Powering LED with 12 & 9 volts
Hello,
Can anybody tell me what resistor value I would need to power a LED from;
12 volt power source?
9 volt power source?
Thank you
E
Thank you
E
Rich H
- Stephen
No one can tell you that, unless you first tell them what current you desire through the LED, and what the voltage drop is across the LED at that current.
· -- Carl, nn5i@arrl.net
Next you have to figure out the current you want based on the diode itself and how much light you want. For discussion, let's say 10mA. Ohm's Law gives R = E / I = 10.3V / 0.01A = 1030 Ohms. The closest standard value is 1K. The power dissipation is P = E * I = 10.3V * 0.01A = 1/10W. I'd suggest a 1/4W resistor.
my question has been answered precisely. I understand the equation now well enough (Mike) to derive the answers I need.
