockeTerm (see attached). I wonder if the terminal you are using could be edited?
CP/M outputs 13 then 10 after each line. The bootup sends just 13, and 10 if you want to add it.
The idea I have is to leave out the ifdefs, delete all references to CR, even delete CR and LF as definitions in the main program. Just a philosophical thing too, but a uart object really should just be sending and receiving bytes, not modifying those bytes.
All the bootup lines have crlf as the next line eg
UART.str(string("ZiCog v0.009 on the TriBladeProp v0.09x"))
crlf
UART.str(string("8 bit, parity=None, 1 stop bit, Flow control=None"))
crlf
And then you just change this line here and comment out the LF if you don't want it. So it becomes one line to change which is as simple as an ifdef. (you could even add that deletion as an ifdef if required)
PRIcrlf
UART.tx(13)
UART.tx(10)
Attached zip of code with crlf added and a photo of it running on the PockeTerm
Addit: tried re including these lines but didn't make any difference to the speed:
'<== probably can speedup by enabling thisif blockno == 0
buff := $00
buff := $FF
Ok, major housekeeping. What I was debugging the program looking for the missing characters I went through and commented out lots of lines eg tv.hex and tv.dec because these did not exist in the serial driver. Those changes have ended up being left in, so time to fix them up.
All tv.hex changed to UART.hex and uncommented
All tv.dec changed to UART.dec and uncommented
All commented out instances of CR uncommented, and replaced with crlf
Many messages now included again, especially hard drive messages. While it is being debugged etc, better to have these messages. They can always be commented out again later.
I hope this is all ok, but it was kind of my fault this highly commented out version is persisting.
That works. Looking at a common file we can work on, can you pls re-release that with the baud rate at 115k, and try the LF commented out.
I'll change those two things on my working file (and hopefully remember to change them if I upload a new package).
Then you can use the terminal you are using. (my inability to go above 38k baud speed is due to the long serial cable. 38k is more than fast enough for me!)
I must say that is is amazing watching xmodem work. Also, I know I said those 4 lines
buff := $00
buff := $FF
didn't make a difference to the boot speed. They don't, but something has dramatically increased the speed of file writes when doing an xmodem file transfer.
All looking good!
So - on to the next phase. I've pondered all sorts of ways to get the bigger disk images, but keep coming back to heater's comment that it is best to keep this as a simh simulation. Use the simh standards. I was tempted at one stage earlier today to get into the cbios settings and make the floppy drives bigger, but I think heater is right. Keep the first 8 drives as 1mb, and then the next 4 as 8mb. Down the track, maybe we can get a link to the zicog on the simh site (as the N8VEM managed to do once it was stable).
Heater, I spent 4 months procrastinating building a triblade. Cluso was very patient, and he even sent me a freebie sd socket at one stage. So I know the board can be a bit daunting, but are you stuck with one particular part missing, or is the build a bit confusing? I know this might be a bit odd to hassle you like this, but I feel like a smoker who has just quit and now has gone all evangelical about it. The triblade is great!!! If you need a ram chip or something, pls let me know so I can send you one.
Was there a thought at one stage of using faster sd access code? Is this possible (it would be great if it is!)
Dr_A: Only just today I managed to find time to sit down with ZiCog and find out what you guys are up to.
Looks like you have been doing great. I have just now managed to download your latest files and get them running on my Demo Board.
Re: Hard Disks. I just noticed a comment in zicog_demo under the HD descriptors that the sector size can be increased
from 128 bytes BUT NOT for CP/M 2 only CP/M 3. I don't know if that is a limitation of CP/M 2 or just the CBIOSX we are using with it.
It occurs to me that as we are 512 byte SD card blocks to hold 128/137 byte sectors, which is waste full anyway, we would get a 4 times
speed up of disk access using 512 byte sectors on hard disks under CP/M 3 !!! Not to mention the speed gain we get by using "virtual" DMA
instead of the byte at a time transfers of the floppy disks.
So we should aim to
1) Get hard disks working
2) Get CP/3 in general use
3) Increase the sector size to 512
4) Add more tracks etc.
Re: My TriBlade, The major problem is the lack of time. But given my list of objectives above I really should try harder to get on to it.
If you have a spare RAM chip that would be great [noparse]:)[/noparse]
For the rest of today I am going to try and recreate the experiments I did with the hard disk driver emulation.
I feel sure that it pretty much works. Just need to demonstrate it to you guys.
Dr_A: Just noticed in that screen shot above here that your BIOS is v1.25 from 15-JAN-2007.
I'm using (SIMH ALTAIR 8800, BIOS V1.27, 1 HD, 02-May-2009).
James: Those lines will not increase the speed after boot.
However, I increased the FDX buffer size to 256 (previously 16) and this could account for speed improvement. You can make it 512 if you like - just edit the CON section in FDX.
OK with the baudrate. I will not re-release just for that - I can that change easily. Heater is looking at the hard drive tonight so may have some fixes. I think we may need a N8VEM #define at some time, so could adj baudrate in there.
Heater and I emailed today and we are both going to use FDX (provided he has no problems tonight).
I am unable to try LF at the moment - no hardware :-(
re Heater's TriBlade - I think he has just been flat out with other things. I took photos and wrote instructions when I built my second TriBlade a week or so ago. However, I only built Blade #2 and the power & USB so far. Thats all I needed for running ZiCog. James, be careful about the ram chips. Heater may want to use them in something else LOL.
I cannot play with the faster fsrw SD code. I have been having a look though. Should pretty much drop in.
1) I edited z.bat to this:
homespun024 zicog_demo009_rr092_james2 -b -d -i3 -w
zicog_demo009_rr092_james2.binary
pause
#else FindDriveBase(0, string("DRIVE__A.DSK")) 'set the SD card drive base(s) CPM2.2 FindDriveBase(1, string("DRIVE__B.DSK")) 'set the SD card drive base(s) FindDriveBase(2, string("DRIVE__C.DSK")) 'set the SD card drive base(s) FindDriveBase(3, string("DRIVE__D.DSK")) 'set the SD card drive base(s) FindDriveBase(4, string("DRIVE__E.DSK")) 'set the SD card drive base(s) FindDriveBase(5, string("DRIVE__F.DSK")) 'set the SD card drive base(s) FindDriveBase(6, string("DRVCPM_2.DSK")) 'set the SD card drive base(s) CPM2.2 FindDriveBase(7, string("DRVCPM_3.DSK")) 'set the SD card drive base(s) CPM3 FindDriveBase(8, string("DRIVE__I.DSK")) 'set the SD card drive base(s) 8MB #endif
'Handle Z80 IO port reads case io_port srport: 'Altair front panel switches register in_srport simhport: 'SIMH control port in_simhport constat: 'Console status port. in_constat condata: 'Console data port in_condata statin: 'Altair disk status port in_statin secpos: 'Altair disk sector position port in_secpos dskread: 'Altair disk read port in_dskread n8vem_uart_test: ' test port $6D in_test_n8vem ' is a byte ready returns 0 for no byte, 1 for a byte n8vem_uart_in: ' ask for input from port $68 in_uart_n8vem ' get the byte #ifdef hdskenable hdskport: in_hdskport 'SIMH style hard disk port #endif other: UART.transmitCharacters(string("Read from unimplemented I/O Port &H")) printhex(io_port) UART.transmitCharacters(string(" with byte &H")) printhex(io_data) UART.transmitCharacters(string(13,10)) io_data := 0 io_command := 0
and
PRI on_output 'Handle Z80 IO port writes case io_port ledport: 'An 8 bit parallel output with LEDs attached out_ledport simhport: 'SIMH control port out_simhport condata: 'Console data port out_condata constat: 'Console status port out_constat punstat: out_punstat 'Punch control port selout: 'Altair disk controller select port out_selout dskcon: 'Altair disk function port out_dskcon dskwrit: 'Altair disk write port out_dskwrit n8vem_uart_out: ' &H68 out_n8vem_byte #ifdef hdskenable hdskport: out_hdskport 'SIMH style hard disk port #endif other: UART.transmitCharacters(string("Write to unimplemented I/O Port &H")) printhex(io_port) ' print the port number for debugging UART.transmitCharacters(string(" with byte &H")) printhex(io_data) UART.transmitCharacters(string(13,10)) io_command := 0 'Set flag ready for next io
etc
and added this line
PRI in_hdskport_read | r 'Handle read from hdskport during a disk read command 'This read triggers the actual disk sector transfere 'and must return an error code. 'N.B. sectors are mapped to blocks 1 to 1 UART.transmitCharacters(string("hdisk read "))
But further down
PRI in_hdskport_write 'Handle read from hdskport during a disk write command 'This read triggers the actual disk sector transfere 'and must return an error code. 'N.B. sectors are mapped to blocks 1 to 1 if hdsk_check_dts 'Check drive, track and sector are sane io_data := $FF 'Return error if not return #ifdef TriBladeProp '??? #else
Post Edited (Dr_Acula) : 8/17/2009 8:15:47 AM GMT
· Home of the MultiBladeProps: TriBladeProp, RamBlade, TwinBlade,·SixBlade, website
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80), MoCog (6809)
A>dirx Name Ext Bytes Name Ext Bytes Name Ext Bytes Name Ext Bytes ASM COM 8K ! EXZ80ALLCOM 12K ! SBASIC COM 26K ! UNERA COM 2K BASICLIBREL 42K ! EXZ80DOCCOM 12K ! SHOWSEC COM 4K ! UNLOAD COM 2K BOOT COM 2K ! FORMAT COM 2K ! SID COM 8K ! USERLIB REL 2K BOOTGEN COM 2K ! HALT COM 2K ! SPEED COM 2K ! USQ COM 2K CCPZ TXT 40K ! HDIR COM 2K ! STAT COM 6K ! W COM 4K CONIN ASM 2K ! L80 COM 12K ! SUBMIT COM 2K ! WS COM 8K COPY COM 2K ! LOAD COM 2K ! SUPERSUBCOM 4K ! WS OVR 52K CPU COM 2K ! M80 COM 20K ! SURVEY COM 2K ! WSMSGS OVR 14K DD TXT 2K ! MBASIC COM 24K ! SYSCOPY COM 2K ! XFORMAT COM 4K DDT COM 6K ! NEW BAS 2K ! SYSCPM2 SUB 2K ! XMODEMP COM 4K DDTZ COM 10K ! NEW COM 4K ! SYSCPM2ZSUB 2K ! XMODEMQ COM 4K DIR TXT 2K ! OVERLAYBCOM 8K ! TEST BAK 2K ! XSUB COM 2K DIRX COM 4K ! PACMAN95COM 18K ! TEST TXT 2K ! ZASM SUB 2K DUMP COM 2K ! PIP COM 8K ! TIMER COM 2K ! ZSID COM 10K ED COM 8K ! R COM 4K ! TS SUB 2K ! ZTRAN4 COM 4K EX8080 COM 12K ! RSETSIMHCOM 2K ! UNCR COM 8K 63 File(s), occupying 472K of 984K total capacity 182 directory entries and 512K bytes remain on A: A>
I am not sure about virtual DMA. Remember, the sram is shared with the SD card so we cannot actually implement this as it will be way too slow!!!
DPBLK0: ; DISK PARAMETER BLOCK (ROMDISK 32KB WITH 16 2K TRACKS, 22K usable) SPT_0: .DW 16 ; 16 SECTORS OF 128 BYTES PER 2K TRACK BSH_0: .DB 3 ; BLOCK SHIFT FACTOR (SIZE OF ALLOCATION BLOCK) BLM_0: .DB 7 ; PART OF THE ALLOCATION BLOCK SIZE MATH EXM_0: .DB 0 ; DEFINES SIZE OF EXTENT (DIRECTORY INFO) DSM_0: .DW 31 ; BLOCKSIZE [noparse][[/noparse]1024] * NUMBER OF BLOCKS + 1 = DRIVE SIZE DRM_0: .DW 31 ; NUMBER OF DIRECTORY ENTRIES AL0_0: .DB 10000000 ; BIT MAP OF SPACE ALLOCATED TO DIRECTORY AL1_0: .DB 00000000 ; DIRECTORY CAN HAVE UP TO 16 BLOCKS ALLOCATED CKS_0: .DW 0 ; SIZE OF DIRECTORY CHECK [noparse][[/noparse]0 IF NON REMOVEABLE] OFF_0: .DW 5 ; FIRST 5 TRACKS TRACKS RESERVED (10K FOR SYSTEM) ; SYSTEM IS ROM LOADER, CCP, BDOS, CBIOS, AND MONITOR ; ; IMPORTANT NOTE: TRACKS $00 - $04 OF 2K BYTES ; EACH ARE MARKED WITH THE OFF_0 SET TO 5 AS ; SYSTEM TRACKS. USABLE ROM DRIVE SPACE ; STARTING AFTER THE FIFTH TRACK (IE, TRACK $05) ; MOST LIKELY FIX TO THIS IS PLACING A DUMMY ; FIRST 10K ROM CONTAINS THE ROM LOADER, MONITOR, ; CCP, BDOS, BIOS, ETC (5 TRACKS * 2K EACH) DPBLK1: ; DISK PARAMETER BLOCK (RAMDISK 512K, 448K usable) SPT_1: .DW 256 ; 256 SECTORS OF 128 BYTES PER 32K TRACK BSH_1: .DB 4 ; BLOCK SHIFT FACTOR (SIZE OF ALLOCATION BLOCK) BLM_1: .DB 15 ; PART OF THE ALLOCATION BLOCK SIZE MATH EXM_1: .DB 1 ; DEFINES SIZE OF EXTENT (DIRECTORY INFO) DSM_1: .DW 225 ; BLOCKSIZE [noparse][[/noparse]2048] * NUMBER OF BLOCKS + 1 = DRIVE SIZE DRM_1: .DW 255 ; NUMBER OF DIRECTORY ENTRIES AL0_1: .DB 11110000 ; BIT MAP OF SPACE ALLOCATED TO DIRECTORY AL1_1: .DB 00000000 ; DIRECTORY CAN HAVE UP TO 16 BLOCKS ALLOCATED CKS_1: .DW 0 ; SIZE OF DIRECTORY CHECK [noparse][[/noparse]0 IF NON REMOVEABLE] OFF_1: .DW 1 ; 1 TRACK RESERVED [noparse][[/noparse]FIRST 32K OF RAM] DPBLK2: ; DISK PARAMETER BLOCK (IDE HARD DISK 8MB) SPT_2: .DW 256 ; 256 SECTORS OF 128 BYTES PER 32K TRACK BSH_2: .DB 5 ; BLOCK SHIFT FACTOR (SIZE OF ALLOCATION BLOCK) BLM_2: .DB 31 ; PART OF THE ALLOCATION BLOCK SIZE MATH EXM_2: .DB 1 ; DEFINES SIZE OF EXTENT (DIRECTORY INFO) DSM_2: .DW 2017 ; BLOCKSIZE [noparse][[/noparse]4096] * NUMBER OF BLOCKS + 1 = DRIVE SIZE ; HD PARTITION 2 IS 16128 SECTORS LONG ; AT 512 BYTES EACH WHICH IS ; 2016 BLOCKS AT 4096 BYTES A PIECE. DRM_2: .DW 511 ; NUMBER OF DIRECTORY ENTRIES AL0_2: .DB 11110000 ; BIT MAP OF SPACE ALLOCATED TO DIRECTORY AL1_2: .DB 00000000 ; DIRECTORY CAN HAVE UP TO 16 BLOCKS ALLOCATED CKS_2: .DW 0 ; SIZE OF DIRECTORY CHECK [noparse][[/noparse]0 IF NON REMOVEABLE] OFF_2: .DW 1 ; 1 TRACK (32K) RESERVED FOR SYSTEM DPBLK3: ; DISK PARAMETER BLOCK (IDE HARD DISK 8MB) SPT_3: .DW 256 ; 256 SECTORS OF 128 BYTES PER 32K TRACK BSH_3: .DB 5 ; BLOCK SHIFT FACTOR (SIZE OF ALLOCATION BLOCK) BLM_3: .DB 31 ; PART OF THE ALLOCATION BLOCK SIZE MATH EXM_3: .DB 1 ; DEFINES SIZE OF EXTENT (DIRECTORY INFO) DSM_3: .DW 2017 ; BLOCKSIZE [noparse][[/noparse]4096] * NUMBER OF BLOCKS + 1 = DRIVE SIZE ; HD PARTITION 3 IS 16128 SECTORS LONG ; AT 512 BYTES EACH WHICH IS ; 2016 BLOCKS AT 4096 BYTES A PIECE. DRM_3: .DW 511 ; NUMBER OF DIRECTORY ENTRIES AL0_3: .DB 11110000 ; BIT MAP OF SPACE ALLOCATED TO DIRECTORY AL1_3: .DB 00000000 ; DIRECTORY CAN HAVE UP TO 16 BLOCKS ALLOCATED CKS_3: .DW 0 ; SIZE OF DIRECTORY CHECK [noparse][[/noparse]0 IF NON REMOVEABLE] OFF_3: .DW 1 ; 1 TRACK (32K) RESERVED FOR SYSTEM DPBLK4: ; DISK PARAMETER BLOCK (IDE HARD DISK 1024K) SPT_4: .DW 256 ; 256 SECTORS OF 128 BYTES PER 32K TRACK BSH_4: .DB 4 ; BLOCK SHIFT FACTOR (SIZE OF ALLOCATION BLOCK) BLM_4: .DB 15 ; PART OF THE ALLOCATION BLOCK SIZE MATH EXM_4: .DB 0 ; DEFINES SIZE OF EXTENT (DIRECTORY INFO) DSM_4: .DW 497 ; BLOCKSIZE [noparse][[/noparse]2048] * NUMBER OF BLOCKS + 1 = DRIVE SIZE ; HD PARTITION 4 IS 4032 SECTORS LONG ; AT 512 BYTES EACH WHICH IS ; 1008 BLOCKS AT 2048 BYTES A PIECE. ; NOT USING ALL OF THE AVAILABLE SECTORS SINCE THIS ; DRIVE IS INTENDED TO EMULATE A ROM DRIVE AND COPIED ; INTO A ROM IN THE FUTURE. DRM_4: .DW 255 ; NUMBER OF DIRECTORY ENTRIES AL0_4: .DB 11110000 ; BIT MAP OF SPACE ALLOCATED TO DIRECTORY AL1_4: .DB 00000000 ; DIRECTORY CAN HAVE UP TO 16 BLOCKS ALLOCATED CKS_4: .DW 0 ; SIZE OF DIRECTORY CHECK [noparse][[/noparse]0 IF NON REMOVEABLE] OFF_4: .DW 1 ; 1 TRACK RESERVED [noparse][[/noparse]FIRST 32K OF PARTITION]
d tracks[noparse][[/noparse]0-7] 254 attach dsk cpm2.dsk attach dsk1 basic.dsk attach dsk2 games.dsk attach dsk3 sbasic.dsk attach dsk4 supercalc.dsk attach dsk5 tools.dsk attach dsk6 wordstar.dsk attach hdsk i.dsk set cpu 64k set cpu noitrap set cpu z80 set cpu altairrom set cpu nonbanked reset cpu set sio ansi set sio nosleep boot dsk bye
C:\N8VEM\AltairSIMH>altairz80 all Altair 8800 (Z80) simulator V3.7-3 build 1016 (scp created Apr 20 2008 at 13:01: 09 with gcc 4.2.3) 64K CP/M Version 2.2 (SIMH ALTAIR 8800, BIOS V1.25, 2 HD, 15-Jan-07) A>dirx Name Ext Bytes Name Ext Bytes Name Ext Bytes Name Ext Bytes ASM COM 8K ! EXZ80DOCCOM 12K ! SID COM 8K ! UNLOAD COM 2K BOOT COM 2K ! FORMAT COM 2K ! SPEED COM 2K ! USQ COM 2K BOOTGEN COM 2K ! HALT COM 2K ! STAT COM 6K ! W COM 4K CCPZ TXT 40K ! HDIR COM 2K ! SUBMIT COM 2K ! WS COM 8K COPY COM 2K ! L80 COM 12K ! SUPERSUBCOM 4K ! WS OVR 52K CPU COM 2K ! LOAD COM 2K ! SURVEY COM 2K ! WSMSGS OVR 14K DDT COM 6K ! M80 COM 20K ! SYSCOPY COM 2K ! XFORMAT COM 4K DDTZ COM 10K ! MBASIC COM 24K ! SYSCPM2 SUB 2K ! XSUB COM 2K DIRX COM 4K ! PACMAN95COM 18K ! SYSCPM2ZSUB 2K ! ZASM SUB 2K DUMP COM 2K ! PIP COM 8K ! TIMER COM 2K ! ZSID COM 10K ED COM 8K ! R COM 4K ! TS SUB 2K ! ZTRAN4 COM 4K EX8080 COM 12K ! RSETSIMHCOM 2K ! UNCR COM 8K EXZ80ALLCOM 12K ! SHOWSEC COM 4K ! UNERA COM 2K 50 File(s), occupying 370K of 984K total capacity 198 directory entries and 614K bytes remain on A: A>i: I>dirx Name Ext Bytes Name Ext Bytes Name Ext Bytes Name Ext Bytes CP409DOCARK 68K ! K1KERM11LBR 16K ! ZORK1 COM 12K ! ZORK2 DAT 92K CP411HEXARK 156K ! LU COM 20K ! ZORK1 DAT 84K ! ZORK3 COM 12K CP411SRCARK 436K ! UNARC COM 8K ! ZORK2 COM 12K ! ZORK3 DAT 92K 12 File(s), occupying 1008K of 8136K total capacity 987 directory entries and 7128K bytes remain on I: I>
Dr_A:
PRI WriteSRAMblock | i, r, mask, in r := tbp2.start check_error(r) #ifdef diskboot 'clears ram $0000-$EFFF, loads $FF00-$FFFF, loads sram disk above 'remember we are reading 8KB blocks, so clear the seven blocks and 8KB-128B of eighth block if blockno < 8 'TV.dec(blockno) if blockno == 7 repeat i from 0 to count-1 -(256) 'clear below $FF00 buff[noparse][[/noparse]i] := 0 'clear the buffer else repeat i from 0 to count-1 buff[noparse][[/noparse]i] := 0 'clear the buffer if blockno == 0 buff[noparse][[/noparse]0] := $C3 'force jmp to $FF00 (faster) buff[noparse][[/noparse]1] := $00 buff[noparse][[/noparse]2] := $FF #endif
ZiCog v0.009 on the TriBladeProp v0.09x 8 bit, parity=None, 1 stop bit, Flow control=None Starting disks... A:DRIVE__A.DSK B:DRIVE__B.DSK C:DRIVE__C.DSK D:DRIVE__D.DSK E:DRIVE__E.DSK F:DRIVE__F.DSK G:DRVCPM_2.DSK H:DRVCPM_3.DSK Loading SRAM... ................................................................................ ................................................Loaded Starting TriBladeProp driver ... Passed, please wait... Starting Z80 emulation... Passed, please wait... 64K CP/M Version 2.2 (SIMH ALTAIR 8800, BIOS V1.25, 2 HD, 15-Jan-07) Unknown console status write with byte &H03
What changed from this version (see attached)
Post Edited (Dr_Acula) : 8/17/2009 1:08:41 PM GMT
Nyamekye,
PUB rxcount
else
return ((inputHead + $100 - inputTail)) & $FF) '<==fix
Post Edited (Cluso99) : 8/17/2009 2:12:34 PM GMT
Basically I copied a bunch of files from A: to I: under SIMH and dropped the resulting file into ZiCog.
I have successfully read directories and read/written to it. I'll dig it out in a couple of hours.
Cluso99:
If you feel more comfortable with that way then go ahead and do it!
I've very sure my technique works however, I been testing it without flaws for a while now.
Nyamekye,
Post Edited (Kye) : 8/17/2009 8:16:29 PM GMT
Good and bad news.
' Optionally add LF after CR if rxtx_mode &%10000 and txbyte == CR repeat until (tx_tail <> (tx_head + 1) & bufmsk) tx_buffer[noparse][[/noparse]tx_head] := LF tx_head := (tx_head + 1) & bufmsk if rxtx_mode & %1000 rx
UART.str(string("ZiCog v0.009 on the TriBladeProp v0.09x")) crlf UART.str(string("8 bit, parity=None, 1 stop bit, Flow control=None")) crlf
PRI crlf UART.tx(13) UART.tx(10)
'<== probably can speedup by enabling this if blockno == 0 buff[noparse][[/noparse]0] := $C3 'force jmp to $FF00 (faster) buff := $00 buff := $FF
Post Edited (Dr_Acula) : 8/18/2009 3:36:12 AM GMT
Sorry, I didn't understand that CPM output CR+LF whereas ZiCog demo was not.
re bst - you must have warnings turned off as there sould be 3 warnings about # missing in jmps.
All looking good!
So we should aim to
Post Edited (heater) : 8/18/2009 2:44:20 PM GMT
With no fuss at all I have hard drive I: working. At least for reads.
