Propeller Kit — Parallax Forums
Propeller Kit
AImanAIman Posts: 531
edited 2009-07-27 22:08 in Propeller 1
I have a propller kit and have it mostly togther but can't figure out where to put the capacitors.
Where do I connect the capacitors on the board?
  • ksamksam Posts: 19
    edited 2009-07-20 15:10
    the (2) 1000 uf capacitors come off of the voltage regulators.·· The positive side of each is connectected to the out side of each regulator and the other side is grounded.· The .47 uf capacitor is for if you are using a power source that plugs into the wall.
  • AImanAIman Posts: 531
    edited 2009-07-22 15:05
    In other words, make sure the wires on the capacitor match the holes were the regulators are?
    edited 2009-07-22 15:39
    Sort of ... the regulators have 3 terminals and the capacitors have 2 terminals. It's important which 2 of the 3 terminals you use for the capacitors. Follow the assembly directions.
    edited 2009-07-26 23:00
    Ok, I am confused. I haven't seen the instructions in the·PE Kit book·and the pictures aren't clear to me.
    What page of the book has the instruction?
  • hinvhinv Posts: 1,256
    edited 2009-07-26 23:07
    Below is what you need. #3
    Book - Propeller Education Kit Labs: Fundamentals
    1) Propeller Microcontroller and Labs Overview
    2) Software Documentation and Resources
    3) Setup and Testing Lab for 40-Pin DIP PE Platform
    4) I/O and Timing Basics
    5) Methods and Cogs
    6) Objects
    7) Counter Modules and Circuit Applications
    www.parallax.com/Portals/0/Downloads/docs/prod/prop/PELabsFunBook-v1.1.pdf
    edited 2009-07-27 14:11
    To be clear, the 6.3v capacitor goes long side to hole 1 and the other to hole 3 and the 25v goes·to hole k5 and the long side·to J6?
    Post Edited (AIman) : 7/27/2009 2:27:18 PM GMT
  • edited 2009-07-27 15:52
    ksam said...
    I took my power supply to Radio Shack and I didn't realize how hard this would be but they said I needed to have the board that the plug goes into to find a match because they have a fist full of plugs.· I found that plug N seems to fit well enough but they are out of them.
    If I battery power the demo board, would the capacitors be in the way or would they have to be removed?· What would the proper DC voltage be?
  • SapiehaSapieha Posts: 2,964
    edited 2009-07-27 18:54
    Hi Chuckz.
    You can add more caps. ...
    BUT never remove any.
    Them have its function in that place... And are not bare for at it will looks GOOD!
    Nothing is impossible, there are only different degrees of difficulty.
    For every stupid question there is at least one intelligent answer.
    Don't guess - ask instead.
    If you don't ask you won't know.
    If your gonna construct something, make it·as simple as·possible yet as versatile as posible.
    Sapieha
  • JomsJoms Posts: 279
    Do not really rely on which lead is longer. I have seen many components, LEDs, Caps, etc. that have been wrong.
    Instead look for the 'line' or minus strip on the side of the capacitor. This will be on the side with the negetive lead. Sometimes the line is even a different color.
    Always observe polarity for a capacitor (unless it is bipolor) or it will fail!
