Propeller Kit
I have a propller kit and have it mostly togther but can't figure out where to put the capacitors.
Where do I connect the capacitors on the board?
What page of the book has the instruction?
Book - Propeller Education Kit Labs: Fundamentals
1) Propeller Microcontroller and Labs Overview
2) Software Documentation and Resources
3) Setup and Testing Lab for 40-Pin DIP PE Platform
4) I/O and Timing Basics
5) Methods and Cogs
6) Objects
7) Counter Modules and Circuit Applications
www.parallax.com/Portals/0/Downloads/docs/prod/prop/PELabsFunBook-v1.1.pdf
Post Edited (AIman) : 7/27/2009 2:27:18 PM GMT
If I battery power the demo board, would the capacitors be in the way or would they have to be removed?· What would the proper DC voltage be?
You can add more caps. ...
BUT never remove any.
Them have its function in that place... And are not bare for at it will looks GOOD!
For every stupid question there is at least one intelligent answer.
Don't guess - ask instead.
If you don't ask you won't know.
If your gonna construct something, make it·as simple as·possible yet as versatile as posible.
Sapieha
Instead look for the 'line' or minus strip on the side of the capacitor. This will be on the side with the negetive lead. Sometimes the line is even a different color.
Always observe polarity for a capacitor (unless it is bipolor) or it will fail!
