Playing a wav file without SD?
Is it possible to play a small wav file without using an SD card?· SD is nice and all, but it takes up time, longs, and pins.· I think the "yet another HSS player" does that with *.hmus files...· I know it may be hard to find a small enough *.wav file, but I have a 5k-ish one in mind for a test...
Thanks.
Quit buying all those fixed voltage regulators, and·get an Adjustable Power Supply·for your projects!· Includes an LED testing terminal!
*-NEW-* SD Card Adapter·Now available!· Add extra memory to your next Propeller project with ease!
Thanks.
My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
