bad aftermarket Nintendo controllers — Parallax Forums
gonzobrainsgonzobrains Posts: 27
edited 2009-07-29 13:23 in Propeller 1
Did anyone have any problems trying to connect the aftermarket Nintendo controllers that came with their Hydra? I bought a Hydra kit a few months back from Fry's Electronics. They plugs would not fit into the sockets on the board. I ended up visiting the local swap meet to pick up some old school originals which work fine.
I tried emailing support about getting replacements but nobody answered me.
Jeff
  • Spork FrogSpork Frog Posts: 212
    edited 2009-07-26 12:48
    The connectors for the controllers, for whatever reason, are very stiff out of the box. This is a known issue; inserting and removing the controller a few times usually does the trick (but put something like a book under the system PCB so you don't snap the board.)
  • gonzobrainsgonzobrains Posts: 27
    edited 2009-07-26 14:59
    they were seriously too hard to insert. i already tried your suggestion. I really felt like I was going to break something, so i bought original ones instead. inserting standard nintendo controllers was a piece of cake. is that because the original controllers were old and worn? will i have this same problem if i bought new controllers?
    these aftermarket ones are kinda of cheap anyway.
    edited 2009-07-26 23:16
    Again, it's normal. You have to push pretty hard to get them in there. Indeed, the older controllers if nothing else are made of old plastic which has undoubtedly softened over time.
  • RossHRossH Posts: 5,737
    edited 2009-07-27 01:14
    @gonzobrains,
    I had the same experience - but BFI (Brute Force and Ignorance) soon sorted it out.
    Ross.
  • CardboardGuruCardboardGuru Posts: 443
    Once I'd applied brute force and ignorance to mine, I left the controller connected. I never unplug it, just wrap the cable around the PCB when I put it away.
    Help to build the Propeller wiki - propeller.wikispaces.com
    Play Defender - Propeller version of the classic game
