Thermocouple interfaced with Basic Stamp 2
I want to use a K type thermocouple to control the temperature of a lead melting pot. The temperature would need to hover around 750 degrees F. I noticed that when the Parallax thermocouple kit is used, a BS2P is required. I have several BS2 IC's and I wish to use one of these and not have to purchase an additional microcontroller. Is there a way to use the BS2 to control the heater via an SSR ? Perhaps there is an available interface chip that would go between the BS2 and the thermocouple that would allow the use of the microcontroller I already have? Also, does anyone know the reason that the Parallax thermocouple kit REQUIRES the BS2P microcontroller?
Showing up to school doesn't·mean you are a student any more than crawling up in an oven means that·you are a biscuit.
Another good chip that interfaces easily with any Stamp using SHIFTIN and SHIFTOUTis the MAX6675.
Tracy Allen
www.emesystems.com
I have one of these kit from Parallax but have not used it yet
Can you tell how stable Parallax thermocouple kit is
··Thanks for any·
Sam
