Is LMM supported in any way by Parallax ?
I've been looking on the Parallax site for some LMM info, but I don't see any.
Does Parallax support LMM in any way ?
Do they plan to support LMM in the Propeller IDE ?
Is there a "standard" LMM implementation ?
Bean.
Does that byte of memory hold "A", 65, $41 or %01000001 ?
Yes it does...
Bean.
Yes it does...
The most information is in the thread where I announced LMM; I actually have some written docs that I can't publish until after they show up in a magazine.
They added ORGX to the IDE, but it is still extremely painful to write LMM with the IDE
No idea, maybe ask Jeff Martin or Chip
I defined a minimal implementation when I came up with it, I am working (a bit slowly due to getting Morpheus off the ground) on a "standard" LMM for Largos.
You should check out LAS on my downloads page, it makes writing LMM code easy. There will be a new release of LAS in one to two months, with macro's and the expression evaluator re-enabled.
Bill
www.mikronauts.com - my site 6.250MHz custom Crystals for running Propellers at 100MHz
Las - Large model assembler for the Propeller Largos - a feature full nano operating system for the Propeller
Morpheus & Mem+ Advanced dual Propeller SBC with XMM and 256 Color VGA
Please use mikronauts _at_ gmail _dot_ com to contact me off-forum, my PM is almost totally full
Parallax Inc.
This is not related to the BASIC->SPIN compiler.
I was thinking that LMM was supported by the IDE, but then I couldn't find any info on it. I think I was confused because the C compiler uses LMM.
Bean.
Yes it does...
http://forums.parallax.com/showthread.php?p=615022
Almost 2 years old...No wonder I couldn't find it.
Bean.
Yes it does...
Yeah, time flies when you are catching your honey, get engaged, and married [noparse]:)[/noparse]
There is also quite a bit of info on LMM on the propeller wiki:
propeller.wikispaces.com/Large+Memory+Model
Visit some of my articles at Propeller Wiki:
MATH on the propeller propeller.wikispaces.com/MATH
pPropQL: propeller.wikispaces.com/pPropQL
pPropQL020: propeller.wikispaces.com/pPropQL020
OMU for the pPropQL/020 propeller.wikispaces.com/OMU
http://imagecraft.wordpress.com/2008/08/27/parallax-propeller-and-the-propeller-c-compiler/
// richard
I am going to ask some·question that may be stupid but I am just starting with PASM and
am not up to par with it.....
with this code
nxt···· rdlong·· instr,pc
········ add······pc,#4
instr···nop····· ' placeholder!
········ jmp····· nxt
what happens if the code that is placed in the place holder is a JMP?
How would the code come back to the "Jmp nxt" line·and how would the code
placed in the place holder·that is a JMP itself be executed since its jump location
is not even in the cog in the first place???
Or is it that you are suggesting that only SPECIAL instructions are used to replace Jmp
and other PASM equivalents???
But then how does the code above distinguish these special opcodes from the PASM ones
when the code in the place holder it is executed??
Sam
Good questions... LMM does not use the normal jumps, except to call functions resident in the kernel.
You can do relative jumps by using sub/add
ie
to jump back: sub pc,#4*numlongsback
to jump forward: add pc,#4*numlongs
also there is a special kernel routine FJMP that uses the long after the instruction for the LMM address to jump to. My assembler automatically uses the regular jump or an FJMP.
Kernel routines continue executing LMM code with a "JMP #NEXT"
You should try LAS - it makes writing LMM code pretty easy, also you may wish to get comfortable with regular PASM before tackling any significant LMM code.
Hope this helps.
Bill
For relative jumps close to the current instruction location, you'd use "SUB PC,#xxx" to jump backwards up to 512 bytes (128 instructions) from the following instruction or "ADD PC,#xxx" to jump forwards up to 128 instructions. These can be conditional which is really handy for loops of different kinds or IF statements.
If the jump is further, you'd have to use an LMM interpreter subroutine that would possibly fetch the content of the next word or long and load it into PC or skip it. There are tricks with NOPs where you could embed a 16 or even 18 bit address in a NOP so you could conditionally call an LMM subroutine that would load the address from the least significant 18 bits of the next instruction. If the subroutine call is not executed, the NOP would be skipped as well (with a short delay).
Thanks guys....I now understand.....I am still learning PASM, but this LMM idea is great.
I do not need anything like this at my level....but it is great to know about it and file it
in the back of my mind for the future....of course that is assuming the back of my mind
is still able to hold any memory that far in the future.....I noticed that it is leaking a lot
recently and I have been meaning to fix the leak....but that was filed in the back of my mind....
What was·I talking about????
Seriously......it is a great testament to the design of the propeller that such memory
copying and manipulating makes it possible for such great ideas to be implemented.
I am loving the propeller everyday more and more.
Thanks Bill and everyone who has such a wonderful mind that makes me feel so humble
when I read this forum.....keep up the great work.....
Samuel
P.S. I just had a thought....couldn't a normal PASM program be able to extend itself
to utilize full RAM by just copying chunks of code as needed to fit in the cog RAM?
i.e. similar idea to the LMM but done on chunks basis instead of opcode basis and thus
that way Jmp etc. can still be the same but the code "chunks" have to be designed
with care to inter-chunks looping?????
Yes, it would be possible to make a "paging" cog, and I believe some people have tried it (Ale? Mike? Phil?) however my gut feeling is that LMM would be faster overall (at least if you also use FCACHE and unroll the inner loop of the kernel four ways); the reason is that paging the cog code would be slower for "in-line non-looping code" because even with an optimal reverse loading, it would take 16 cycles to fetch each long, and four (or more) cycles to execute it - whereas a four-way unrolled LMM kernel averages in-line instructions in 18 clock cycles - 10% faster. On the other hand, paging loads loops faster than the current FCACHE... win some, lose some.
Best,
Bill
· Home of the MultiBladeProps: TriBladeProp, RamBlade, TwinBlade,·SixBlade, website
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80), MoCog (6809)
It seems to run on the Prop demo board (flashes all the LEDs).
Bean
Yes it does...
Basically ok. But the way you do the FAR jump means you couldn't have any code after the jump - which is ok for unconditional jumps, but wouldn't work in conditional cases. To do that you need to call a function built into the kernel (i.e. what you call the "LMM Execution code"). For an example, see any of the LMM or XMM Kernels in the Catalina source code. Or Bill's original LMM code.
Ross.
- instead of RDLONG PC,PC with a LONG address following, your loop is small enough for
SUB PC,#20 ' five longs back which saves a long of memory and some cycles [noparse]:)[/noparse]
and actually as long as 18 bits of address is enough, by setting the upper fourteen bits of the LONG following the RDLONG PC,PC it would be treated as a NOP if executed due to conditions being placed on the RDLONG
Post Edited (Bill Henning) : 7/30/2009 12:46:17 AM GMT
· The LONG data will always be less than 18 bits, so the condition code will be 0000 which means NEVER execute. So I don't see why it would matter if the RDLONG PC,PC had a condition or not ?
Bill,
· Yes I see what you mean.
I tried to find the LMM execution code, but I could find it in either LAS or Catalina. In a way I'm trying NOT to see how other have done it. If I find another way, it might spark further development.
Bean.
Yes it does...
That's true if you are limiting yourself to 256Kb - but you already need at least 20 bits to address most XMM memory currently available (some require up to 24 bits).
The LMM execution code in Catalina is in the kernel files, which are in the target directories - e.g. LMM_Kernel.spin. But I can understand you may not want to be influenced by what others have done and instead develop your own solution.
Ross.
Yes, I had I thought of that - but most memory is byte addressable, and having to shift the address on every fetch doesn''t seem like a good solution.
I was going to modify the Hydra Xtreme to make it long addressable to overcome the original 64k addressing limitation, but in the end I didn't because epmoyer had already made it fully byte addressable - but it takes 19 bits.
Ross.
Is this going to be a Largos model? Interesting - I've pretty much decided that the next model Catalina will support will be 16Mb combined code/data/heap - but only 32kb stack. This is by far the simplest model to implement, but it's not (well, not entirely) just laziness on my part - for frame-based procedural languages it is also likely to be the fastest model, since these languages (like C) need fast access to the stack because that's where all the local variables are.
This will still be a bit limiting on the Prop I, but the Prop II it will become 16Mb/256Kb which will work out quite well.
Ross.
Post Edited (Phil Pilgrim (PhiPi)) : 7/30/2009 5:21:21 AM GMT
That's just too darned clever! I feel sorry for all those people who may one day try to read the resulting code to try to figure out what the heck is going on!
Ross.
Of course the fetch mechanism will be different for XMM. Not sure of the impact if the rdlong has bit 31 set (for hub fetching).
Post Edited (Cluso99) : 7/30/2009 7:20:26 AM GMT
While I'd prefer a clean 32 bit linear address space, I really like Phil's trick which allows conditional jumps/loads/calls in an 8MB space.
I REALLY like Catalina supporting a 16MB flat space with only the stack in the hub - don't change that plan! It would let me use Catalina to compile a "native" version of LAS, and hopefully Catalina!
What I was going to do if the jump was not in ADD/SUB PC range:
if_NOTcond ADD PC,#8
RDLONG PC,PC
LONG addr
Now life will be more complicated, but better - birds will sing, the sun will shine, and everyone (except compiler writers) will be happy:
if address is within +- 128 longs
add/sub pc,#offset
if address is within first 8MB of expanded memory space:
if_cond RDLONG PC,PC
LONG $80000000+addr+condition_code
if address > 8MB
RDLONG PC,PC
LONG addr
However before compiler writers shoot me, please be advised that next version of LAS will make above totally transparent, just requiring the following in the code:
if_cond JMP #address
If the address is already known, it will generate the optimal jump, if it is not know, it will default to the two-long trick version; it will need an option to use the three word version.
LAS is a one pass assembler, so it does not know until the destination label is defined how many longs it would need to use to reach it.
Post Edited (Bill Henning) : 7/30/2009 12:56:40 PM GMT
Composite NTSC sprite driver: Forum
NTSC & PAL driver templates: ObEx Forum
OnePinTVText driver: ObEx Forum
Post Edited (ericball) : 7/31/2009 6:15:28 PM GMT
