Is it possible to use a Walkie Takie as a transciever? — Parallax Forums
MicrocontrolledMicrocontrolled Posts: 2,461
edited 2009-08-09 10:01 in Propeller 1
Is there a way? Do you connect your data pin to the mic? (i don't think it is possible to the analog interface created with the mic)
Thanks for the help!
Toys are microcontroled.
Robots are microcontroled.
I am microcontroled.
If it's not Parallax then don't even bother. :-)
I have changed my avatar so that I will no longer be confused with others who use genaric avatars.
Mini-Din/PS2 connectors are for sale! 5 for $1! PM me if you wish to make an order.
Cheap·shipping unless specified!··········150 left!!··
  • Brian CarpenterBrian Carpenter Posts: 728
    edited 2009-08-08 23:48
    Yes. Search For Bell202 modem. I think Phil Pilgram did it
    It's Only A Stupid Question If You Have Not Googled It First!!
    edited 2009-08-08 23:50
    Phil Pilgrim has even stuffed the whole modem into a Propeller chip, so you only need a couple of passives to hook it up to your radios (doesn't require the hardware modem shown in the above link).
    I don't think I've ever used my radios for talking, only data transmission.
    His work is on OBEX.
    KI6HBT
    edited 2009-08-09 00:01
    I looked under "protocol" in the OBEX and couldn't find it.
  • SRLMSRLM Posts: 5,045
    edited 2009-08-09 00:22
    Try "modem".
  • lonesocklonesock Posts: 917
    edited 2009-08-09 00:26
    I assume this one:
    obex.parallax.com/objects/421/
    Is it just me, or is it hard to search the OBEX by author?
    Jonathan
    lonesock
    Piranha are people too.
    edited 2009-08-09 00:28
    It's under "Signal Generation & Processing".
    Please be sure that data transmission is legal for the radio service you're using. If your walkie talkies use CB, FRS or business frequencies, it probably is not. But if you're a licensed ham using amateur radio frequencies, you're in good shape.
    edited 2009-08-09 00:51
    I'm not using anything long range, just one of those dinky little 1-mile radios that you can get at Wal-Mart! Will it work with one of those?
  • hinvhinv Posts: 1,256
    edited 2009-08-09 01:22
  • hover1hover1 Posts: 1,929
    edited 2009-08-09 01:33
    You still have to·be a licensed ham operater to send data over certain frequencies. It doesn't matter how low tech the transmitter is. Check the FCC site for details. I'm not at work where I have specific links.
    microcontrolled said...
    edited 2009-08-09 01:42
    I assume you are referring to FRS radios?
    If so, it's not strictly according to the rules of FRS to do data transmission.
    But I seriously doubt that you would ever be called to account on it wink.gif
    Important questions are: do you need a high data rate or not? do you need a one way data channel or a 2way?
    If you just need low-rate one-way data, Like remote transmission of temperature, wind speed from a weather station
    then I'd send simple tones through the mic circuit on the FRS radio, something like morse would work.
    For simplicity, at the receiving end use an ne567 tone decoder chip. It would be a bit kludgy but you could modulate the
    FRS by placing a speaker over the mic and driving the speaker from the prop. No need for the FRS to stay on all the time,
    drive a relay or switching transistor from the prop to turn the radio on/off.
    An easy method if you want full-duplex is to use 4 cheap FRS radios.
    FRS really spans 2 UHF bands... chan 1-7 (462.5625-462.7125) and chan 8-14 (467.5625-467.7125)
    ch 1 is so far from ch14 that simultaneous transmission/reception using these frequencies should not desense the receivers.
    You could also do 2-way data transmission with just 2 FRS radios but you would have to switch each radio from xmit to rcv by using a
    switching transistor or optocoupler hooked to a pin of the prop. This might be the way to go as the output transistor in the FRS
    radios may not be rated for continuous duty anyway.
    If you can find a cheap cordless phone that is not being used any more then you can do full duplex communications from
    the handset to the base, and they are rated for continuous duty. The range is not bad either and there is no rule saying you
    cannot use them for data transmission. If you make a simple set of external antennas you could get lots of extra range.
    You can probably do a google search and turn up info about turning an unused cordless phone into things like point2point data
    Of course the professional way to do this is to buy ready made modules that are easy to connect to a controller...but I am
    assuming you want a low-cost and homemade method.
    edited 2009-08-09 01:56
    Re "You still have to be a licensed ham operater to send data over certain frequencies. It doesn't matter how low tech the transmitter is. Check the FCC site for details. I'm not at work where I have specific links."
    I agree and this was discussed in detail last year on the Picaxe forum. Here in Australia there are two frequencies allocated for data. However, when you scroll through all the channels on one of those low tech handhelds, it skips the data ones. Voice users would not appreciate having their channels swamped with data, and it is illegal anyway. So essentially, these cheapie hand held units can't be used for data. (even though it is possible technically).
    There are lots of other solutions, particularly the 433Mhz data transceiver units from Hope or Yishi or other manufacturers which are a drop-in replacement for a wired RS232 connection and are only around $20 to $30 each. These are <10mW but get a good range by having super sensitive receivers (eg -123db).
    Post Edited (Dr_Acula (James Moxham)) : 8/9/2009 2:06:50 AM GMT
    edited 2009-08-09 02:29
    @Dr_Acula
    An interesting option for VERY long range data is available here in the states.
    There is a tiny sliver of bandwidth just below the 20 meter ham band that is available
    for use for scientific and educational purposes on a non-exclusive (you can't complain about being interfered with by other users..etc) basis.
    13.553-13.567Mhz
    If you listen with a quality receiver on CW mode in this band you will hear regular sets of beeps from some
    remote gear on 13.5602 .... you will, of course, get reception best during the daylight hours due to the
    painful sunspot minimum we are experiencing. The data is from some very weak solar powered remote devices
    at various locations across the states. Power output is 1 watt to a simple V ant with apex at just 15ft.
    Just this afternoon I had great reception on several of them located at a distance greater than 1,000 miles.
    The solar panels that power them are just tiny things about 8 inch square. They are AVR based and the entire
    electronics package is about the size of a paperback book.
    You need a very narrow bandwidth filter to manage to hear only the signals from these devices because the
    frequency range is a mass of various transmissions....bedlam at times.
    Post Edited (HollyMinkowski) : 8/9/2009 2:40:26 AM GMT
    edited 2009-08-09 02:45
    HollyMinkowski - what a fascinating post. I need to research this more. I wonder if it could be used with PhiPi's nifty bell modem code? Long antennas, small solar power transmitters. I'm off to Google to find out more...
    edited 2009-08-09 03:18
    I know nothing of Australian law, but here in the states you must have any gear for these
    bands certified for use by a 1st Class FCC license holder....it's not for tinkerers.
    I searched on google and came up with a snippet from a page at Google books search.
    Note that the 2400Mhz-2500Mhz band has a center freq of 2450Mhz.
    That is the freq that was assigned by the FCC for microwave ovens to operate on if I remember correctly...how interesting smile.gif
    And of course, just below 2450 is the wifi band.
    The 2,5 and 24Ghz bands would be great for narrow beam width point2point work with small dish antennas.
    It is readily apparent that all the wifi bands, cordless phone bands, fall into these allocations.
    I find it odd that they put FRS radios on 400mhz and not the 902-928Mhz range already allocated
    for such devices...hmmm
    What a shame there is not a small bit of spectrum available around 8-10mhz...it would be ideal both
    day and night during sunspot minimums unlike 13560 which is only usable during the day...it would not
    be as good at longer ranges as 13560 but would be better for shorter ranges. Something around 3Mhz
    would be great for 0 to 300 miles.
    Post Edited (HollyMinkowski) : 8/9/2009 3:39:01 AM GMT
    edited 2009-08-09 06:22
    microcontrolled,
    Seriously, if you are interested in wireless data communication, it's very easy to get an amateur technician class license. You have to pass a test, but it's an easy one. A few evenings study from this book is really all you need to get up to speed. There's no Morse code requirement any more. Then, pick up a pair of used 2-meter handhelds from eBay, and you're all set.
    edited 2009-08-09 07:32
    I might get that book too, PhiPi. I'm intrigued by Holly's low frequency stuff and I guess if you need a licence, then why not get one. I just did an online practice exam for the technician's class and got 77%. The Morse thing always put me off but I gather that has gone now, right?
    With a licence, one could crank up the power over 10mW! And I might need a bit of power once I put Cluso's triblade into my wireless mesh.
    edited 2009-08-09 08:02
    That's right: no code requirement, which I have somewhqat mixed feelings about. I can remember sweating as a teen at the FCC offices in Indianapolis to pass the 13wpm code test for my general class license, but I'm glad I went through it. Knowing Morse code is like riding a bike. Your speed may diminish without practice, but you never forget it. Now, you not only don't need to know Morse, but you don't even have to see the inside of a federal offcie building. My license had long since lapsed, so I started over to get a new one this past winter and took the test — proctored by vounteer hams from my community — at a local fire station. Not only that, but the long wait for your license to show up in the mail before you can begin operating is history. Once your name and new callsign appear on the FCC's website a few days after the test, you're good to go.
    AD7YF
    Here in the UK we were allocated 2460-2560MHz for broadcast point to point links. Neadless to say the lower end of the spectrun was not too useful at mealtimes. Ok for the top of some Welsh hillside.
    Ex G8LCU back in the 70's
    Style and grace : Nil point
    Post Edited (Toby Seckshund) : 8/9/2009 10:09:55 AM GMT
