Looking for a (tilt?) sensor.
I'm searching for a very cheap and small sensor to use in a POV wand. The idea is to sense the abrupt change in direction when you wave the wand back and forth. I found a couple inclinometers but reading the data sheets, I don't think they would like operation above 10 hz.
A SPDT reed switch that has both poles normally open might work but I can't find such a thing.
What should I be looking for?
Rich H
Rich H
www.goldmine-elec-products.com/prodinfo.asp?number=G16881
Mike2545
This message sent to you on 100% recycled electrons.
Rich H
- Stephen
Maybe so. They aren't that expensive, I was hoping for something under a buck and not quite as fancy.
Rich H
edit: found a freescale 3 axis accelerometer with an SPI interface for $2!
Post Edited (W9GFO) : 8/3/2009 12:13:00 AM GMT
This has the disadvantage, for these forums anyway, of being simple, reliable, and inexpensive. Such properties almost disqualify it here. But you can overcome that by, perhaps, gold-plating everything.
Of course, if you're determinedly resolved to enrich the manufacturers of accelerometers and associated circuitry, you can simply order their products and have them delivered straight to the landfill, saving time and effort.
· -- Carl, nn5i@arrl.net
Post Edited (Carl Hayes) : 8/3/2009 10:50:24 PM GMT
That is essentially what I was looking for, but in a component form.
So $2 accelerometers deserve to go to the landfill but disfigured paperclips safety pins and repurposed fishing weights don't?
What if I gold plate the accelerometer?
Rich H
Post Edited (W9GFO) : 8/4/2009 11:44:12 PM GMT
Whit+
My point was that those who insist on doing everything in the most expensive possible way might still want to spend for an accelerometer -- let's not forget the associated circuitry, which is not free -- and these people can still use the inexpensive solution but might find their houses cluttered with unemployed accelerometers and circuitry to run them.· The landfill is a solution to that.
Of course,· instead of buying accelerometers they could instead send the money to the landfill directly.· This would have the same ultimate effect as actually using an accelerometer where it isn't needed.
Alas, the spirit of homebrew has atrophied, and the safety-pin industry must languish in desuetude, or else fall back upon dry cleaners, and·parents of toddlers, to provide a market.
Rich H
73 OM
