Soldering Challenge: How would you solder THESE??? — Parallax Forums
xanatosxanatos Posts: 1,120
edited 2009-07-21 19:43 in General Discussion
The picture says it all.· MAXQ610B's.· Not a job for my trusty Weller....· I need to get set up with a real, high-quality professional soldering method.· Advice?· Suggestions?· Manufacturers and catalog numbers??? :-)
I can make a PC board that will handle these just fine.· Just can't solder 'em...
Dave
    edited 2009-07-20 18:35
    Solder paste, stencil, and toaster oven
    propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
    Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
    Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
    edited 2009-07-20 18:51
    If you go back a couple pages there is a thread on surface mount soldering that should help.
  • xanatosxanatos Posts: 1,120
    edited 2009-07-20 19:06
    Thanks. I've seen these terms before, but I am completely ignorant to these techniques, so I even need to know what a "stencil" is. And you can really toast boards and chips hot enough to solder them but it doesn't harm the components themselves?
    I've squeeked by the past few years with a Weller iron with a tip I made myself that is basically a needle ground into a chisel tip, and with a magnifying glass, I have been able to solder "regular" SMT style chips (like the 74xx series) with fairly nice results... but this item (and likely many more to come) are simply beyond that possibility.
    I'll go find the SM soldering thread. T^hamks!
    Dave
    edited 2009-07-20 19:22
    I found the thread in which you soldered that propeller onto the board - looks like the exact same style of chips I am going to be using - and it looks good!
    There was nothing there about the stencil - which is what I am assuming is what prevents the solder paste from simply forming bridges between those micropads. I will be continuing to check on here, but since you've got hands-on experience doing this apparently well, is there a good tutorial to which you you would refer a beginner in this kind of microsoldering work?
    Dave
    edited 2009-07-20 19:29
    Youtube and instructables both have good tutorials
    Stencils make it easy to put the right amount of solder in the right place. Not absolutely needed but make life easier
    Oharp is I believe were I get mine. Can check on spelling and take some photos of the approach
    Asfor bridging solder natuarly wants to pull together. As long as you don't put to much solder on and you have solder mask on pcb it will not bridge.
  • LeonLeon Posts: 7,620
    edited 2009-07-20 19:30
    I use a large via for the central pad. I then drag-solder the outer pads and solder the central pad by feeding solder in with the soldering iron tip. It's quite easy with the Metcal equipment I use. This is only for prototypes, of course; I get production boards assembled by the specialist company I use.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
  • CounterRotatingPropsCounterRotatingProps Posts: 1,132
    edited 2009-07-20 19:42
    Dave,
    not sure if this is the thread mctrivia mentions, but it's got some more info:
    http://forums.parallax.com/forums/default.aspx?f=15&p=1&m=360823
    edited 2009-07-20 20:07
    Oh yeah! That was the thread. This video really was the one that showed me how the solder paste syringe and pre-heat/reflow stuff works. Nice!
    Thanks very much. Now it's off to find the reflow workstation, paste syringe, etc!
    Dave
    edited 2009-07-21 04:02
    If you use solder paste the stencil needs a grid pattern for the central pad, to stop the chip floating on the molten solder.
    Leon
    I have the advantage of access to an Ersa IR Rework machine. So, I would tin the pads on the part and PCB, apply a tacky rework flux to the pads, place the part, and reflow with the Ersa.
    Without the Ersa, I would use a hot air pencil to reflow the part using the same process.
    Without the hot air pencil, I would determine the need for the exposed pad under the part. If the connection is not critical, I would add some thermal paste for potential heat transfer and solder the leads by hand (even though QFN parts are not designed for handsoldering). If the center pad's connection is critical, I would add conductive thermal paste, then solder by hand. (if the PCB is designed with a hole through the center of the pad, you can do as Leon mentions and solder it through the PCB.
    I currently have a Propstick USB board that is waiting for a new Propeller QFN chip. I'll take pictures of the process and can post if anyone is interested. (after I make it over to Parallax to buy the chip)
    Andrew Williams
    WBA Consulting
    IT / Web / PCB / Audio
