Mini LCD - Portable A/V display
Hi all,
Just grabbed one of the Mini LCDs that Parallax offers, and also one of their breadboard mountable RCA ports, hoping to get some video output happening, but for the life of me I can't get a picture up on the screen. It says on the store page that the screen needs a 12VDC power input, but the RCA port has no power input. It just has signal and ground. The signal is going to my propeller which is running at 3.3VDC, and I don't see any power jacks on the screen itself... Am I doing something wrong here?
Who are you, and why are you reading my signature?
Which Mini LCD do you have? I mean, what is the item code number. Each type has a downloadable pdf documentation sheet. For example, the 2 X 16 Serial LCD (Non-Backlit) - Item code 27976, the documentation is here -http://www.parallax.com/Portals/0/Downloads/docs/prod/audiovis/SerialLCD-v2.0.pdf
The documentation should show you how to connect the LCD and give you lots of other useful information.
Hope this helps.
Edit - I see from Mike's comment that you are talking about the Mini LCD A/V Color Display - Item Code 603-32000. Sorry for the confusion!
Whit+
Post Edited (Whit) : 8/4/2009 2:08:01 PM GMT
Mike, you're right. I was looking on the device itself, but the power jack is on the cable! Blonde moment!!!
