anyone know any cheap board to board headers?
I need to be able to connect multiple boards together and was looking at surface mount 90 headers but on digikey they run about $6-$8 each. Anyone know of cheaper method or cheaper place?
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
www.rapidonline.com/Cables-Connectors/Connectors-Multipole/PCB-Interconnect/Single-row-sockets/76075
I buy the longest ones and cut them to size.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Post Edited (Leon) : 7/16/2009 2:33:01 PM GMT
Also not surfacemount but prices are good do I will do some searching.
www.samtec.com/technical_specifications/overview.aspx?series=HW
Leon
Try their sample feature to see what one of them is like, and then you can go from there.
Quit buying all those fixed voltage regulators, and·get an Adjustable Power Supply·for your projects!· Includes an LED testing terminal!
*-NEW-* SD Card Adapter·Now available!· Add extra memory to your next Propeller project with ease!
Leon
Does anyone know of an sip socket that is similar or the same as this one?· I would rather order straight from a manufacturer than from a distributor...
Thanks.
Exactly how are you connecting two boards together? You mention SMT Right Angle connectors. Does this mean you are connecting them end-to-end? Have you tried Tyco's picture search? How many connections do you need?
Vaati:
Try searching on Tyco's website for SIP Machined sockets. Enter "SIP MACHINED" in the search window and when the results come up, click on the keyword results tab. (the part number results tab shows first making you think you don't have any results. This is the link to the results page, not sure if it will work as a LINK. For example, check out P/N 2-1571995-0 which is a 20 pin with a 0.318" lead length.
Andrew Williams
WBA Consulting
IT / Web / PCB / Audio
Oh--I found what I needed from Mill-Max about 3-4 weeks ago...
My suggestion to anyone who needs connectors is to go to mill-max.com
Thanks anyways.
