Parallax boards — Parallax Forums
Parallax boards
kevin101kevin101 Posts: 55
edited 2009-07-16 05:54 in Propeller 1
Does anybody have a BOM for these boards?
I picked them up from the scrap pile at UPEW and a friend there helped me solder on a few components to them. I can guess some of the missing parts, but I have no Idea what the rest of them are.
    edited 2009-07-16 02:09
    looks like they are already populated with all parts. bottom is a generic BGA adapter use any BGA chip up to that big. others have pads for different sized parts.
    propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
    Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
    Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
  • ProcessingData...ProcessingData... Posts: 208
    edited 2009-07-16 02:18
    The one in the upper right might be a board for the Quad Rover.
    Basic Stamp,···· Propeller,·· · SX,·· FUN!
    START:·
    >Proccessing Data. . . .··
    >Task Complete. . .·.
    >Saving Data. . . .
    >Entering SLEEP Mode. . . .
    >Signing OFF
  • WhitWhit Posts: 4,191
    edited 2009-07-16 02:47
    Yes, The Upper Right is the Propeller Control Board and it what is used on the Quadrover.
    See here http://www.parallax.com/Store/Microcontrollers/PropellerDevelopmentBoards/tabid/514/CategoryID/73/List/0/Level/a/ProductID/533/Default.aspx?SortField=ProductName%2cProductName
    Whit+
    edited 2009-07-16 03:46
    Here's the BOM for the Propeller Control Board:
    Stock code Quantity per U/m Description Long description
    150-11031 25 EA Res 0603, 10k, 5% LF Res 0603, 10k, 5%
    172-01542 1 EA DISCON RES,15.4K,1%,0603-LF DISCON RES,15.4K,1%,0603-LF
    172-02102 1 EA DISCON RES,21K,1%,0603-LF DISCON RES,21K,1%,0603-LF
    172-02240 1 EA DISCON Res 0603, 220K, 5% DISCON Res,SM,0603,5%,1/10W
    172-02410 1 EA DISCON Res 0603, 240 ohm, 5% DISCON Res 0603, 240 ohm, 5%
    172-04740 1 EA DISCON Res,SM,0603,470K ohm-LF DISCON Res,SM,0603,5%,1/16W-LF
    172-04991 1 EA DISCON RES,4.99K,1%,0603-LF DISCON RES,4.99K,1%,0603-LF
    172-04993 1 EA DISCON RES,499K,1%,0603-LF DISCON RES,499K,1%,0603-LF
    211-01060 1 EA Cap,SM1206,10uF,25V,X5R- LF Cap,SM1206,10uF,25V,X5R
    213-01020 1 EA Cap 0603, 1nF, 50V, C0G Cap 0603, 1nF, 50V, C0G
    213-01030 1 EA Cap 0603, 10nF, 50V, X7R LF Cap 0603, 10nF, 50V, X7R
    213-01051 4 EA Cap 0603, 1uF, 16V, X7R Cap 0603, 1uF, 16V, X7R
    213-02230 1 EA Cap,0.022uF,50V,0603-LF Cap,0.022uF,50V,0603-LF
    213-03310 1 EA DISCON CAP,330pF,100V,0603-LF DISCON CAP,330pF,100V,0603-LF
    213-03320 1 EA DISCON - CAP,3300pF,50V,0603- DISCON CAP,3300pF,50V,0603-LF
    213-04750 1 EA DISCON CAP,4.7uF,50V,1210-LF DISCON CAP,4.7uF,50V,1210-LF
    217-02270 1 EA DISCON CAP,220uF,10V,7343-LF DISCON CAP,220uF,10V,7343-LF
    251-05000 1 EA XTAL HC-49US, 5MHz, 20pF -LF ECS-50-20-4
    275-03300 1 EA DISCON IND,33uH,CDRH127-LF DISCON IND,33uH,CDRH127-LF
    300-28195 1 EA DISCONRaw PCB,Propeller Contrl DISCONRaw PCB,Propeller Contrl
    350-10004 1 EA LED 0603, Blue Clear LF LED 0603, Blue Clear
    400-00014 1 EA SWITCH 3 POSITION OS203011MS1QP1
    400-10002 1 EA SW SMT Tactile 3.5mm sq (CLR Button)
    450-00301 4 EA DISCON 3 pin SIP Socket DISC ON 3-Pin Socket Strip
    450-00401 1 EA CONN SIP-4, Socket LF CONN SIP-4, Socket
    451-00401 1 EA DISCON-4PIN RA SIP header DISCON HDR 1X4 RA
    451-03080 1 EA DISCON CONN,HDR,3X8-LF DISCON CONN,HDR,3X8-LF
    451-03120 1 EA DISCON CONN,HDR,3X12-LF DISCON CONN,HDR,3X12-LF
    452-00012 6 EA 2 Pos Screw Terminal- LF Terminal
    452-10010 2 EA ="Conn Pin Socket, .015/.021"-LF" MillMax0552-1-15-15-11-27-10-0
    501-10007 1 EA BAT54S Diode (SOT23) - LF Diode
    501-13007 1 EA DISCON DIODE,100V,7A,TO-252-LF DISCON 30WQ10FNPBF
    601-00511 1 EA VREG SOT-223, 3.3V - LF National LM2937IMP-3.3
    601-25576 1 EA DISCONIC,VREG,LM25576,TSSOP-20 DISCONIC,VREG,LM25576,TSSOP-20
    602-10001 1 EA IC SRL EEPROM 512K 2.7V AT24C512-10TU-2.7. LF
    603-00010 1 EA DISCON IC,74HC4017,SSOP-16 DISCON IC,74HC4017,SSOP-16-LF
    604-00608 1 EA DISCON IC,FET,FDC608PZSOT-6-LF DISCON IC,FET,FDC608PZSOT-6-LF
    604-06990 4 EA DISCON IC,FET,DUAL,FDS6990A,SO DISCON IC,FET,DUAL,FDS6990A,SO
    P8X32A-Q44 1 EA P8X32A-Q44 (QFP) Parallax P8X32A-Q44 (LQFP44)
    X00-00009 0 EA Label
    X20-00500 0 EA Bag ESD Silver Ziplock 4x6 Bag ESD Silver Ziplock 4x6
    We can't supply these components as many of them we no longer stock. You'll spend a lot of money to build these up if you can procure all of the components on your own. I wouldn't recommend pursuing a finished design. The PCB you have may even be an early prototype; it's possible it has a functional issue.
    The other two products are very old ansd were discontinued a long time ago. Our network records have been archived off already.
    Sincerely,
  • kevin101kevin101 Posts: 55
    Thanks Ken,
    I may assemble one propeller control board, but like you said, it would be expensive. Andrew at the convention stripped the propeller from a dead demo board and soldered it to this one, but theres no guarantee that it even works. I think it was just a fried regulator on the demo board. Do you also have a layout of the board where it shows where the components go? I know where most go, but in some areas it gets a little hazy, like the magneto input pin protection circuit. Also, I think these PCBs may have been left over from production, as these boards have been discontinued, but I may be wrong.
    I was planning to use the Cyclone fast pack to start developing things on FPGAs, but that is pretty difficult. For the PCB, I know that the cyclone requires 1.5v and a whole ton of bypass capacitors, but the "PX loader" and the RS-232 specifics are beyond me. I have absolutely no intention of assembling the other board, as it is BGA, and don't have the right tools to solder that crazy mess. I'll see what part hunting for these boards leads me to...
    On another note
    Thank you once again for your support at the UPEW! I'm loving my PPDB and all the other fun stuff you donated through the "Parallax Welfare program". Hopefully I can go again next year for more excitement and learning. Meeting Randy (the energetic contractor with intentions to conquer the world) and all the great people at the UPEW made for a wonderful weekend.
    Kevin
