HYDRA-Net versus USB ports — Parallax Forums
gonzobrainsgonzobrains Posts: 27
edited 2009-07-28 01:06 in Propeller 1
Can anyone tell me the original purpose of the HYDRA-Net port? Was it simply to connect two HYDRAs together? Can it be used to connect a HYDRA to a PC? Perhaps using an adapter cable? Or would using the mini USB connection be better suited for this task? I am interested in using my PC to connect the HYDRA to the internet. I don't really want to buy any other hardware at this time. It seems like an ethernet port would have been much more useful. Maybe I can just manipulate the Hydra through a virtual COM port on the PC? I have seen various software packages that act as "servers", i.e., routing telnet data from an ethernet port to a device via a NULL modem cable. Could I do this with the virtual COM port?
Also, where do you buy cross-over phone cables, or do I have to make one myself?
Can anyone tell me the difference between the mini USB port and the four pin USB2SER port on the Hydra? Thanks.
Jeff
  • FredBlaisFredBlais Posts: 389
    edited 2009-07-26 15:22
    Most of your questions can be answered by reading the book that came with your hydra. For connecting to the internet, I suggest you buy the ethernet module for the hydra that connects in the cartridge port, there is an API for it so it's really easy to use. I use it to do some http request to my server and GET some php file, so I can toggle the debug led by clicking a button on a webpage, you can do pretty cool stuff. If you don't want to buy anything, you could write a C program and interface it with RS-232. Just add a MAX232 or similar to your experimenter card [noparse]:)[/noparse]
  • gonzobrainsgonzobrains Posts: 27
    edited 2009-07-26 19:24
    Thanks. I am reading that book at the moment. I already read chapter four, which is why I am asking for greater clarification. The kit didn't contain a cable for connecting to the four-pin USB2SER connector. All I have is the USB cable for connecting to the PC in order to send programs using the Propeller tool. And, having already shelled out $200 for this kit, as much as I would like to use that ethernet module I don't wanna spend another 60 bucks or whatever for add-ons at this time. What are the options I have right out of the box?
    edited 2009-07-27 17:17
    Your duplicate post has been removed.
    Parallax Engineering
  • mparkmpark Posts: 1,336
    After you send a program down the USB cable, you are free to use the USB as a serial connection to your PC. On the PC side you'll need a program that talks to a COM port. On the HYDRA side you could use the FullDuplexSerial object (for example) to send and receive over pins 30/31.
    Edit: As for the original purpose of the HYDRA-NET ports, they're for HYDRA-to-HYDRA communications. I wrote a two-player BattleZone clone (search this forum) that uses them.
