Here is a little document I made up for the TKB150P, and some SX/B code.
To see the SX/B code work do: DEBUG, then press the POLL button.
Bean.
"A government big enough to give you everything you want, is big enough to take away everything you·have."·· Thomas Jefferson
"It is our choices, Harry, that show what we truly are, far more than our abilities."·Dumbledore from Harry Potter
We both have our Keyboards now. I have 1 of mine wired up and working using·Bean's KB1000.sxb DEBUG program.
However, the comments say don't use an internal oscillator because the serial is not stable with an internal oscillator. However, it worked with no resonator installed. But I have always been told not to use DEBUG with an external resonator because it could blow up the SX-Key which I believe happened to me once.
So I take it that I can change the DATA statements in the program to add in the other Keys like numbers (capitol letters too?) and symbols?
· When using DEBUG the SX generates the clock. And it is very stable. So that is why it works.
· To get the digits and stuff, you need to set flags when certain keys are pressed (like FN), they use a different data table if they are active. · When I get a chance I'll work on a better demo program that does that.
Bean.
I have modified Bean's KB1000.sxb program (see attached) to also see the BLUE keys. This is working as I would expect. It checks for $01 (FN key) and displays on the Debug window the correct keyCodes.
However, if 'Q' is equal to $10, why does Debug display is as 51 (which is the ascii code for Q)? Can anyone explain this? I see no where's on the screen where $10 is listed nor the other Release keys. I thought that I should modify the SERIN statement to look·something like this: SERIN KeyboardPin, N9600, keyCode,·release1, release2 but·it does not ·do anything in Debug nor outside of Debug.
I have spent over a day just trying to have it recognize a key being pushed (outside of Debug) and I can't get anything to work. What I wanted to do is press a certain key and have it break out of the DO LOOP routine and turn on a LED or something to some way let me know it is no longer scanning for keys.
Bottom line - works fine in Debug but not running outside of Debug. Can anyone help with this?
I modified the program again to connect·8 resistor/leds to RC and moved the keypad pin to RB.7.
When I leave the program as is and run in Debug mode (click on "Poll" too), I see the 8 LEDs display correctly and the Watch keyCode is correct (e.g. press the Q button displays Watch keyCode = 81 and the LEDs display 0*0*000* -> 64+16+1 = 81). So everything is fine under Debug using Poll or even Run.
However when I comment out the Watch and Break statements and compile normally, no LEDs turn on. I am really stumped on this. I tried using some PAUSEs and other ideas but don't understand what is happening here.
' Test program for Micro Innovation TKB150P mini keyboard
DEVICE SX52, OSCXT1 ', TURBO, OPTIONX, STACKX
FREQ 4_000_000' DO NOT USE INTERNAL OSCILLATOR, IT IS NOT STABLE ENOUGH FOR SERIAL' On keyboard connect: VDD to supply; GND to ground; PE3 to RA.0' Keyboard seem to work at 5.0V, but 3.3V is recommended.'KeyboardPin PIN RC.2 INPUT
KeyboardPin PIN RB.7 INPUT
LED PIN RC OUTPUT
keyCode VARBYTE
PROGRAM Start
Start:
DO
IF keyCode < $70 THEN
IF keyCode = $01 THEN
DO
READ Blue + keyCode, keyCode
LOOP UNTIL keyCode <> 0ELSE
DO
READ Keys + keyCode, keyCode
ENDIF
'WATCH keyCode,1,FSTR
[b][color=red]WATCH keyCode,8,SDEC
BREAK
[/color][/b] 'keyCode = keyCode ' Need an instruction for break to work
[b]LED = keyCode[/b]
ENDIF
LOOP
END
Keys:
DATA 0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0' $00 to $0F
DATA "Q","W","E","R","J","K","L",0 ,0 ," ",0 ,0 ,0 ,0 ,0 ,0' $10 to $1F
DATA 0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,"D","F","G","H",0 ,0 ,0 ,0' $20 to $2F
DATA 0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0' $30 to $3F
DATA 0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,"M","N","B","S","A","P","O"' $40 to $4F
DATA 0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0' $50 to $5F
DATA 0 ,0 ,0 ,0 ,"V","C","X","Z","I","U","Y","T",0 ,0 ,0 ,0' $60 to $6F
Blue:
DATA "1","2","3","4","'",0 ,"@",0 ,0 ," ",0 ,0 ,0 ,0 ,0 ,0' $10 to $1F
DATA 0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,"+","-","=",":",0 ,0 ,0 ,0' $20 to $2F
DATA 0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,".","'","!","/","*","0","9"' $40 to $4F
DATA 0 ,0 ,0 ,0 ,"?",")","(","$","8","7","6","5",0 ,0 ,0 ,0' $60 to $6F
Well - I figured it out. I needed to put back in a resonator (and change the FREQ statement to the resonators value) and then I could run the program outside of Debug. However, the value of Q was 81 (or $51) and could exit out of the loop if pressed. I still don't see where the value of $10 comes from for Q. But at this point, I am happy I can continue with my progress.
' Use TKB150P Micro Datapad' Vcc tied to +5vdc (actually runs on 3.3vdc - but 5vdc works)' Gnd tied to ground' PE3 serial tied to RC.2 (or any other available key)
Datapadpin PIN RC.2 INPUT 'PE3 serial wire from TKB150P
keyCode VARByte
alpha VARByte
m_lin1 VARByte (8)
Datapad FUNC 1, 0' Scan the Datapad' Store 8 characters into m_line1
FOR alpha = 0TO7
Datapad
m_lin1(alpha) = keyCode
NEXT
END
FUNC Datapad
DO
SERIN Datapadpin, N9600, keyCode
DO
DO
ENDIF
RETURN keyCode
IF keyCode THEN EXIT
ENDIF
LOOP
ENDFUNC
Keys:
DATA 0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,"D","F","G","H",13 ,0 ,0 ,0' $20 to $2F
Blue:
Post Edited (T&E Engineer) : 7/22/2008 12:25:58 AM GMT
Hi anyone, Did an object ever get written for this wee keypad? I found a nice documentation by a Mike Cook but it is not printable without registering which I didn't want to do.
Has anyone really made use of the keypad? The encoding seems awkward at first glance; may have been a reason for it.
I got my 6 units, opened one up to study the design and pcb layout, and powered it to scope the output. Other work pushed it aside. Wonder how these worked with the Palm?
Thank you Bean. I did see the thread on these and someone even measured the current draw, I note. Neat and small; if only my fingers fit better; easy to hit two or more 'buttons'. Thanks again.
Finally got around to the M105 Mini-keypad. The keypads were available for 'free' almost, but was too occupied at the time to get to this state of progress. Anyway thought I'd document it.
Used John Abisher's early code to get the Prop and keypad working, completed the lookdown/lookup lines, and modified the tv display to my liking. Used wire-wrap wire to connect keypad and Prop Protoboard, as was out of stranded wire; temporary setup for this effort. Below is the code, but attached also is the archive and photos. Another learning curve project., I'd already had a female header on the board for SD card, so used that to plug in a male header wired to the keypad.
Works well, but the blue marking on the keypads is nearly useless for these old eyes. Keys are so close that fingers too easily hit adjacent keys. At $0.39 (shipping was lots more) a nice package; if only the i/f connector was a 'normal' type.
' from Prop forum, by Johm Abishier' by H Shanko rev. 9:30 am 28 Feb.2011CON
Rxpin = 0_clkmode = xtal1 + pll16x_xinfreq = 5_000_000
#0, lc, fn, caps
OBJ
tv : "TV_Text"
sio : "FullDuplexSerial"
vp : "Conduit"' transfers data to/from PC, 1 cog
qs : "QuickSample"' captures INA, variables, 1 cog @20 MHzVARlong stack[200], frame[400], char, junk1, junk2, state, idx, outchar
PUBMain
vp.register(qs.sampleINA(@frame,1)) 'sample INA w/ 1 cog up to 20 MHz (MUST BE COG 0)
optional_configure_viewport ' optionally configure Viewport's interface
vp.share(@char,@outchar) 'share memory from 'key' to 'id'; END of VP commands <<===
tv.start(12)
sio.start(Rxpin,-1,1,9600)
state := lc
tv.str(string(" M105 Keypad/Prop I xlator - 1 Mar.2011",13))
repeat' tv.out($00) ' clear screen ???
tv.str(string("Type a char",13))
' ReadCharscase state
lc:
ReadChars
if char == $1' if 'lc' and 'Fn', 'upper case' (=blue keycap symbols)
state := fn
else
idx := lookdown(char: $10,$11,$12,$13,$6B,$6A,$69,$68,$4F,$4E,$4D,$4C,$28,$29,$2A,$2B,$14,$15,$16,$17,{
}$01,$67,$66,$65,$64,$4B,$4A,$49,$48,$2C,$2D,$2F,$2E,$18,$19,$19,$1A,$1B,$62,$63)
outchar := lookup(idx: "qwertyuiopasdfghjklBFzxcvbnmDELDRP TDMU")
fn:
ReadChars
if char == $19' if 'Fn' and 'Space' key, caps (upper-case) mode
state := caps
elseif char ==$01' if 'Fn' and 'uppercase', 'lc'
state := lc
else
outchar := lookup(idx: "1234567890*/+-=:'",$22,"@BF$()?!,.DELDRP TDMU")
caps:
ReadChars
if char == $1' if 'caps' and 'Fn', 'lc'
state := lc
else
outchar := lookup(idx: "QWERTYUIOPASDFGHJKLBFZXCVBNMDELDRP TDMU")
tv.str(string(", the character is: "))
tv.out(outchar)
tv.str(string(" = hex "))
tv.hex(outchar,2)
tv.out(13)
' waitcnt(CLKFREQ + cnt)PRIReadChars
char := sio.rx
junk1 := sio.rx
junk2 := sio.rx
tv.hex(char,2)
tv.out(32)
tv.hex(junk1,2)
tv.out(32)
tv.hex(junk2,2)
' tv.out(13) return'+-------------------------------------------------------------------------------------+PUBoptional_configure_viewport
vp.config(string("var:io(bits=[all[0..29],30tx,31rx])"))
vp.config(string("var:io,key,id")) ' show these VARs
vp.config(string("lsa:view=io,timescale=200ns,trigger=io[8]f")) ' trig on A8 falling
vp.config(string("edit:key(default=5,mode=text)"))
vp.config(string("start:lsa"))
I use the M105 keypad with Rayman's Propeller System Module to make a "Portable Computer" The code as it stands waits for a keypress so I modified it so it times out after 10 milliseconnds so I can monitor if a keypress has happened or not and if so act on it.
I still have a few of these on my shelf.. They are awesome little keyboards. The only reason I don't use them more often is because I have big gorilla-like hands.
@ OBC, I'd guess even 'normal' hand/finger size finds the M105 keys too close. My iMac keys are 3/4", a rather normal keyboard spacing. The M105 is about 0.35", just under half that. Not one for speed typing.
@ blitted, I'd like to see a photo of how your keypad is cabled in use. Would your source code be available to study? I like your idea, even though my above statement still holds; More for one finger typing than two or more fingers in use. I have both a 3.5" and several 4.3" LCDs from Rayman. Make quite nice displays.
Bean.
www.iElectronicDesigns.com
Thank you so much.
Thanks again!
· Glad you got it working !
Bean.
I was thinking that Lookup tables could be used for this.
I appreciate you expanding on the demo.
Thanks again!
' Test program for Micro Innovation TKB150P mini keyboard DEVICE SX52, OSCXT1 ', TURBO, OPTIONX, STACKX FREQ 4_000_000 ' DO NOT USE INTERNAL OSCILLATOR, IT IS NOT STABLE ENOUGH FOR SERIAL ' On keyboard connect: VDD to supply; GND to ground; PE3 to RA.0 ' Keyboard seem to work at 5.0V, but 3.3V is recommended. 'KeyboardPin PIN RC.2 INPUT KeyboardPin PIN RB.7 INPUT LED PIN RC OUTPUT keyCode VAR BYTE PROGRAM Start Start: DO SERIN KeyboardPin, N9600, keyCode IF keyCode < $70 THEN IF keyCode = $01 THEN DO SERIN KeyboardPin, N9600, keyCode READ Blue + keyCode, keyCode LOOP UNTIL keyCode <> 0 ELSE DO READ Keys + keyCode, keyCode LOOP UNTIL keyCode <> 0 ENDIF 'WATCH keyCode,1,FSTR [b][color=red]WATCH keyCode,8,SDEC BREAK [/color][/b] 'keyCode = keyCode ' Need an instruction for break to work [b]LED = keyCode[/b] ENDIF LOOP END Keys: DATA 0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ' $00 to $0F DATA "Q","W","E","R","J","K","L",0 ,0 ," ",0 ,0 ,0 ,0 ,0 ,0 ' $10 to $1F DATA 0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,"D","F","G","H",0 ,0 ,0 ,0 ' $20 to $2F DATA 0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ' $30 to $3F DATA 0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,"M","N","B","S","A","P","O"' $40 to $4F DATA 0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ' $50 to $5F DATA 0 ,0 ,0 ,0 ,"V","C","X","Z","I","U","Y","T",0 ,0 ,0 ,0 ' $60 to $6F Blue: DATA 0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ' $00 to $0F DATA "1","2","3","4","'",0 ,"@",0 ,0 ," ",0 ,0 ,0 ,0 ,0 ,0 ' $10 to $1F DATA 0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,"+","-","=",":",0 ,0 ,0 ,0 ' $20 to $2F DATA 0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ' $30 to $3F DATA 0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,".","'","!","/","*","0","9"' $40 to $4F DATA 0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ' $50 to $5F DATA 0 ,0 ,0 ,0 ,"?",")","(","$","8","7","6","5",0 ,0 ,0 ,0 ' $60 to $6F
' Use TKB150P Micro Datapad ' Vcc tied to +5vdc (actually runs on 3.3vdc - but 5vdc works) ' Gnd tied to ground ' PE3 serial tied to RC.2 (or any other available key) Datapadpin PIN RC.2 INPUT 'PE3 serial wire from TKB150P keyCode VAR Byte alpha VAR Byte m_lin1 VAR Byte (8) Datapad FUNC 1, 0 ' Scan the Datapad ' Store 8 characters into m_line1 FOR alpha = 0 TO 7 Datapad m_lin1(alpha) = keyCode NEXT END FUNC Datapad DO SERIN Datapadpin, N9600, keyCode IF keyCode < $70 THEN IF keyCode = $01 THEN DO SERIN Datapadpin, N9600, keyCode READ Blue + keyCode, keyCode LOOP UNTIL keyCode <> 0 ELSE DO READ Keys + keyCode, keyCode LOOP UNTIL keyCode <> 0 ENDIF RETURN keyCode IF keyCode THEN EXIT ENDIF LOOP ENDFUNC Keys: DATA 0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ' $00 to $0F DATA "Q","W","E","R","J","K","L",0 ,0 ," ",0 ,0 ,0 ,0 ,0 ,0 ' $10 to $1F DATA 0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,"D","F","G","H",13 ,0 ,0 ,0 ' $20 to $2F DATA 0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ' $30 to $3F DATA 0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,"M","N","B","S","A","P","O"' $40 to $4F DATA 0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ' $50 to $5F DATA 0 ,0 ,0 ,0 ,"V","C","X","Z","I","U","Y","T",0 ,0 ,0 ,0 ' $60 to $6F Blue: DATA 0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ' $00 to $0F DATA "1","2","3","4","'",0 ,"@",0 ,0 ," ",0 ,0 ,0 ,0 ,0 ,0 ' $10 to $1F DATA 0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,"+","-","=",":",0 ,0 ,0 ,0 ' $20 to $2F DATA 0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ' $30 to $3F DATA 0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,".","'","!","/","*","0","9"' $40 to $4F DATA 0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ' $50 to $5F DATA 0 ,0 ,0 ,0 ,"?",")","(","$","8","7","6","5",0 ,0 ,0 ,0 ' $60 to $6F
I just want to ask if someone has any of these "Micro DataPad Mini Keyboard for Palm PDA m100/m105 Series" left, mentioned here:
http://forums.parallax.com/showthread.php?p=702548
Does anybody like to sell 2 or 3 pieces?
I live in Germany, how much would it cost including shipping costs?
Please contact me via PM.
Thank you.
Greetings
Michael
Here is the info that I have about them.
Bean
' from Prop forum, by Johm Abishier ' by H Shanko rev. 9:30 am 28 Feb.2011 CON Rxpin = 0 _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 #0, lc, fn, caps OBJ tv : "TV_Text" sio : "FullDuplexSerial" vp : "Conduit" ' transfers data to/from PC, 1 cog qs : "QuickSample" ' captures INA, variables, 1 cog @20 MHz VAR long stack[200], frame[400], char, junk1, junk2, state, idx, outchar PUB Main vp.register(qs.sampleINA(@frame,1)) 'sample INA w/ 1 cog up to 20 MHz (MUST BE COG 0) optional_configure_viewport ' optionally configure Viewport's interface vp.share(@char,@outchar) 'share memory from 'key' to 'id'; END of VP commands <<=== tv.start(12) sio.start(Rxpin,-1,1,9600) state := lc tv.str(string(" M105 Keypad/Prop I xlator - 1 Mar.2011",13)) repeat ' tv.out($00) ' clear screen ??? tv.str(string("Type a char",13)) ' ReadChars case state lc: ReadChars if char == $1 ' if 'lc' and 'Fn', 'upper case' (=blue keycap symbols) state := fn else idx := lookdown(char: $10,$11,$12,$13,$6B,$6A,$69,$68,$4F,$4E,$4D,$4C,$28,$29,$2A,$2B,$14,$15,$16,$17,{ }$01,$67,$66,$65,$64,$4B,$4A,$49,$48,$2C,$2D,$2F,$2E,$18,$19,$19,$1A,$1B,$62,$63) outchar := lookup(idx: "qwertyuiopasdfghjklBFzxcvbnmDELDRP TDMU") fn: ReadChars if char == $19 ' if 'Fn' and 'Space' key, caps (upper-case) mode state := caps elseif char ==$01 ' if 'Fn' and 'uppercase', 'lc' state := lc else idx := lookdown(char: $10,$11,$12,$13,$6B,$6A,$69,$68,$4F,$4E,$4D,$4C,$28,$29,$2A,$2B,$14,$15,$16,$17,{ }$01,$67,$66,$65,$64,$4B,$4A,$49,$48,$2C,$2D,$2F,$2E,$18,$19,$19,$1A,$1B,$62,$63) outchar := lookup(idx: "1234567890*/+-=:'",$22,"@BF$()?!,.DELDRP TDMU") caps: ReadChars if char == $1 ' if 'caps' and 'Fn', 'lc' state := lc else idx := lookdown(char: $10,$11,$12,$13,$6B,$6A,$69,$68,$4F,$4E,$4D,$4C,$28,$29,$2A,$2B,$14,$15,$16,$17,{ }$01,$67,$66,$65,$64,$4B,$4A,$49,$48,$2C,$2D,$2F,$2E,$18,$19,$19,$1A,$1B,$62,$63) outchar := lookup(idx: "QWERTYUIOPASDFGHJKLBFZXCVBNMDELDRP TDMU") tv.str(string(", the character is: ")) tv.out(outchar) tv.str(string(" = hex ")) tv.hex(outchar,2) tv.out(13) ' waitcnt(CLKFREQ + cnt) PRI ReadChars char := sio.rx junk1 := sio.rx junk2 := sio.rx tv.hex(char,2) tv.out(32) tv.hex(junk1,2) tv.out(32) tv.hex(junk2,2) ' tv.out(13) return '+-------------------------------------------------------------------------------------+ PUB optional_configure_viewport vp.config(string("var:io(bits=[all[0..29],30tx,31rx])")) vp.config(string("var:io,key,id")) ' show these VARs vp.config(string("lsa:view=io,timescale=200ns,trigger=io[8]f")) ' trig on A8 falling vp.config(string("edit:key(default=5,mode=text)")) vp.config(string("start:lsa")) '+-------------------------------------------------------------------------------------+
If not, why not?
OBC
