1/2 Price Demo Board
Just to drop a line that the daily deal today is the Propeller Demo Board. 2 for 1!
http://www.parallax.com/Store/Microcontrollers/PropellerDevelopmentBoards/tabid/514/ProductID/340/List/0/Default.aspx?SortField=ProductName,ProductName
The daily deal showed the BS1 programming plug from yesterday for a while, but it finally got updated. If I didn't just get 5 Protboards the other day, I would jump at it!
Jim
Jim
Thanks Jim (and Parallax)! [noparse]:)[/noparse]
Might have to get two...
I have given all my Demo Boards away! (Fixed up a couple from the expo freebie table and they are finding their way to new homes!) Miss not having one for a quick run on some code though.
One stubborn one is still not running... When I get it going, I plan to toss in the 100Mhz Xtal, which is now listed as a related product for the Demo Board, and the Xtal is listed as replaceable. (cool) I'm kind of hoping the 100Mhz demo board gets to be common as well.
Anyway, the demo board is a great getting started with the prop, general purpose board. If you don't have one, get one. This is a good deal. I think I paid more than $100 for my first one way back when. $40 is just a killer price. I always forget to bonk on the daily deal.
Chat in real time with other Propellerheads on IRC #propeller @ freenode.net
Note to Parallax, please update your Power Supply Recommendation Chart to include Propeller products!
You can probably get away with it, but it depends how much hardware your going to hang off of it. That said, I am running a Proto board with a GPS module, uSD 2GB, TV out, and keyboard I/O off of a 6V 300ma wall wort and it works just fine.
BTW, I enjoy running Sphinx off that same board.
Jim
I assume then that all Parallax power supplies use the same connector?
If you have a Radio Shack nearby, you can use their Adapaplug "M" with the many DC power supplies that they offer. I like the 273-155 power supply which·has settings for 6VDC, 7.5VDC, 9VDC or 12VDC·at 2500ma and is regulated and filtered.
The do also have a 300ma supply, 273-028, which has voltage settings of 1.5/3/4.5/6/7.5/9/12VDC , that I use for smaller projects.
Between these two supplies, I can power just about anything·on the bench.
Jim
EDIT: Nevermind- took a gander at the Demo Board schematic that came when I installed the Propeller Tool. Looks like a positive tip is what I need, and what I have.
Props to Parallax's lightning quick fulfillment- I got my two demo boards this morning, having ordered them at 3 PM on Friday. Not too bad! [noparse]:)[/noparse]
Post Edited (RevAaron) : 7/20/2009 6:09:36 PM GMT
Jim
