Do·I need to use a 5 volt regulator with the propeller chip if I am only using the chip for video output, or can I get by with just the 3.3 volt regulator?·
If you are not going to use a PS/2 keyboard or mouse, you can usually get away without the +5V (some old monitors may need it)
ksam said...
Do I need to use a 5 volt regulator with the propeller chip if I am only using the chip for video output, or can I get by with just the 3.3 volt regulator?
www.mikronauts.com - my site 6.250MHz custom Crystals for running Propellers at 100MHz
Las - Large model assembler for the Propeller Largos - a feature full nano operating system for the Propeller
Morpheus & Mem+ Advanced dual Propeller SBC with XMM and 256 Color VGA
Please use mikronauts _at_ gmail _dot_ com to contact me off-forum, my PM is almost totally full
They often have very low parameters as though they assume that there will be a pre-regulator
Style and grace : Nil point
