HYDRA-Net versus USB ports
Can anyone tell me the original purpose of the HYDRA-Net port? Was it simply to connect two HYDRAs together? Can it be used to connect a HYDRA to a PC? Perhaps using an adapter cable? Or would using the mini USB connection be better suited for this task? I am interested in using my PC to connect the HYDRA to the internet. I don't really want to buy any other hardware at this time. It seems like an ethernet port would have been much more useful. Maybe I can just manipulate the Hydra through a virtual COM port on the PC? I have seen various software packages that act as "servers", i.e., routing telnet data from an ethernet port to a device via a NULL modem cable. Could I do this with the virtual COM port?
Also, where do you buy cross-over phone cables, or do I have to make one myself?
Can anyone tell me the difference between the mini USB port and the four pin USB2SER port on the Hydra? Thanks.
Jeff
Jeff
Chris Savage
Parallax Engineering
Edit: As for the original purpose of the HYDRA-NET ports, they're for HYDRA-to-HYDRA communications. I wrote a two-player BattleZone clone (search this forum) that uses them.
