Looking for a (tilt?) sensor. — Parallax Forums
W9GFOW9GFO Posts: 4,010
edited 2009-08-05 00:27 in General Discussion
I'm searching for a very cheap and small sensor to use in a POV wand. The idea is to sense the abrupt change in direction when you wave the wand back and forth. I found a couple inclinometers but reading the data sheets, I don't think they would like operation above 10 hz.
A SPDT reed switch that has both poles normally open might work but I can't find such a thing.
What should I be looking for?
Rich H
  • Mike2545Mike2545 Posts: 433
    edited 2009-08-02 19:56
    If you just want to detect movement then something like this might work:
    www.goldmine-elec-products.com/prodinfo.asp?number=G16881
    Mike2545
    This message sent to you on 100% recycled electrons.
  • W9GFOW9GFO Posts: 4,010
    edited 2009-08-02 20:29
    That's close. The problem I see with that one is that it can't tell which way it is tilted, only if it is tilted.
    Rich H
    edited 2009-08-02 22:14
    An accelerometer is probably what you will need.
    - Stephen
    edited 2009-08-02 23:08
    Franklin said...
    Maybe so. They aren't that expensive, I was hoping for something under a buck and not quite as fancy.
    Rich H
    edit: found a freescale 3 axis accelerometer with an SPI interface for $2!
    Post Edited (W9GFO) : 8/3/2009 12:13:00 AM GMT
  • Carl HayesCarl Hayes Posts: 841
    edited 2009-08-03 22:44
    Why not use a small weight on the end of a small straight spring, and contacts surrounding it? Make the spring from something like a safety pin (straightened out), mount one end solidly, and ground it. Put a weight (fishing sinker) on the free end. Put contacts (perhaps made from, for example, other safety pins) around the free, weighted end of the spring, separated by a small distance that determines the sensitivity. When it's not waving about, the spring is not deflected and none of the surrounding contacts are grounded. When you wave it about, the spring gets deflected because of the weight on the end, and hits one of the contacts, grounding it.
    This has the disadvantage, for these forums anyway, of being simple, reliable, and inexpensive. Such properties almost disqualify it here. But you can overcome that by, perhaps, gold-plating everything.
    Of course, if you're determinedly resolved to enrich the manufacturers of accelerometers and associated circuitry, you can simply order their products and have them delivered straight to the landfill, saving time and effort.
    · -- Carl, nn5i@arrl.net
    Post Edited (Carl Hayes) : 8/3/2009 10:50:24 PM GMT
    edited 2009-08-04 20:26
    Carl Hayes said...
    That is essentially what I was looking for, but in a component form.
    Carl Hayes said...
    So $2 accelerometers deserve to go to the landfill but disfigured paperclips safety pins and repurposed fishing weights don't?
    Rich H
    Post Edited (W9GFO) : 8/4/2009 11:44:12 PM GMT
  • WhitWhit Posts: 4,191
    edited 2009-08-04 20:34
    You might find a damaged Wii controller at a yard sale or thrift shop.
    Whit+
    edited 2009-08-04 22:29
    W9GFO said...
    Carl Hayes said...
    Carl Hayes said...
    So $2 accelerometers deserve to go to the landfill but disfigured paperclips and repurposed fishing weights don't?
    Rich H
    No, not at all.· But when you want only to sense the existence, rather than to measure·the magnitude, of an acceleration, a safety pin and fishing weight are considerably cheaper.· And who said anything about paper clips?· Not I.· Paper clips are made from steel that's inferior to that in safety pins.
    My point was that those who insist on doing everything in the most expensive possible way might still want to spend for an accelerometer -- let's not forget the associated circuitry, which is not free -- and these people can still use the inexpensive solution but might find their houses cluttered with unemployed accelerometers and circuitry to run them.· The landfill is a solution to that.
    Of course,· instead of buying accelerometers they could instead send the money to the landfill directly.· This would have the same ultimate effect as actually using an accelerometer where it isn't needed.
    Alas, the spirit of homebrew has atrophied, and the safety-pin industry must languish in desuetude, or else fall back upon dry cleaners, and·parents of toddlers, to provide a market.
    edited 2009-08-04 23:49
    Funny, I was thinking safety pins but wrote paper clips...
    Rich H
    Not as bad as me, though. I've got to proofread everything I write, or I'll write of paper pins and safety clips --
    73 OM
