Propeller and Vibra Tab
For the parallax Piezo Film Vibra Tab Mass sensor at:
http://www.parallax.com/Store/Sensors/PressureFlexRPM/tabid/177/CategoryID/52/List/0/Level/a/ProductID/89/Default.aspx?SortField=ProductName%2cProductName
There is a circuit described in the pdf at:
http://www.parallax.com/Portals/0/Downloads/docs/prod/compshop/PiezoInfo.pdf
Is that circuit "safe" to use for a propeller input pin?
if not, then what mods would be needed?
The circuit diagram shown on the pdf is for a Basic Stamp which uses 5 Volt I/O signals.
See this thread on safely connecting a 5 Volt signal to a Propeller. http://forums.parallax.com/showthread.php?p=585920
It is recommended that a 1k resistor be placed between a 5 Volt signal and a Propeller Pin.
So I think you could do it that way - though there may be better thoughts from others.
I have used the Vibra Tab with a Basic Stamp, but not with the Propeller. It is a neat sensor and works well.
Also on the Vibra Tab page, there is a link to the Object Exchange Sensor's page, but I could not find an object for the Vibra Tab - If there is one, it may have some connection info.
Whit+
I did peruse the thread you referenced. There was a lot of information packed into that little gem. Your additional comments on the sensor itself are also very encouraging. With the newfound confidence that "I won't make smoke" I am even more eager to wire up the little wiggler to the propeller
I did not see any obex entry for the device as well, but as it looks like a simple level test, it seems that ina is all that is needed to read from the little wiggler.
Thanx again!
TinkersALot
