Sensing an ON condition inductively through a power cord.
LoopyByteloose
I would like to be able to use a Hall Effect transistor to sense when an A/C or TV is running so that I can confirm that it needs to be turned off via transmiting IR to its remote control sensor. Any suggestions of how to build a sensor that can be attached to the outside of the power cords?
The problem is that the remote control toggles ON and OFF and expects a human to be present to observe which condition is present. So I need a redundant system to verify the ON or OFF status.
I can provide a robotic control that both transmits and receives IR. SO the current sensor can provide a signature identity and condition in IR which will help the robotic control.
Ain't gadetry a wonderful thing?
aka G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
In the everyday world, power outlets are distributed about every 3 meters along a wall. That distribution creates a very large barrier to centralized home automation. Unless each outlet were to provide a twist pair that could be fed to a centralized microprocessor for each room, not much could be done.
I'm not ready to rip up baseboard and install wire for this. One day, there may be a commercial market for AC power outlets with built in current sense that feed data for remote monitoring. Someone will make a bundle on it, but not me.
Here take a look at this I think you could use·some or·all of·what they are talking about in you project
Built your Tweet-A-Watt__You take Xbee adapter kit and a Kill·A Watt Meter······
·It starts on page 112
IN··· MAKE Magazine··· Click_Here· ·to read more It will only let you read the first three·page of the magazine I can share it with you if you want me to
just PM me with the Email address that you want to use
Here is where you can a kit with all parts need Click_here
I can not share this with every one·· ·
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 7/11/2009 9:46:46 PM GMT
take a look at the COIL_demo.spin in the prop tool's "library" folder - I've done what pretty much what PrettyBird suggested, but even simpler: just wound a bunch of loops around one line of a power cord and op-amped the signal, but, as he mentions, you can't wrap it around the whole cord (I think because it gets phase cancelled, like a twisted pair cable.) All the CT's I've seen go around just one leg of the line. So, right, all you need is a bit of current to tell it's on, right?
- H
transmitter/receiver pair for around $15 on some sites. They work pretty good, they lose
data a sometimes but you make up for this by sending repeated transmissions and a
checksum.
You could have a monitor on each outlet pretty cheaply.
