anyone know any cheap board to board headers? — Parallax Forums
mctriviamctrivia Posts: 3,772
edited 2009-08-11 22:22 in General Discussion
I need to be able to connect multiple boards together and was looking at surface mount 90 headers but on digikey they run about $6-$8 each. Anyone know of cheaper method or cheaper place?
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
  • LeonLeon Posts: 7,620
    edited 2009-07-16 14:26
    I use these:
    www.rapidonline.com/Cables-Connectors/Connectors-Multipole/PCB-Interconnect/Single-row-sockets/76075
    I buy the longest ones and cut them to size.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
    Post Edited (Leon) : 7/16/2009 2:33:01 PM GMT
    edited 2009-07-16 17:34
    I can't buy biggest and cut because will eventually be assembled by automated machines.
    Also not surfacemount but prices are good do I will do some searching.
  • PrettybirdPrettybird Posts: 269
    edited 2009-07-16 21:16
    Chinese have alot on ebay if you in no hurry. Shipping 2 to 3 weeks average.
    edited 2009-07-16 21:26
    Samtec makes them:
    www.samtec.com/technical_specifications/overview.aspx?series=HW
    Leon
  • VaatiVaati Posts: 712
    edited 2009-07-16 21:37
    You can always get some from Mil-Max....
    Try their sample feature to see what one of them is like, and then you can go from there.
    Quit buying all those fixed voltage regulators, and·get an Adjustable Power Supply·for your projects!· Includes an LED testing terminal!
    *-NEW-* SD Card Adapter·Now available!· Add extra memory to your next Propeller project with ease!
    edited 2009-07-16 21:53
    Samtec is very good with samples, as well.
    Leon
    edited 2009-07-16 22:05
    This is slightly off topic, but as I did not want to make another thread I will just say it here...
    Does anyone know of an sip socket that is similar or the same as this one?· I would rather order straight from a manufacturer than from a distributor...
    Thanks.
    edited 2009-08-11 21:32
    mctrivia:
    Exactly how are you connecting two boards together? You mention SMT Right Angle connectors. Does this mean you are connecting them end-to-end? Have you tried Tyco's picture search? How many connections do you need?
    Vaati:
    Try searching on Tyco's website for SIP Machined sockets. Enter "SIP MACHINED" in the search window and when the results come up, click on the keyword results tab. (the part number results tab shows first making you think you don't have any results. This is the link to the results page, not sure if it will work as a LINK. For example, check out P/N 2-1571995-0 which is a 20 pin with a 0.318" lead length.
    Andrew Williams
    WBA Consulting
    IT / Web / PCB / Audio
    Yes I am connecting boards end to end. Parts were expensive but will do.
    WBA Consulting,
    Oh--I found what I needed from Mill-Max about 3-4 weeks ago...
    My suggestion to anyone who needs connectors is to go to mill-max.com
    Thanks anyways.
