what happens when you shoot 2 lasers at the same spot? — Parallax Forums
science_geekscience_geek Posts: 247
edited 2009-08-09 20:22 in General Discussion
lets just say that 2 lasers are·mount on a turret, one 5 mw laser cant burn a hole in a material, but a 7-10 mw laser will burn a hole. If i were to shine 2 5mw lasers at the same spot, would it burn a hole or do the lasers not combine.
i know this doesnt sound good, but i dont know how else to put it...
«13
    edited 2009-07-18 16:28
    Well, the real answer is more complex than you might think.
    Two lasers aimed at the same spot theoretically might cancel out or they might add together or anywhere in-between. In practice, the kinds of lasers you would use (cheap) with the optics you would have (fair to poor) would mostly add their output together. You might not have exactly the sum of the two amounts of energy, but it would be close.
    Look at some of the Wikipedia's articles on lasers and optics including interference for further information.
    edited 2009-07-18 16:54
    Think of a laser beam as a sine wave. if in phase the amplitudes get added together. If 180 deg out of phase they cancel.
    propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
    Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
    Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
    edited 2009-07-18 21:58
    The answer is more complicated than that. First of all, since the beams are coming in at slightly different angles, any interference would be non-uniform, forming an interference pattern of summing and cancelling in minuscule "stripes" across the target. As a result, the average energy imparted to the target should sum in such a way as to cause the desired burning.
    This does bring up an interesting thought experiment, though. Suppose it were possible (e.g. with a half-silvered mirror) to create colinear beams that exactly cancel. Now each laser emits light having a certain amount of energy. Due to conservation of energy, the energy in the light beams cannot simply disappear. So where does it go when the beams cancel? devil.gif
  • John R.John R. Posts: 1,376
    edited 2009-07-18 23:01
    If a laser never shines on anything, does it still product light? If a tree falls in the forest and nobody hears it, does it still make a crash?
    My head hearts.
    I guess I'm not fully wrapping my aching head around it, but the two waves are not just "canceling" each other out, they are "interfering" - they would be absorbing and emitting each others energy in balance. Sorta. I guess.
    This is almost as bad as:
    • Work = Mass X Height Moved
    • Hold a copy of the "Handbook of Chemistry and Physics" at arms length.
    • Don't raise or lower the book.
    • You haven't done any work (you have not created any additional potential energy).
    • Why is your arm getting tired?
    John R.
    Click here to see my Nomad Build Log
  • CounterRotatingPropsCounterRotatingProps Posts: 1,132
    edited 2009-07-18 23:28
    Into the Burmda triangle, reverbertating and oskalliting off the Mohorovičić discontinuity, and back up beneath the shopping mall in Boulder, Colorado - where all the UFO's are built.
    But you knew that already, Phil, so why are you asking?
  • xanatosxanatos Posts: 1,120
    edited 2009-07-18 23:40
    Heh heh! This is one of my areas of enjoyment. Phil - great question! I don't know the official answer to that question, but I'd venture a guess. Laser radiation is coherent - all the wavefronts are in phase, all the photons come in clumps. If two beams were 180 degrees out of phase, they would not cancel each other out, as there is only an absence of photons in between the "clumps" of photons, not antiphotons (although a photon is its own antiparticle, I believe, like neutrinos). It would be like voltage through a bridge rectifier - the peaks of one beam would simply squeeze in between the other. Getting this to happen PERFECTLY would be a real feat, however.
    As for 7 to 10 mW burning anything - don't expect much! One of my active hobbies is making VERY high power lasers, and I like to make handheld units with arrays of diode lasers. Here's a video of a single red diode laser I ran up a few years ago putting out somewhere around 150 to 200mW, igniting a match:
    Ignore the rest of the circuitry running on the board - that light show was another project for a friend's vehicle and has nothing to do with the laser, which is just a current regulator, a resistor and a capacitor.
    There are now single diode lasers that put out around 500mW of red. The diodes for BluRay DVD Burners put out a near UV beam that is around 405nm and now are getting up around 150 to 200mW, and so are capable of popping small holes in things with good optics.
    If you are VERY CAREFUL and take ALL the precautions inherent in these items, you can do a lot with these items. An IR Laser Diode can put out 50 WATTS of power and cut thick materials rapidly (downside to IR: you can't see the beam, and you can lose your vision in a second with stray reflections. USE LASER SAFETY GOGGLES!!!). One of my "to do" personal projects is to use a BS2 to control an X-Y plotter style device that has an IR laser diode instead of a pen, that I can program to cut out parts for other projects.
    But I digress. If you want to combine beams, you want to use a polarized beam combiner cube. Laser diodes put out polarized radiation. If you put one polarization into one face of the cube, and rotate another laser diode 90 degrees and put its beam into the adjacent face of the cube, the resultant output beam will be a randomly polarized beam that is roughly equal to the input power of the first laser plus the input power of the second, minus a very small percentage of losses through the cube and whatever collimating optics you use.
    You may also use these little cubes to combine lasers of different wavelengths. I tend to go for combining the highest power devices I have got, but I have also combined my 632nm reds and my 405nm UVs to get some really pretty colors! smile.gif
    One last thing - once you have combined two beams, you cannot use another cube to add in beams - as only ONE polarity will pass through the next cube face, so you'll lose 1/2 your beam power in the attempted second recombine.
    If you want to learn a LOT about high power diode lasers, there are several forums you can go to, the best two I have found are laserpointerforums.com and laserenthusiast.com. Be forewarned that those boards are no where NEAR the level of professionalism you will find here. There's a lot of "drama" (which is why I tend to use them in a "read only" fashion now). But there is no doubt that theere is a wealth of highly valuable and useful information to be had there, and there are a handful of helpful and intelligent folks on those boards who contribute regularly.
    I hope this info has been useful to you.
    Lasers are fun. Microcontrollers are fun. Looking forward to combining the two! smile.gif
    Dave X
  • PhilldapillPhilldapill Posts: 1,283
    edited 2009-07-18 23:50
    I've often wondered the same thing, Phil. Applying that sort of thinking to a different experiment, I'd love to see the results.
    The experiment goes something like this. You get two colinear beams that are just SLIGHTLY different wavelengths - say the frequency is just 1Hz difference. Shine this colinear beam on a wall, with a second wall behind it. The first wall would need to be SUPER thin, but still opaque. As the waves come in and out of phase, the net EM field is zero, so at some points, the light SHOULD pass through the first wall, go out of phase, and hit the wall behind it. Basically, it's like shining a flashlight on an opaque wall, but having some of the light "magically" pass through and hit whatever is on the otherside.
    Spooky. I'm going to talk to some physics professors once my normal semester starts back up this fall at my university. I'm sure there's a simple explaination.
    edited 2009-07-19 00:04
    xanatos your description of laser light is not exactly correct. Laser light has a very stron quantum effect to it. You need to think of the light as waves not as photons traveling in a straight line.
    Phil Pilgrim you are correct the 2 waves do not cancel out exactly like sine waves do unless they were some how traveling along exactly the same tragectory 180 deg out of phase. would become an interesting output because the angle between them would make the phase difference chancge from point to point along the paper.
    As for what happens to the energy. If we had to lasers of different frequency shining through mirrors to some how line up so that there beams ran in the same trajectory. as the beams went in and out of phase with each other it would brighten and dim. When it hits the paper we are trying to light up it will either reflect of pass through. Cool thing is if we get it so it perfectly cancels when it hits the paper the paper would not light up but we could see the beam on the other side(dimmed because some will have reflected but none will have been absorbed)
  • dev/nulldev/null Posts: 381
    edited 2009-07-19 02:26
    The energy of two or more interfering waves will either be smaller at some places and greater at others, or smaller at some instants and greater at others. If they cancel out completely, you didn't have a wave to start with!
    Don't worry. Be happy
    edited 2009-07-19 02:49
    Mctrivia, I may be incorrect, but as far as I know, photons are both wave and particle. The double slit experiment showed us, as I understand it, that when you set up conditions for photons to behave as particles, they behave as particles. If you set up conditions for them to behave as waves, they behave as waves. And if you set up conditions for them to do something impossible as one form, they will do something likely as the other. The bottom line seems to be that a) they are very cooperative, and b) they know when you're watching! smile.gif
    I think my point in my previous post was that there is no "negative light" in a laser beam, so, unlike a "regular" electromagnetic wave, there is only a wave of increasing energy density or decreasing energy density, but at its lowest energy point over time, there is no energy present to "cancel" the wave of the opposite phase.
    Dave
    edited 2009-07-19 04:03
    John R. re "If a laser never shines on anything, does it still product light? If a tree falls in the forest and nobody hears it, does it still make a crash?"
    This is an argument I had with a teacher or two in high school. First define what you mean by light and crash (sound). If you define light and sound as something seen and heard respectively then by that definition the answer is no. If you define light as energy emitted at specific wavelengths and sound as vibrations produced in a medium then the answer is yes. Nothing personal John, but consider this to be one of the dumbest pseudo philosophical questions of all time, and I spent several hours in detention for my opinion.
    As for the " * Why is your arm getting tired? " question, that is a much more interesting one. Your muscles require energy to maintain contraction against any applied force. Think of a rope wrapped around a motor shaft with a weight on the end of it. To keep the weight at any but the fully extended position requires power to the motor even though you are not adding energy to the weight.
    edited 2009-07-19 04:22
    xanaots said...
    You are correct. the double slit experiment shows us that light indeed adds together and cancels itself ot like we would expect waves to do. the really interesting thing with that experiment is not only does light cancel itself out but if you do the experient 1 photon at a time where there is no other photon to interfear as long as you are going to send another it will still interfear. the reason because the photon do not interfear with each other but in fact interfere with the probability of each other.
    This experiment was the first proof that quantum mechanics was real.
    edited 2009-07-19 04:34
    Ha! mctrivia, you explained it well. However, these are not standing waves, so some light will pass through, while some light will not. You would see two spots - one on the first wall, and one on the second. If you were to look at each wall at a single instant though, the light would be proportional on each wall based on the phase angle.
    edited 2009-07-19 04:38
    Wow! This is even more entertaining than I thought it would be. I feel like Spencer Tracy in It's a Mad, Mad, Mad, Mad, Mad, Mad, Mad World.
    Excuse me while I adjust my chaise. Mozo! Una otra margarita, por favor!
    edited 2009-07-19 04:46
    with the double slit experiment you do not get 2 spots you get a image like below.
    if you send one photon at a time you have to use film so you can see the patern after firing a few million photons.
    going back to the first experiment there is no slits but two beams overlapping but rotating in there phase to one another. you should see a sine wave like intensity over the length of the beam. if the rotation was small enough say 3nHz it could be easily seen with naked eye.
    Post Edited (mctrivia) : 7/19/2009 4:53:25 AM GMT
    969 x 443 - 7K
    edited 2009-07-20 06:08
    I was under the impression that lasers (either diode or gas) above a few hundred mW were unavailable to non-commercial or non-military users (i.e. you and me).
    Is that not the case?
    If so, I've seen some really nice 50 - 75 WATT (yeow!) laser diodes I'd considered using in an "intruder dissuading" project.
    Smiles,
    DJ
    Instead of:
    "Those who can, do.· Those who can't, teach." (Shaw)
    I prefer:
    "Those who know, do.· Those who understand, teach." (Aristotle)
    edited 2009-07-20 07:19
    http://www.wickedlasers.com/
    edited 2009-07-20 11:11
    High powered diode lasers can often be harvested from surplus or damaged equipment, if you know where to look. I have all my local computer repair shops saving 20x+ DVD burners for me. eBay is a reliable and unending source of high power IR laser diodes (40+ Watts are easy to come by). But IR is very difficult to work with because you can never know with certainty if there's a stray reflection which can blind you fast and permanently, and additionally, you need some very specialized (read: expensive) optical materials to properly focus and collimate the beam.
    That said, I've seen an 80 Watt IR cut a fried chicken leg in half in about 6 seconds.
    Dave
  • LilDiLilDi Posts: 229
    edited 2009-07-20 16:59
    I don't buy any of this idea that light waves some how interfere with one another. If I remember back in the stone age when I took a quantum physics class, I was taught that light beams do not interfere with one another. Shine as many light beams as you wish, each of a different wave length (color) or of the same wave length, that all intersect at one point in space and all of the light beams will pass through one another unaffected and shine on a white piece of paper with their respective unchanged colors. The colors don't mix or cancel one another. Once the light strikes an object, then chemistry dictates what photons will be emitted from the atoms that absorb the initial photon energy. If two CO2 lasers strike an object at the same spot, then I would expect the electrons to absorb twice as much energy as one CO2 beam striking an object and release twice as much energy as a single beam. Has physics changed since the stone age?
    edited 2009-07-20 17:04
    In that case no they will not interfear. However at the point of intersection they will interfear but only there.
    Good book on this subject is
    Fabric of the cosmos : Space time and the texture of reality by Brian Greene
    Post Edited (mctrivia) : 7/20/2009 5:43:56 PM GMT
    edited 2009-07-20 17:50
    At the point of intersection of all the light beams, they will all pass through one another and onto the white paper with no interference from one another at all. I don't care if its a thousand different colors of light or the same color of light, they do not interfere with one another as seen on the white paper they strike. With several mirrors, reflect the sun light onto a single point, with each added mirror, the heat energy at the point of convergence increases. These are observations from experimentation.
    I don't question Brian Green's credentials and have not read those two books, but i do know that both books are in the realm of theoretical physics, not proven science.
    edited 2009-07-20 17:57
    actually it is 1 book and yes it is a book on quantum mechanics. Light will not interfere in a way that effects the light farther down the path. so in your example the light will pass through a single point and the beams exiting the light will be unaffected by each other. However at the point where they intersect light will in dead interfere with each other. In the example we are talking about we have 2 beams following the same path so that both of the beams intersect along every point of there path. In this particular case the interference will happen along the entire length.
    In normal white light there is so many different frequencies that no noticeable difference will be seen. However in the case of lasers that have 1 frequency and all the light is lined up in phase the effect can be very noticeable.
    The 2 slit experiment would not give an output like the diagram shown above if light did not interfere with each other. The output seen by the experiment is what would be expected from 2 sine waves adding and subtracting from each other.
    edited 2009-07-20 19:06
    LilDi,
    If two beams of light did not interfere with each other at the surface of a substrate, holography would not be possible. But holography uses coherent light from a laser. When you cite the example of the sun reflecting from mirrors, you're talking about incoherent light. In such a case, the lightwaves will still interact at the surface, but any interference effects will be so transient and disassociated as to be undetectable.
    Also, it should be noted that beams from two separate lasers will not be mutually coherent, having emanated from independent sources. So they will not form a static, detectable interference pattern at the target. Multiple lasers aimed at a target containing deuterium or tritium are being tried as a means of exciting nuclear fusion in the sample to produce power.
    edited 2009-07-20 21:17
    LilDi > ... when I took a quantum physics class,
    That was quantum I and maybe II - you need to get deeper into QED (quantum electro-dynamics) to look at Phil's rather devilish - and perhaps - trick, question. :-P
    Dave (xantos)> (although a photon is its own antiparticle, I believe, like neutrinos).
    AFAIR, Dirac noted first in "Principles of Quantum Mechanics" that a photon can only interfer with itself. But that was really before QED kicked into high gear. Since a photon is a _boson_ they can interfere with other photons. A neutrino is a lepton, not a boson.
    Keep in mind that a photon's probablity state ("probability amplitude") of *where* it is, differs from where it is observed, (where it is annihilated).
    The question really is, can two photons from different sources be superpositioned?
    - Howard
    ____________________________________________________________
    If Schr
  • David BDavid B Posts: 593
    edited 2009-07-20 22:25
    It sounds like Lildi is using "interfere" as referring to nonlinear mixing, as in a radio mixer, where two frequencies mix to form new frequencies that were not originally present.
    Ordinarily the light beams will not generate new frequencies when they pass through the same region of space, but their electric and magnetic fields will still add or subtract where the beams cross.
    In cases where the beams are extremely closely matched, such as when recombining beams from a single light source as in an interferometer, the addition and subtraction can result in large areas of low signal, or darkness, alternating with areas of strong signal, so you see a pattern like a bulls-eye or a picket fence series of lines.
    edited 2009-07-21 18:03
    Well, before Phil finishes his virtual margarita and no longer relishes in our bafflement, let me remind everyone that *no one* has come up with a satisfactory answer to Phil's question! (IMO). [noparse]:)[/noparse]) So far we've said only what the phenomenon is not, or am I missing something?
    edited 2009-07-21 18:09
    The question of what would happen with two laser sinking perfectly at the point they hit the paper? Yes it was answerd. The laser will act as normal part will reflect and part will pass through. None will be absorbed by the paper though. No energy lossed it just did not go into the paper
    edited 2009-07-21 18:29
    McT.,
    Phil did mention the question immediately after, and in the context of, interference 'across' and 'energy imparted to a target'. To which your post with the interference amplitude waveforms was a nice explainer when the wave function is solved, when the photons are observed and annihilated. However, that is *not* what Phil's thought experiment is, the actual question was much more subtle and I requote:
    " Suppose it were possible (e.g. with a half-silvered mirror) to create colinear beams that exactly cancel. Now each laser emits light having a certain amount of energy. Due to conservation of energy, the energy in the light beams cannot simply disappear. So where does it go when the beams cancel? "
    Phil can correct me if I'm wrong, but I read this to be asking what is happening to the light beams *in transit, before* any targets are hit. This is a *very* different question than what you address (and also different from what the OP asked about).
    He should have put TWO to FIVE devils at the end of his question - it's been a thorn in optical quantum mechanic's side for decades. In fact, it's a thorn in the side of not only Q.M. but also touches on the entire "standard model" and the unresolved "grand theory" bridges needed between QM and relativistic theories. It goes to the very foundations of modern science. (That's why I was so flippant in my first answer, because from what I've read in Phil's other posts, he *usually* ;-P knows what he's talking about --- I suspect he knew where this was coming from too.)
    If, to this question, you give an answer that physicists accept, this forum will become very hot and famous - because you will certainly win a Noble.
    cheers
    - H
    edited 2009-07-21 18:55
    A well that is more complicated because it would never again find itself out of the quantum unsertenty
    My guess is it would become the perfect laser never losing any energy no mater how much it reflects. Though its energy would not be in a visible form but in a probabilistic form only
