Sensor to measure a distance!
Hi I'm new to all this and just need all your opinions on how to resolve my problem please so that i don't buy lots of stuff for nothing! [noparse]:)[/noparse]
Anyway what I'm trying to do is build a device that i will be able to use to measure a long piece of rope that will be at speed!
At first i was looking on google for a measuring wheels but i needed a wheel that was digital and could be plugged into a USB port to retrieve the data into my software!
And some how i have ended up at this site! so i was wondering on building it my self as i can program! so do u have any ideas like do you think i could use the "Reed Switch and Magnet" with the magnet on a wheel so that as the rope passes the wheel, the wheel will turn and then the magnet will pass the sensor every diameter of the wheel and then if i know the diameter in mm then i could work out how long the rope was!!!!!!!!!!!
www.leonheller.com/usb
There are lots of other ways to do it, but they will probably be more expensive and more complicated.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Post Edited (Leon) : 7/14/2009 6:54:44 PM GMT
http://www.lenord.de/en/produkte/sensorline/01absolut/Agel235/promotion/parametrierung/index.html
which i hope to use and found a cable wheel reader that i hope to steel the design idea!
[url=http:// http://www.trumeter.com/home.php?class=Length+Measuring+Systems&app=Cable+and+Wire+Measuring&item=2630&lang=English ] http://www.trumeter.com/home.php?class=Length+Measuring+Systems&app=Cable+and+Wire+Measuring&item=2630&lang=English [/url]
cheers for your help and any other comment any one else wants to make [noparse]:)[/noparse]
anyone know any cheap but good rotary absolute encoders?
It's quite easy to make one if you have machining facilities, you just need a disk with holes drilled in it and a couple of opto switches.
Leon
well I'm hoping once creating the above and connecting it to a wheel that will be resting on the 13mm diameter wire rope witch is 100 meters long and when the wire rope passes the wheel the encoder will be able to pass back information to my laptop in meters cm and mm but if it doesn't then i could cope with just meters and cm! [noparse]:)[/noparse]
to give you some idea on what i do when im not in a recession then here is a video
thanks again for your responses [noparse]:)[/noparse]
Leon
If you want to build a cheap prototype to test the feasibility use the guts from a mouse. It has everything you need including the USB connection to the computer.
thepiratebay.org/torrent/4960955/USB_Complete_The_Developer_s_Guide_4th_Ed_tqw__darksiderg
the link takes you to a torrent download page to get a free copy! the book is usually £40 in the shop. i hope it helps some one!
Please note the above link is illegal as you should pay the £40 for it and W9GFO may not like you if you download from it!
Post Edited (whitefinger) : 8/5/2009 12:22:17 PM GMT
If it is the author's or publisher's intent to make it available for free via download you should include that information.
Rich H
I doubt you will find that anyone here that is offended by you wanting to offer help.
I did not mean to say that posting that link was against the law. However, directing people towards a product which was uploaded illegally - and because of that they can now get it for free, is wrong in my opinion. You are participating in the distribution of stolen property.
I recommended that you remove the link because I think it is in bad to taste to post links for things that you know were ill-gotten.
Rich H
And as my cable that i intend to measure will reach speeds of 50 meters in just a few seconds i feel i need to look else where!
i am currently looking at syscompdesign.com/lab6.pdf and robotroom.com/Counter.html Which i feel will hopefully get me started just need to get the bread bored and bits! still think im going to have a hard time making it USB capable! does anyone know if you create a USB devise your self if you can just give it your own ProductID and VendorID in which to communicated with your own software or do u have to pay lots of money to the USB people to get ur own unique ID's! I'm sure you can as it would be stupid to pay all that money when u are still at the testing stage?????
But nice to see im not mad and that some of my idea are worth creating just like what this person did and beat me to it [noparse]:([/noparse]
http://www.geomem.com/index.php5?x=catalogue&cmd=viewproduct&id=77#pricing
