Thermocouple interfaced with Basic Stamp 2 — Parallax Forums
CogburnCogburn Posts: 62
edited 2009-08-02 01:07 in BASIC Stamp
I want to use a K type thermocouple to control the temperature of a lead melting pot. The temperature would need to hover around 750 degrees F. I noticed that when the Parallax thermocouple kit is used, a BS2P is required. I have several BS2 IC's and I wish to use one of these and not have to purchase an additional microcontroller. Is there a way to use the BS2 to control the heater via an SSR ? Perhaps there is an available interface chip that would go between the BS2 and the thermocouple that would allow the use of the microcontroller I already have? Also, does anyone know the reason that the Parallax thermocouple kit REQUIRES the BS2P microcontroller?
Showing up to school doesn't·mean you are a student any more than crawling up in an oven means that·you are a biscuit.
  • Tracy AllenTracy Allen Posts: 6,656
    edited 2009-08-02 00:07
    The Parallax kit uses the one-wire interface, and the OWIN and OWOUT are only available on the BS2p series.
    Another good chip that interfaces easily with any Stamp using SHIFTIN and SHIFTOUTis the MAX6675.
    Tracy Allen
    www.emesystems.com
    edited 2009-08-02 00:39
    Tracy Allen
    I have one of these kit from Parallax but have not used it yet
    Can you tell how stable Parallax thermocouple kit is
    ··Thanks for any·idea.gif·that you may have and all of your time finding them smile.gif
    Sam
  • CogburnCogburn Posts: 62
    Thanks Tracy- I will order the maxim chip
