Propeller and Vibra Tab — Parallax Forums
TinkersALotTinkersALot Posts: 535
edited 2010-07-02 17:01 in Propeller 1
For the parallax Piezo Film Vibra Tab Mass sensor at:
http://www.parallax.com/Store/Sensors/PressureFlexRPM/tabid/177/CategoryID/52/List/0/Level/a/ProductID/89/Default.aspx?SortField=ProductName%2cProductName
There is a circuit described in the pdf at:
http://www.parallax.com/Portals/0/Downloads/docs/prod/compshop/PiezoInfo.pdf
Is that circuit "safe" to use for a propeller input pin?
if not, then what mods would be needed?
  • WhitWhit Posts: 4,191
    edited 2009-08-11 02:09
    TinkersALot,
    The circuit diagram shown on the pdf is for a Basic Stamp which uses 5 Volt I/O signals.
    See this thread on safely connecting a 5 Volt signal to a Propeller. http://forums.parallax.com/showthread.php?p=585920
    It is recommended that a 1k resistor be placed between a 5 Volt signal and a Propeller Pin.
    So I think you could do it that way - though there may be better thoughts from others.
    I have used the Vibra Tab with a Basic Stamp, but not with the Propeller. It is a neat sensor and works well.
    Also on the Vibra Tab page, there is a link to the Object Exchange Sensor's page, but I could not find an object for the Vibra Tab - If there is one, it may have some connection info.
    Whit+
    edited 2009-08-11 04:50
    Thank you, Whit --
    I did peruse the thread you referenced. There was a lot of information packed into that little gem. Your additional comments on the sensor itself are also very encouraging. With the newfound confidence that "I won't make smoke" I am even more eager to wire up the little wiggler to the propeller
    I did not see any obex entry for the device as well, but as it looks like a simple level test, it seems that ina is all that is needed to read from the little wiggler.
    Thanx again!
    TinkersALot
  • Little-endianLittle-endian Posts: 91
    edited 2010-07-02 16:28
    I know this is an old thread, but after being recently inspired by the "Laundry Alert" project (http://www.parallax.com/LaundryAlert/tabid/883/Default.aspx) I was wondering if it might also be possible to detect a running appliance (washer, dryer, dehumidifier) using a sensor to measure its vibration. In my case, I really don't care about how much it's vibrating, just whether or not the appliance is running. I know an accelerometer can do this, but I really don't need to measure the amount of vibration. In searching for a sensor I found the inexpensive Vibra Tab and this thread. Anyone know if the Vibra Tab would be a good choice for a Propeller application to determine when a washer, dryer, dehumidifier, etc. is running?
  • T ChapT Chap Posts: 4,224
    The 5.1v zener is there to limit the voltage max. You can use a limit resistor as stated, but you can also sub in a 3v3 zener or close to prevent some higher voltage if the tab gets hit hard. If you wanted to, you could connect a scope to the tab and see what the max potential voltage spike is, and work from there.
