Powering LED with 12 & 9 volts — Parallax Forums
EugalazEugalaz Posts: 39
edited 2009-08-04 02:54 in General Discussion
Hello,
Can anybody tell me what resistor value I would need to power a LED from;
12 volt power source?
9 volt power source?
Thank you
E
  • W9GFOW9GFO Posts: 4,010
    edited 2009-08-04 02:41
    Rich H
    edited 2009-08-04 02:44
    It depends on the LED. Each type is different and the datasheet will give you voltage and current requirements/limits.
    - Stephen
  • Carl HayesCarl Hayes Posts: 841
    edited 2009-08-04 02:46
    Eugalaz said...
    Hello,
    Thank you
    E
    No.· Nobody can tell you that, which is a complete answer to the question you asked.·
    No one can tell you that, unless you first tell them what current you desire through the LED, and what the voltage drop is across the LED at that current.
    · -- Carl, nn5i@arrl.net
    edited 2009-08-04 02:47
    You should be able to figure this out yourself using Ohm's Law. First, you have to find out the forward voltage of the diode. It can range anywhere from 1.7V for a red LED to as much as over 3V for some blue or white LEDs. Say it's a red LED with a forward voltage of 1.7V. With a 12V supply, the resistor has to drop 12V - 1.7V = 10.3V.
    Next you have to figure out the current you want based on the diode itself and how much light you want. For discussion, let's say 10mA. Ohm's Law gives R = E / I = 10.3V / 0.01A = 1030 Ohms. The closest standard value is 1K. The power dissipation is P = E * I = 10.3V * 0.01A = 1/10W. I'd suggest a 1/4W resistor.
  • EugalazEugalaz Posts: 39
    Thank you everyone,
    my question has been answered precisely. I understand the equation now well enough (Mike) to derive the answers I need.
