Replacing a potentiometer — Parallax Forums
dev/nulldev/null Posts: 381
edited 2009-07-31 11:56 in General Discussion
Hi,
How can I replace a potentiometer as shown in this circuit?
The circuit is a DC motor controller with a 100k pot. I want to use Stamp to control the resistance with an AD5220 digital potentiometer.
Do I connect the ground of the circuit to the ground of the Stamp, and then A, W, and B terminals to the circuit?
Thanks.
Don't worry. Be happy
  • Greg LaPollaGreg LaPolla Posts: 325
    edited 2009-07-31 04:58
    The VDD and Ground should go to the stamp side so that your cs, clock and data pins will work.
    I believe the What is a Micro Controller Book has a section on using digital pots.
    Greg
  • dev/nulldev/null Posts: 381
    Thanks. The examples from Parallax are with only one voltage source, I will try and see.
